I did an update from 114.4 to 115.2 and now I get this errror: “You are running an unsupported installation.”
It is not possible anymore to add a new integration.
Details of my setup:
How to solve it?
note: stepped back to 114.4: same issue
in the logfile:
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] udev.sh: executing…
[12:22:51] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[12:22:51] INFO: Start local supervisor watchdog…
20-09-21 12:22:53 INFO (MainThread) [supervisor.bootstrap] Use the old homeassistant repository for machine extraction
20-09-21 12:22:53 INFO (MainThread) [main] Initialize Supervisor setup
20-09-21 12:22:53 INFO (MainThread) [supervisor.bootstrap] Initialize Supervisor Sentry
20-09-21 12:22:53 INFO (MainThread) [supervisor.bootstrap] Setup coresys for machine: qemux86-64
20-09-21 12:22:53 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 245
20-09-21 12:22:53 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connect Supervisor to hassio Network
20-09-21 12:22:54 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: [‘homeassistant/amd64-hassio-supervisor:244’]
20-09-21 12:22:54 ERROR (MainThread) [supervisor.core] Docker version 18.09.3 is not supported by Supervisor!
20-09-21 12:22:54 ERROR (MainThread) [supervisor.docker] Docker logging driver json-file is not supported!
Seems docker version 18.09.3 is not supported?
other log:
20-09-21 12:34:51 ERROR (MainThread) [supervisor.core] Detected unsupported OS: Ubuntu 18.04.2 LTS
20-09-21 12:34:51 INFO (MainThread) [main] Run Supervisor
20-09-21 12:34:51 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-09-21 12:34:51 CRITICAL (MainThread) [supervisor.core] System running in a unsupported environment!
20-09-21 12:34:51 CRITICAL (MainThread) [supervisor.core] System running in a unhealthy state and need manual intervention!
