But the Developer-Tools info page shows me this:
You are using a custom integration for rpi_power which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
When I clear the error and do a reboot: error is still there.
It gets reported for almost every custom component that is installed.
And as noted above itās only a warning and there is no way to get rid of it but it isnāt causing any harm either.
So, yes you can ignore it but just be aware of the reason why itās there - sometimes custom components arenāt coded properly and cause system instability. So if you start seeing some weirdness going on after running a new(ish) custom component then the first thing to try before submitting an issue to the HA github would be to stop using the custom component(s) to see if it solves your problem.
Same, I HATE looking in my logs and seeing any. Makes me chase my tail to resolve as normally seems like they should not be there. REALLY makes me mad when they are these as no one knows how to get rid of them.
Iām getting ones for things I donāt have installed. We found a custom integration yandex_station which has not been tested by Home Assistant
I donāt even know what Yandex Station is We found a custom integration start_time which has not been tested by Home Assistant
Not sure what that is, but the name is so ambiguous I may use it We found a custom integration webrtc which has not been tested by Home Assistant
Another I cannot tell what it is We found a custom integration xiaomi_gateway3 which has not been tested by Home Assistant
Donāt own any Xiaomi products We found a custom integration hacs which has not been tested by Home Assistant
This one I know We found a custom integration sonoff which has not been tested by Home Assistant
Donāt use Sonoff We found a custom integration yandex_station which has not been tested by Home Assistant
Another one of these.
I have HACS installed, but the others I do not see in my integrations. How do I remove the things I donāt use?
It says āThis component might cause stability problems, be sure to disable it if you experience issues with Home Assistantā but I cannot see any way to do that
