I then created the dashboards.yaml file "/homeassistant/dashboards.yaml " . I copied the content of my current dashboard using Raw Configuration Editor.
I restarted Home Assistant.
I donât see my new dashboard YAML in my the sidebar and neither in the Setting-Dashboard.
The documentation mention that I should create the file in my configuration directory, but I cannot find such directory.
What am I doing wrong ? Any additional steps required?
I am just following the instructions in the Home Assistant official documentation.
I did not change anything in the structure of the file. Using File Editor, I can see that my configuration.yaml is in the homeassitant directory. Nowhere I can see âconfigâ directory.
Where can I get more information about your suggestion to access my dashboard with http⊠directly. What is the advantage to do so?
to answer your question about file editor and the path⊠file editor is actually abstracting some of that away from you. do you have samba installed? if you donât, you should⊠then you can browse the home assistant full directory from your mac/pc.
also do you have visual code studio? i prefer using that for when i need to instead of file editor. visual code studio will show you the real heirarchy.
but again, especially if you are new⊠use the ui, donât grovel the yaml first. not only will it guide you and make things easier, it will also help prevent you from making accidental catestrophic mistakesâŠ
on another thread someone corrupted their config file⊠they said they didnât change anything⊠but when we actually saw the file, it was clear they had an accidental âpasteâ in the header and it prevented homeassistant from bootingâŠ
Thanks for your quick reply and clarifications.
About the config directory; I just find out that it as been rename homeassistant.
That explain why while editing my configuration.yaml file the top line show
â /homeassistant/configuration.yamlâ.
It seem that not all documentation have been updated.
in your yaml, you have set mode: storage this is used when itâs ui managed. but you are saying you donât want to use the ui. so you should set this to be mode: yaml
if i may⊠can i still inquire why you want to do it purely in yaml? the official documentation does recommend the ui. see it below. it has yaml as an alternative. but it first focuses on the ui method. if youâre new to this, i would strongly recommend as well. i donât believe you lose any power or flexibility going that path.
but in any case ,if you want to stick with it⊠start with switching the mode to yaml mode instead of storage. this doc link half way down will explain that as well.
The documentation state:
â You can also add YAML dashboards when your main dashboard is UI configured:â
This statement is follow by the code that I copy to my configuration.yaml file. Including mode storage.
You are saying that storage is for UI, is The documentation wrong?
The reason I wish to use both UI and YAML dashboard types is that I using extensively custom:decluttering-card. I want to used the included file or directories within my YAML dashboard and copy my decluttering templates into raw-configuration-editor of my UI dashboard.
I understand that my approach is not perfect because we cannot include file or directory into UI dashboard.
iâm not saying the documentation is wrong⊠what iâm saying is actually consistent with the documentation. i think perhaps that you may want to read the full documenation.
note where it says specifically that the mode should always be set to yaml. and that storage mode is for those created in the configuration (ui) panel.
I understand your alternives, but, at this point in time, I would prefer to stick to the official documentation.
But the official documentation also mentions setting up dashboards in the UI. And itâs the first method explained, at the very beginning of the article. YAML method is second, and itâs more complicated.
You can manage your dashboards via the user interface. Go to Settings > Dashboards. Here you can see some of the defined dashboards and create new ones
So, unless there is a specific reason why you prefer to use the YAML method, I would just do it in the UI.
I sorry for the misunderstanding.
I know and understand that UI Dashboards are the one recommended for Home Assistant. I agreed with this.
I have multiple dashboards all of them are UI controlled.
I am also using extensively âdecluttering templatesâ and âbutton_card_templates:â. I got about 1000 lines of those in my UI Dashboards. I change and maintain then using 'raw-configuration editor.
My concern is that every time I change these templates, I have to cut & paste them in each of my dashboard.
UI dashboard do not support âinclude file / directoryâ. YAML dashboard do.
I am trying to set a new dashboard YAML type.
This dashboard would âincludeâ and external file âdashboard.yamlâ where I will put all my âdecluttering templates / button_card_templatesâ code.
I follow the instructions in the Home Assistant documentation:
lovelace:
mode: storage
# Add yaml dashboards
dashboards:
lovelace-yaml:
mode: yaml
title: YAML
icon: mdi:script
show_in_sidebar: true
filename: dashboards.yaml
I added the code in my â/homeassistant/configuration.yamlâ. Homeassitant being the directory and configuration.yaml the file.
The I created a file âdashborad.yamlâ in '/homeassistant/dashboards.yaml â
The documentation clearly state that I can add YAML dashboards when your main dashboard is UI configured.
I think that I followed every steps of documentation. My problem is that I cannot see anywhere this new dashboard title âYAMLâ mode âyamlâ, even if my configuration indicate that the dashboard should show_in_sidebar: true.
I appreciate all suggestions and alternatives that you are proposing.
But what I am looking for is to do exactly what the documentation say âYou can also add YAML dashboards when your main dashboard is UI configured:â
My question is what did I do wrongly, and what else should I do to see/access/maintain this new dashboard?
