hi
trying to use api password to login my hassio 0.77 on pi3
have enabled the legacy api password however hass says
“You don’t have an API password configured”
any idea how to fix this???
here is my config
homeassistant:
auth_providers:
- type: homeassistant
# Uncomment next line if you want to enable legacy API password support
- type: legacy_api_password
auth:
config:
http:
api_password: 123456789
base_url: homeassistant.org
get rid of all this part
auth_providers:
auth:
if you have the second bit under http: with a legacy password it will use it.
You can also try and delete the hassio, onboarding and maybe the auth files in the .storage folder if you have ssh access
sorry, did not follow this.
Now i have delete .storage and restart, delete chrome cache also
but after i create an account, i still cannot see the api login option…
If you read the fine manual you’ll see that you’re warned against manually listing the providers. This is because Home Assistant will automatically configure them for you.
