Hello, not sure why my installation is unhealthy, working perfectly fine before.
System Information
version
core-2024.2.1
installation_type
Home Assistant Supervised
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.12.1
os_name
Linux
os_version
6.1.31-sun50iw9
arch
aarch64
timezone
Asia/Hong_Kong
config_dir
/config
Home Assistant Community Store
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
4994
Installed Version
1.34.0
Stage
running
Available Repositories
1397
Downloaded Repositories
4
HACS Data
ok
Home Assistant Cloud
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
Home Assistant Supervisor
host_os
Debian GNU/Linux 12 (bookworm)
update_channel
stable
supervisor_version
supervisor-2024.01.1
agent_version
1.6.0
docker_version
24.0.7
disk_total
28.5 GB
disk_used
8.8 GB
healthy
failed to load: Unhealthy
supported
failed to load: Unsupported
supervisor_api
ok
version_api
ok
installed_addons
Advanced SSH & Web Terminal (17.1.0), Zigbee2MQTT (1.35.2-1), Mosquitto broker (6.4.0), File editor (5.7.0), HomePod Connect (28.8-ls126)
Dashboards
dashboards
2
resources
0
views
3
mode
yaml
Recorder
oldest_recorder_run
23 January 2024 at 12:15
current_recorder_run
14 February 2024 at 17:46
estimated_db_size
17.43 MiB
database_engine
sqlite
database_version
3.44.2
Spotify
api_endpoint_reachable
ok
Xiaomi Miot Auto
component_version
0.7.15
can_reach_server
ok
can_reach_spec
ok
logged_accounts
2
total_devices
11
francisp
(Francis)
February 14, 2024, 10:14am
2
ryan.cph:
6.1.31-sun50iw9
Looks like an OrangePi kernel ?
francisp
(Francis)
February 14, 2024, 1:37pm
4
if not using a ‘real’ Debian, supervised installations often become unhealthy for the weirdest reason. Normally, you can click on the ‘repair’ and the ‘learn more’ button will tell you what Supervisor thinks is wrong.
Hmm. Not sure why it’s not “real” Debian. In the repair page it’s telling me to reinstall ha-supervised. Privileged - Home Assistant
Will I lose data if I reinstall them? Now I am just using ha jobs options --ignore-conditions healthy to bypass all errors. Thanks.
francisp
(Francis)
February 15, 2024, 3:57am
6
Not privileged is often solved by a reboot. On a lot of Supervised systems it always happens when Supervisor updates itself.
nickrout
(Nick Rout)
February 15, 2024, 9:14am
7
Reinstalling the ha privileged deb package will not lose data.
Ran wget -O homeassistant-supervised.deb https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb apt install ./homeassistant-supervised.deb
but still getting same error
nickrout
(Nick Rout)
February 15, 2024, 7:47pm
9
Take a look in the directory and make sure the file wasn’t renamed when you download it.
