Ytube_music_player
I’m very new and have been learning, I’m running into a issue where I don’t understand step 2, “Please use the config flow of Home Assistant” While I understand the terminology of this as it’s a flow process to enter in data. I cannot figure out where/what needs to be done to get that to show up for this integration?
I have the cookie as indicated in previous steps, just don’t know where I can paste this in?
  1. Paste the cookie into the indicated field, all other fields are optional
  2. It is highly recommended to enter the entity_id of your default ouput player, otherwise you have to set that after every reboot
Go to Configuration → Integrations → Press “Add integration” in the bottom right and search for the integration, then click on it.
Thank you very much, that made sense now. I had to add it from the HACS integration and then go back into Configuration -> Integrations -> Press “Add integration”. Originally I didn’t see it in there.
