Hello,every time i reboot hassio(last version) my usb zwave stick become unreachable from the ui?
If i unplug the rasp3 power and plug it back the stick works again till next restart from the ui.
I have added this line into my config:
zwave:
usb_path: /dev/ttyACM0
I’m receiving this code:
2018-02-23 13:15:07 ERROR (MainThread) [homeassistant.setup] Error during setup of component zwave
File "/usr/lib/python3.6/site-packages/openzwave/option.py", line 78, in __init__
raise ZWaveException(u"Can't find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: "Zwave Generic Exception : Can't find device /dev/ttyACM0 : ['NoneType: None\\n']"
File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.6/asyncio/futures.py", line 332, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/zwave/__init__.py", line 275, in setup
config_path=config[DOMAIN].get(CONF_CONFIG_PATH))
File "/usr/lib/python3.6/site-packages/openzwave/option.py", line 81, in __init__
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: 'Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : [\'Traceback (most recent call last):\\n\', \' File "/usr/lib/python3.6/site-packages/openzwave/option.py", line 78, in __init__\\n raise ZWaveException(u"Can\\\'t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\\n\', \'openzwave.object.ZWaveException: "Zwave Generic Exception : Can\\\'t find device /dev/ttyACM0 : [\\\'NoneType: None\\\\\\\\n\\\']"\\n\']'
I have two zwave entities, is it normal?
I thought it will easy to configure from the video i have seen, with a one button pairing mode. I bought a fibaro motion sensor and i can’t figured how to pair them thougether.
Any help would be awsome.
