Z-wave - add node
Hi ya all,
I have been trying to add a zwave multi sensor to my setup for a while now. I have one sensor connected (as Node002), but cannot seem to add the other two. I’ve clicked the ‘add node’ button on the zwave configuration page and I received the following in the log, but I cannot see Node001 in the setup. Is there anything else I should be doing or looking at? Do I need to restart the system after adding a node?
2019-04-15 14:44:23.698 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2019-04-15 14:44:23.698 Detail, Node001, Expected callbackId was received
2019-04-15 14:44:23.698 Detail, Node001, Expected reply was received
2019-04-15 14:44:23.698 Detail, Node001, Message transaction complete
I’m trying to pair a zipato multisensor 4 in 1 (one is working) to a Z-Stick Gen5, on HASS.io running via a docker on an intel NUC.
Thanks for any pointers.
I restarted hass.io and all z-wave entities, including the z-stick have disappeared from the Z-Wave Network Management panel.
However, after a subsequent restart, the z-stick is back, but node 2, previously assigned an entitiy name is now reporting as ‘unknown’. Node 1 is not to be found.
