Environment: Raspberry PI 4. Buster. VENV install. HA v0.97.2 Aeotec USB Stick.
Background: This is my third HA Raspberry PI for HA. I’ve been a longtime user and upgraded PIs twice from my original install. On my original and second install, I had no issues with ZWave. Followed the instructions and it worked.
Problem: I’ve been wrestling with the USB stick on this install. I cannot seem to get it to be recognized. I would appreciate someone nudging me from my confusion.
Details:
The current errors I am getting in the log are shown below.
I have also included output from an ls tty command and dmesg.
Any hints on what I could look at next to get this USB stick recognized?
I’m out of ideas since I started this journey last weekend.
*****E R R O R #1:
Log Details (ERROR)
Fri Aug 30 2019 13:17:12 GMT-0400 (Eastern Daylight Time)
Received invalid command: zwave/network_status
*****E R R O R #2:
Fri Aug 30 2019 12:46:59 GMT-0400 (Eastern Daylight Time)
Error setting up entry Z-Wave (import from configuration.yaml) for zwave
File "/srv/homeassistant/lib/python3.7/site-packages/openzwave/option.py", line 78, in __init__
raise ZWaveException(u"Can't find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: "Zwave Generic Exception : Can't find device /dev/ttyAMC0 : ['NoneType: None\\n']"
******TTY OUTPUT:
$ ls -ltr /dev/tty* | tail -n 1
crw--w---- 1 root tty 4, 1 Aug 30 12:46 /dev/tty1
***** DMESG OUTPUT:
$ dmesg | grep USB
[ 0.393428] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.396004] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.396038] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.396633] hub 1-0:1.0: USB hub found
[ 0.397148] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.397184] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.397542] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.397574] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.398139] hub 2-0:1.0: USB hub found
[ 0.826904] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ 0.827529] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.827563] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.828167] hub 3-0:1.0: USB hub found
[ 0.835412] usbhid: USB HID core driver
[ 0.971574] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.153230] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 1.153269] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.153296] usb 1-1: Product: USB2.0 Hub
[ 1.154891] hub 1-1:1.0: USB hub found
[ 1.301845] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1.332595] usb 2-2: New USB device found, idVendor=0789, idProduct=0578, bcdDevice= 2.04
[ 1.332634] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
