Hi!
My Z-Wave network seems to be broken somehow. It has been running flawlessly for the past few months. I’m not sure what as gone wrong, and I don’t want to make things worse. My hassio install in running on a Dell Optiplex running Windows 10 as the host OS with VirtualBox running Ubuntu Server with a Hassio on Docker. The USB is passed though to the VM for the stick. I have had no issues with this setup until recently. I cloned the hard drive as I migrated to an SSD recently, I have no idea if that is related. I am using a Z Stick gen5 with three Zooz dImmers and two of the new Inovelli dimmers (fantastic dimmers).
Currently, on the home page of HA, all my devices show as “unavailable,” however in the Z-Wave section, Z-Wave appears to be started.
I am running HA v0.108.3.
Thanks in advance for your help.
here is my config:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
#Thermostat
climate 1:
- platform: honeywell
username: hidden
password: hidden
region: us
scan_interval: 600
# Example for Z-Wave
homekit:
auto_start: false
discovery:
enable:
- homekit
switch:
- platform: command_line
switches:
aeotec_zstick_disco_light:
friendly_name: 'Aeotec Z-Stick Disco Light'
command_on: 'echo -e -n "\x01\x08\x00\xF2\x51\x01\x01\x05\x01\x50" > /dev/serial/by-id/usb-0658_0200-if00'
command_off: 'echo -e -n "\x01\x08\x00\xF2\x51\x01\x00\x05\x01\x51" > /dev/serial/by-id/usb-0658_0200-if00'
group: !include groups.yaml
script: !include scripts.yaml
My OZW_Log file can be found at https://pastebin.com/gAgKm8js
