Z-wave and automation menu disappeared after upgrading to 51.1
Is it something that should be added in the configuration files to make them work again?
“Another change to the frontend is that we have reorganized the panels. The Z-Wave and automation configuration panels have been merged into the configuration panel.”
It’s moved to the configuration tab
Thx, I missed that and I didn’t have the config tab enabled
Should read better the release notes next time
I can’t find the documentation to enable to config tab. Can you point out where this is, or what the entry looks like?
I found it at https://home-assistant.io/components/config/.
