Hi all,
I am new to Home Assistant and so far I am very happy with my choice. I am currently migrating my Smart Home from a different system to HA.
I am running HA on a raspberry pi 4 with a AEON Labs ZW090 Z-Stick Gen5 EU and have 34 Devices included so far. That went very smooth.
Now I also got a new Conbee 2 Stick since I also own several Zigbee Devices which I obviously want to include in HA.
I got Zigbee it to work with the ZHA integration and I was able to include a few devices already.
However after a reboot my Z-Wave network is stopped and would not start up again. Zigbee still works fine.
Zigbee is connected and configured via:
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2228756-if00
Z-Wave:
/dev/serial/by-id/usb-0658_0200-if00
What am I’m doing wrong? Please help
Z-Wave log:
2020-09-03 11:44:40.515 Always, OpenZwave Version 1.4.3469 Starting Up
2020-09-03 11:44:46.469 Info, Setting Up Provided Network Key for Secure Communications
2020-09-03 11:44:46.469 Info, mgr, Added driver for controller /dev/serial/by-id/usb-0658_0200-if00
2020-09-03 11:44:46.469 Info, Opening controller /dev/serial/by-id/usb-0658_0200-if00
2020-09-03 11:44:46.469 Info, Trying to open serial port /dev/serial/by-id/usb-0658_0200-if00 (attempt 1)
2020-09-03 11:44:46.471 Info, Serial port /dev/serial/by-id/usb-0658_0200-if00 opened (attempt 1)
2020-09-03 11:44:46.472 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-09-03 11:44:46.472 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-09-03 11:44:46.472 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-09-03 11:44:46.472 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-09-03 11:44:46.472 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-09-03 11:44:46.472 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-09-03 11:44:47.472 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-03 11:44:47.472 Detail, contrlr, Removing current message
2020-09-03 11:44:47.472 Detail, contrlr, Notification: Notification - TimeOut
2020-09-03 11:44:47.473 Detail,
2020-09-03 11:44:47.474 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-09-03 11:44:48.474 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-03 11:44:48.474 Detail, contrlr, Removing current message
2020-09-03 11:44:48.474 Detail, contrlr, Notification: Notification - TimeOut
2020-09-03 11:44:48.476 Detail,
2020-09-03 11:44:48.476 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-09-03 11:44:49.477 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-03 11:44:49.477 Detail, contrlr, Removing current message
2020-09-03 11:44:49.477 Detail, contrlr, Notification: Notification - TimeOut
2020-09-03 11:44:50.462 Detail,
2020-09-03 11:44:50.462 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-09-03 11:44:51.463 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-03 11:44:51.463 Detail, contrlr, Removing current message
2020-09-03 11:44:51.463 Detail, contrlr, Notification: Notification - TimeOut
2020-09-03 11:44:51.463 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-09-03 11:44:52.464 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-09-03 11:44:52.464 Detail, contrlr, Removing current message
2020-09-03 11:44:52.464 Detail, contrlr, Notification: Notification - TimeOut
