Z-wave Associations not fully supported in Hass ZWCP?
Hi!
Short question: Is the associations settings in the Home-Assistant Z-wave Control Panel not fully supported?
From what I’ve read, you’re supposed to being able to set the association to specific “parts” of a node, not just the entire node (how it is in hass z-wave network manager right now).
Long question (with my issue, suggestions are welcome!):
I’m trying to setup an association between my fibaro motion sensor and a fibaro double relay switch. Currently I just have a simple automation turning the lights on when movement and turning them off when the motion sensor state have been Off for X minutes. I’m not quite satisfied with the delay of this setup (it takes 1-2 seconds for S1 channel to turn on, and sometimes up to 10 seconds for S2 channel to turn on), so I started reading on Z-Wave associations and thought I might give it a try. However, in Hass I’m only able to choose which node to control, but nothing else. This makes me believe it will not work as intended. I also got the understanding that it should be possible to just set it to one of the channels on the double relay switch, but this is not possible. I can just choose the entire node.
Bonus question: At my current setup I have one automation for daytime (turning boths relays on) and one for night time (only turning on one of the relays). Is this possible to do using associations?
No
Associations are also per device, not per entity, if you grab the manual for your motion sensor you’ll see that’s all that’s supported.
I figured. However, I might be able to accept the fact that I get both switches turned on during night-time aswell, If they can do it without the 10s delay between them…
