I am far into process of migrating away from Wink and am learning Z Wave “stuff” every day. I have a Aeon USB stick, working fairly well with about 30 nodes so far…
I now have a Fibaro button and am surprised I can not do what I want, I get that it really only controls other z wave devices.
Is it possible to use it direct with HA so that I can write automations ( I dont use Node Red…yet, but maybe never)
The only way I can see to use it is to group or associate it with a binary device like a door sensor and use that as a trigger. Is it possible to use more directly? The button presses do not seem to return anything on the sensors I have after inclusion. Is it possible to make a binary_sensor out f 1 of the sensors, although I still need to “see” something in HA from the button press(es) action.
ok, so after 2 failed attampts I finally got it right…as in I can get the Z wave network up again…but the Fibaro button now only has 2 sensors showing, the other 5 that were there are no longer there, they are greyed out…no zwave.scene or anything under services or events. I’ll try a repair node…?
under node it states (Node:27 Probe)
update: it seems like it is a dead node, can not do anything with it, can not exclude, I have tried resetting the device as per Fibaro instruction, remove battery, heal, refresh node, rebooting a few times, tried inclusion again, nada should I go back a remove the code I pasted in and try again?
uodate again: I worked out the problem, had duplicate code, only needed part of what was there…so i was able to include the button again as a new node but can not remove the corrupt node, can I just go delete the node info from that same xml file?
This is getting ridiculous lol! OK, so I have the button with a new node and the right code pasted in. Still not seeing anything related to scenes, any idea of what i am missing??
