Z-Wave certain round trips are really long for one node
Struggling with scenes being incredibly slow, due to the fact that some (mostly one or two) are really slow, and it seems that the Aeotec stick gen5 waits for a response before triggering next command (might be wrong).
Since it seems every command is sequential, and it stops somewhere in the scene selection it takes a long time before anything new can trigger. Also this affects WAF, because she feels she has to wait for everything to turn off before going to bed. Sometimes we are talking 10-15 seconds to go through 10 nodes.
Example of round trips freshly after a restart:
Any advice as to where I should trouble shoot? It seems that it is my Dimmers that mess it up, since switches and smart plugs trigger faster. I tried earlier today to reset the network completely (disconnect all devices one by one, reset z-stick to factory settings, stopp HA and delete files before setting it up from scratch). Still the same issues.
Here is from a simple “turn on” for one node (node id: 2) that is 1,5 meter from the Z-stick
2019-12-08 21:38:21.238 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Dimming Duration - 5 - 1 - 255
2019-12-08 21:38:21.238 Detail, Node002, Refreshed Value: old value=255, new value=255, type=byte
2019-12-08 21:38:21.239 Detail, Node002, Changes to this value are not verified
2019-12-08 21:38:21.239 Detail, Node002, Notification: ValueChanged
2019-12-08 21:38:21.239 Info, Node002, Value::Set - COMMAND_CLASS_SWITCH_MULTILEVEL - Level - 0 - 1 - 255
2019-12-08 21:38:21.239 Info, Node002, SwitchMultilevel::Set - Setting to level 255
2019-12-08 21:38:21.239 Info, Node002,   Duration: Default
2019-12-08 21:38:21.239 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x35, 0xd6
2019-12-08 21:38:21.239 Detail, Node002, Queuing (Send) SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x36, 0xd2
2019-12-08 21:38:21.245 Detail,
2019-12-08 21:38:21.245 Info, Node002, Sending (Send) message (Callback ID=0x35, Expected Reply=0x13) - SwitchMultilevelCmd_Set (Node=2): 0x01, 0x0b, 0x00, 0x13, 0x02, 0x04, 0x26, 0x01, 0xff, 0xff, 0x25, 0x35, 0xd6
2019-12-08 21:38:21.253 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-12-08 21:38:21.253 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
2019-12-08 21:38:21.269 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x35, 0x00, 0x00, 0x02, 0xdc
2019-12-08 21:38:21.269 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x35 received (expected 0x35)
2019-12-08 21:38:21.269 Info, Node002, Request RTT 23 Average Request RTT 25
2019-12-08 21:38:21.269 Detail,   Expected callbackId was received
2019-12-08 21:38:21.269 Detail,   Expected reply was received
2019-12-08 21:38:21.269 Detail,   Message transaction complete
2019-12-08 21:38:21.269 Detail, Node002, Removing current message
2019-12-08 21:38:21.269 Info, Node002, Sending (Send) message (Callback ID=0x36, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x26, 0x02, 0x25, 0x36, 0xd2
2019-12-08 21:38:21.277 Detail, Node002,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-12-08 21:38:21.277 Detail, Node002,   ZW_SEND_DATA delivered to Z-Wave stack
2019-12-08 21:38:21.293 Detail, Node002,   Received: 0x01, 0x07, 0x00, 0x13, 0x36, 0x00, 0x00, 0x02, 0xdf
2019-12-08 21:38:21.293 Detail, Node002,   ZW_SEND_DATA Request with callback ID 0x36 received (expected 0x36)
2019-12-08 21:38:21.293 Info, Node002, Request RTT 23 Average Request RTT 24
2019-12-08 21:38:21.293 Detail,   Expected callbackId was received
2019-12-08 21:38:31.270 Error, Node002, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-12-08 21:38:31.270 Detail, Node002, Removing current message
2019-12-08 21:38:31.270 Detail, Node002, Notification: Notification - TimeOut
Thanks!
