I recently upgraded to 0.116.4 running in a docker container. My prior version was running on a Pi3 @ vers ~ 0.8 or so. I have a Trane Zwave thermostat (TZEMT524AA21MA) that worked fine on the previous install. HA would expose it as 4 separate entities but now in the latest version HA exposes a sensor and a mode entity. The sensor reports the thermostat temperature correctly, but the mode entity card is unresponsive.
I’m not sure how to fix this, any help appreciated.
Thanks for the reply. I’ve tried excluding and re-enrolling in the z-wave network a few times. I thought maybe Since it would report the temperature correctly but the mode control/temperature settings were grayed out in the UI that maybe it needed to be added as a secure node, but that didn’t seem to work either.
Maybe try exclude then reboot HA and power cycle thermostat then readd to zwave.
Secure note is not necessary
I had a similar issue with the new unit after I purchased it… I ultimately return that unit.
Ultimately though it should be working without issue
EDIT
I also have this issue after my Z-Wave network failed due to power outage… In this case I just started from scratch rebuilding entire z-wave network by resetting Z-Wave stick and re-pairing all devices
