Z-wave configuration takes more than 2 hours and no results
I did a reset of my ZWAVE.ME usb stick with Z-WAVE PC controller 5 and than i added all the devices.
I did a new integration of Z-wave in HA with the ZWAVE stick in the Raspberry . After that I did “start netwerk” and he is still busy. Strange.
logging
´´020-12-02 19:15:42.223 Always, OpenZwave Version 1.4.3469 Starting Up
´ù2020-12-02 19:15:53.550 Info, Setting Up Provided Network Key for Secure Communications
2020-12-02 19:15:53.550 Info, mgr, Added driver for controller /dev/ttyAMA0
2020-12-02 19:15:53.550 Info, Opening controller /dev/ttyAMA0
2020-12-02 19:15:53.553 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-12-02 19:15:53.553 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-12-02 19:15:53.554 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-12-02 19:15:53.555 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-12-02 19:15:53.555 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-12-02 19:15:53.555 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-12-02 19:15:53.555 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-12-02 19:15:53.555 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-12-02 19:15:53.556 Detail, contrlr, Notification: DriverFailed
2020-12-02 19:20:21.535 Error, Options have been locked. No more may be added.
2020-12-02 19:20:21.536 Error, Options have been locked. No more may be added.
2020-12-02 19:20:21.538 Error, Options are already final (locked).
2020-12-02 19:20:27.876 Info, mgr, Cannot add driver for controller /dev/ttyAMA0 - driver already exists
