I’ve been searching with no luck… I have seen screenshots people have posted of their z-wave connection graph but I can’t find out how to display it on my UI. I have the Z-Wave JS integration. Do I need some other add-on as well?
You need to use the zwave-js addon. See also Z-Wave JS UI I read in the description the following:
- Network Graph: Provides a beautiful map showing how nodes are communicating with the controller
Thanks. If I manage to stop it giving me errors and start working I’ll come back and mark your post as solution.
Later: actually having looked into it further I think this is something that could cause problems where I currently have none, I just wanted to look at the graph out of curiosity. So I’ll pass. But I’ve marked your post as it might help others.
You cannot run the standard Z-wave and the Z-Wave-JS addon at the same time. If you want to run JS you need to stop the other one and visa versa. Hope this helps.
Oh right, yeah I don’t really want to invite the extra hassle, fortunately my z-wave devices are connected and working fine as they are
