Good day all,
Sorry for bringing this up yet again… however I’ve tried many things and now I’m at a loss. I started with the Aeotec ZW090 Z-Stick Gen5 USB controller. I’m attempting to control a Kwikset Smartlock914. I installed the Z-wave device and paired it with the SmartLock, had some problems then went back to exclude it from the z-wave and attempted to re-include it with Z-wave controller but to no avail. What ever I try I see the following:
and now Hassio can see node 2 but that’ about it. I’m also including the OZW_Log file for some help.
2019-02-02 15:42:20.740 Always, OpenZwave Version 1.4.3322 Starting Up
2019-02-02 15:42:23.329 Info, Setting Up Provided Network Key for Secure Communications
2019-02-02 15:42:23.329 Warning, Failed - Network Key Not Set
2019-02-02 15:42:23.329 Info, mgr, Added driver for controller /dev/ttyACM0
2019-02-02 15:42:23.329 Info, Opening controller /dev/ttyACM0
2019-02-02 15:42:23.329 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2019-02-02 15:42:23.331 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2019-02-02 15:42:23.334 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-02-02 15:42:23.334 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-02-02 15:42:23.334 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-02-02 15:42:23.334 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-02-02 15:42:23.334 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-02-02 15:42:23.335 Detail,
2019-02-02 15:42:23.335 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-02-02 15:42:23.339 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2019-02-02 15:42:23.339 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2019-02-02 15:42:23.339 Info, contrlr, Static Controller library, version Z-Wave 4.54
2019-02-02 15:42:23.339 Detail, Node045, Expected reply was received
2019-02-02 15:42:23.340 Detail, Node045, Message transaction complete
2019-02-02 15:42:23.340 Detail, contrlr, Removing current message
2019-02-02 15:42:23.340 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-02-02 15:42:23.342 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xc7, 0x87, 0x0e, 0x8f, 0x01, 0x16
2019-02-02 15:42:23.343 Detail,
2019-02-02 15:42:23.343 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xc7870e8f. Our node ID = 1
2019-02-02 15:42:23.343 Detail, Node135, Expected reply was received
2019-02-02 15:42:23.343 Detail, Node135, Message transaction complete
2019-02-02 15:42:23.343 Detail, contrlr, Removing current message
2019-02-02 15:42:23.344 Detail,
2019-02-02 15:42:23.344 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-02-02 15:42:23.347 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2019-02-02 15:42:23.347 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2019-02-02 15:42:23.347 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2019-02-02 15:42:23.347 Info, contrlr, The PC controller is a primary controller.
2019-02-02 15:42:23.347 Detail, Node247, Expected reply was received
2019-02-02 15:42:23.348 Detail, Node247, Message transaction complete
2019-02-02 15:42:23.348 Detail, contrlr, Removing current message
2019-02-02 15:42:23.348 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-02-02 15:42:23.357 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x01, 0x00, 0x86, 0x01, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfb
2019-02-02 15:42:23.357 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2019-02-02 15:42:23.358 Info, contrlr, Serial API Version: 1.1
2019-02-02 15:42:23.358 Info, contrlr, Manufacturer ID: 0x0086
2019-02-02 15:42:23.358 Info, contrlr, Product Type: 0x0101
2019-02-02 15:42:23.358 Info, contrlr, Product ID: 0x005a
2019-02-02 15:42:23.358 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2019-02-02 15:42:23.358 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2019-02-02 15:42:23.358 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2019-02-02 15:42:23.359 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2019-02-02 15:42:23.359 Detail, Node001, Expected reply was received
2019-02-02 15:42:23.359 Detail, Node001, Message transaction complete
2019-02-02 15:42:23.359 Detail, contrlr, Removing current message
2019-02-02 15:42:23.359 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-02-02 15:42:23.365 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2019-02-02 15:42:23.366 Detail,
2019-02-02 15:42:23.366 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2019-02-02 15:42:23.366 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2019-02-02 15:42:23.366 Detail, Node172, Expected reply was received
2019-02-02 15:42:23.366 Detail, Node172, Message transaction complete
2019-02-02 15:42:23.366 Detail, contrlr, Removing current message
2019-02-02 15:42:23.366 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2019-02-02 15:42:23.422 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x6f, 0x51, 0x50, 0xaa, 0x32, 0x74, 0x34, 0xdb, 0x22, 0x50, 0x2e, 0x48, 0x08, 0xec, 0x44, 0xb8, 0x3a, 0xc7, 0xfb, 0x14, 0x7f, 0x20, 0x16, 0xb0, 0x63, 0x7b, 0x7f, 0x4e, 0x4e, 0x2d, 0x21, 0xa4, 0xa3
2019-02-02 15:42:23.423 Detail,
2019-02-02 15:42:23.423 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2019-02-02 15:42:23.423 Detail, Node032, Expected reply was received
2019-02-02 15:42:23.423 Detail, Node032, Message transaction complete
2019-02-02 15:42:23.423 Detail, contrlr, Removing current message
2019-02-02 15:42:23.423 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2019-02-02 15:42:23.527 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc7
2019-02-02 15:42:23.528 Detail,
2019-02-02 15:42:23.528 Info, mgr, Driver with Home ID of 0xc7870e8f is now ready.
2019-02-02 15:42:23.555 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2019-02-02 15:42:23.555 Info, contrlr, Node 001 - Known
2019-02-02 15:42:23.555 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2019-02-02 15:42:23.556 Detail, Node001, QueryStage_CacheLoad
2019-02-02 15:42:23.556 Info, Node001, Node Identity Codes: 0086:0101:005a
2019-02-02 15:42:23.556 Detail, Node001, QueryStage_Associations
2019-02-02 15:42:23.556 Detail, Node001, QueryStage_Neighbors
2019-02-02 15:42:23.556 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2019-02-02 15:42:23.556 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2019-02-02 15:42:23.556 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2019-02-02 15:42:23.556 Info, contrlr, Node 002 - Known
2019-02-02 15:42:23.556 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2019-02-02 15:42:23.556 Detail, Node002, QueryStage_Probe
2019-02-02 15:42:23.556 Info, Node002, NoOperation::Set - Routing=true
2019-02-02 15:42:23.556 Detail, Node002, Queuing (NoOp) NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xca
2019-02-02 15:42:23.556 Detail, Node002, Queuing (Query) Query Stage Complete (Probe)
2019-02-02 15:42:23.556 Detail, Expected reply was received
2019-02-02 15:42:23.556 Detail, Message transaction complete
2019-02-02 15:42:23.556 Detail, contrlr, Removing current message
2019-02-02 15:42:23.557 Detail, Node001, Notification: DriverReady
2019-02-02 15:42:23.568 Detail, Node001, Notification: NodeAdded
2019-02-02 15:42:23.687 Detail, Node001, Notification: NodeProtocolInfo
2019-02-02 15:42:23.688 Detail, Node001, Notification: EssentialNodeQueriesComplete
2019-02-02 15:42:23.689 Detail, Node001, Notification: ValueAdded
2019-02-02 15:42:23.690 Detail, Node001, Notification: NodeNaming
2019-02-02 15:42:23.691 Detail, Node002, Notification: NodeAdded
2019-02-02 15:42:23.694 Detail, Node002, Notification: NodeProtocolInfo
2019-02-02 15:42:23.696 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.700 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.704 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.726 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.728 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.733 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.740 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.743 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.750 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.752 Detail, Node002, Notification: ValueAdded
2019-02-02 15:42:23.753 Detail,
2019-02-02 15:42:23.753 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2019-02-02 15:42:23.755 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x96, 0x0f, 0x64
2019-02-02 15:42:23.755 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2019-02-02 15:42:23.755 Detail, Node015, Expected reply was received
2019-02-02 15:42:23.755 Detail, Node015, Message transaction complete
2019-02-02 15:42:23.755 Detail, contrlr, Removing current message
2019-02-02 15:42:23.756 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2019-02-02 15:42:23.758 Detail, contrlr, Removing current message
2019-02-02 15:42:23.758 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2019-02-02 15:42:23.767 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5c
2019-02-02 15:42:23.767 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2019-02-02 15:42:23.767 Info, Node001, Neighbors of this node are:
2019-02-02 15:42:23.767 Info, Node001, Node 2
2019-02-02 15:42:23.767 Detail, Expected reply was received
2019-02-02 15:42:23.767 Detail, Message transaction complete
2019-02-02 15:42:23.767 Detail, Node001, Removing current message
2019-02-02 15:42:23.767 Info, Node002, Sending (NoOp) message (Callback ID=0x0a, Expected Reply=0x13) - NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xca
2019-02-02 15:42:23.778 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-02 15:42:23.778 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-02 15:42:27.307 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x0a, 0x01, 0x01, 0x61, 0x80
2019-02-02 15:42:27.307 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2019-02-02 15:42:27.307 Info, Node002, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2019-02-02 15:42:27.307 Warning, Node002, WARNING: Device is not a sleeping node.
2019-02-02 15:42:27.308 Info, Node002, QueryStageRetry stage Probe requested stage Probe max 3 retries 0 pending 1
2019-02-02 15:42:27.308 Detail, Node001, Expected callbackId was received
2019-02-02 15:42:27.308 Detail, Node001, Expected reply was received
2019-02-02 15:42:27.308 Detail, Node001, Message transaction complete
2019-02-02 15:42:27.308 Detail, Node002, Removing current message
2019-02-02 15:42:27.308 Detail, Node002, Notification: Notification - NoOperation
2019-02-02 15:42:27.312 Detail, Node001, Query Stage Complete (Neighbors)
2019-02-02 15:42:27.312 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2019-02-02 15:42:27.312 Detail, Node001, QueryStage_Session
2019-02-02 15:42:27.312 Detail, Node001, QueryStage_Dynamic
2019-02-02 15:42:27.312 Detail, Node001, QueryStage_Configuration
2019-02-02 15:42:27.312 Detail, Node001, QueryStage_Complete
2019-02-02 15:42:27.312 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2019-02-02 15:42:27.312 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=1
2019-02-02 15:42:27.312 Info, Node query processing complete except for sleeping nodes.
2019-02-02 15:42:27.313 Detail, Node001, Notification: NodeQueriesComplete
2019-02-02 15:42:27.319 Detail, contrlr, Notification: AwakeNodesQueried
2019-02-02 15:42:27.335 Detail, Node002, Query Stage Complete (Probe)
2019-02-02 15:42:27.335 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=1 queryStage=Probe live=1
2019-02-02 15:42:27.336 Detail, Node002, QueryStage_Probe
2019-02-02 15:42:27.336 Info, Node002, NoOperation::Set - Routing=true
2019-02-02 15:42:27.336 Detail, Node002, Queuing (NoOp) NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xcb
2019-02-02 15:42:27.336 Detail, Node002, Queuing (Query) Query Stage Complete (Probe)
2019-02-02 15:42:27.336 Info, Node002, Sending (NoOp) message (Callback ID=0x0b, Expected Reply=0x13) - NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xcb
2019-02-02 15:42:27.347 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-02 15:42:27.347 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-02 15:42:30.846 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x0b, 0x01, 0x01, 0x5f, 0xbf
2019-02-02 15:42:30.846 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2019-02-02 15:42:30.846 Info, Node002, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2019-02-02 15:42:30.846 Warning, Node002, WARNING: Device is not a sleeping node.
2019-02-02 15:42:30.846 Info, Node002, QueryStageRetry stage Probe requested stage Probe max 3 retries 1 pending 1
2019-02-02 15:42:30.846 Detail, Node001, Expected callbackId was received
2019-02-02 15:42:30.846 Detail, Node001, Expected reply was received
2019-02-02 15:42:30.847 Detail, Node001, Message transaction complete
2019-02-02 15:42:30.847 Detail, Node002, Removing current message
2019-02-02 15:42:30.847 Detail, Node002, Notification: Notification - NoOperation
2019-02-02 15:42:30.855 Detail, Node002, Query Stage Complete (Probe)
2019-02-02 15:42:30.855 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=2 queryStage=Probe live=1
2019-02-02 15:42:30.855 Detail, Node002, QueryStage_Probe
2019-02-02 15:42:30.860 Info, Node002, NoOperation::Set - Routing=true
2019-02-02 15:42:30.860 Detail, Node002, Queuing (NoOp) NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0c, 0xcc
2019-02-02 15:42:30.860 Detail, Node002, Queuing (Query) Query Stage Complete (Probe)
2019-02-02 15:42:30.860 Info, Node002, Sending (NoOp) message (Callback ID=0x0c, Expected Reply=0x13) - NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0c, 0xcc
2019-02-02 15:42:30.871 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-02-02 15:42:30.871 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2019-02-02 15:42:34.340 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0x0c, 0x01, 0x01, 0x5b, 0xbc
2019-02-02 15:42:34.340 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2019-02-02 15:42:34.340 Info, Node002, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2019-02-02 15:42:34.340 Warning, Node002, WARNING: Device is not a sleeping node.
2019-02-02 15:42:34.340 Error, Node002, ERROR: node presumed dead
2019-02-02 15:42:34.340 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=1
2019-02-02 15:42:34.340 Warning, CheckCompletedNodeQueries all=1, deadFound=1 sleepingOnly=1
2019-02-02 15:42:34.340 Info, Node query processing complete except for dead nodes.
2019-02-02 15:42:34.340 Info, Node002, QueryStageRetry stage Probe requested stage Probe max 3 retries 2 pending 1
2019-02-02 15:42:34.340 Detail, Node001, Expected callbackId was received
2019-02-02 15:42:34.340 Detail, Node001, Expected reply was received
2019-02-02 15:42:34.341 Detail, Node001, Message transaction complete
2019-02-02 15:42:34.341 Detail, Node002, Removing current message
2019-02-02 15:42:34.341 Detail, Node002, Notification: Notification - NoOperation
2019-02-02 15:42:34.343 Detail, contrlr, Notification: AllNodesQueriedSomeDead
2019-02-02 15:42:34.344 Detail, Node002, Notification: Notification - Node Dead
2019-02-02 15:42:34.349 Detail, Node002, Query Stage Complete (Probe)
2019-02-02 15:42:34.349 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=0
I appreciate any and all comments/help!
Happy Saturday!
