I have a switch that is constantly sending data and the counter for commandsRX is very high. The network is under heavy load and sometimes fails to get status of other sensors.
Is this a failed device or did I do something wrong with the parameters?
Any other ideas?
I am using zwavejs2mqtt and a zwave.me UZB1 Stick.
PARAMETER
9
State After Power Failure
Previous state
PARAMETER
10
First Channel - Operating Mode
Standard
PARAMETER
11
First Channel - Reaction to Key S1 for Delay/Auto ON/OFF Modes
Cancel and set target state
PARAMETER
12
First Channel - Time Parameter for Delay/Auto ON/OFF Modes
PARAMETER
15
Second Channel - Operating Mode
Standard
PARAMETER
16
Second Channel - Reaction to Key S2 for Delay/Auto ON/OFF Modes
PARAMETER
17
Second Channel - Time Parameter for Delay/Auto ON/OFF Modes
PARAMETER
18
Second Channel - Pulse Time for Blink Mode
PARAMETER
20
Input Button/Switch Configuration
Switch (status changes when switch change)
PARAMETER
21
Report During Blink Mode
PARAMETER
27
Send Secure Commands to 2nd Association Group
Only active when the node is included securely
PARAMETER
27
Send Secure Commands to 3rd Association Group
PARAMETER
27
Send Secure Commands to 4th Association Group
PARAMETER
27
Send Secure Commands to 5th Association Group
PARAMETER
28
Key S1: Send Scenes When Pressed 1 Time
PARAMETER
28
Key S1: Send Scenes When Pressed 2 Times
PARAMETER
28
Key S1: Send Scenes When Pressed 3 Times
PARAMETER
28
Key S1: Send Scenes When Held Down and Released
PARAMETER
29
Key S2: Send Scenes When Pressed 1 Time
PARAMETER
29
Key S2: Send Scenes When Pressed 2 Times
PARAMETER
29
Key S2: Send Scenes When Pressed 3 Times
PARAMETER
29
Key S2: Send Scenes When Held Down and Released
PARAMETER
30
Key S1 Associations: Send ON With Single Click
Enable
PARAMETER
30
Key S1 Associations: Send OFF With Single Click
Enable
PARAMETER
30
Key S1 Associations: Send When Holding and Releasing
Reuqires Key S1 to be configured as momentary
Enable
PARAMETER
30
Key S1 Associations: Send When Double Clicking
Reuqires Key S1 to be configured as momentary or to change each time input changes
Enable
PARAMETER
31
Key S1 Associations: Switch ON Value Sent
PARAMETER
32
Key S1 Associations: Switch OFF Value Sent
PARAMETER
33
Key S1 Associations: Double Click Value Sent
PARAMETER
35
Key S2 Associations: Send ON With Single Click
Enable
PARAMETER
35
Key S2 Associations: Send OFF With Single Click
Enable
PARAMETER
35
Key S2 Associations: Send When Holding and Releasing
Requires Key S2 to be configured as momentary
Enable
PARAMETER
35
Key S2 Associations: Send When Double Clicking
Requires Key S2 to be configured as momentary or to change each time input changes
Enable
PARAMETER
36
Key S2 Associations: Switch ON Value Sent
PARAMETER
37
Key S2 Associations: Switch OFF Value Sent
PARAMETER
38
Key S2 Associations: Double Click Value Sent
PARAMETER
40
General Purpose Alarm Response
Blink load
PARAMETER
41
Water Flood Alarm Response
Turn off load
PARAMETER
42
Smoke, CO or CO2 Alarm Response
Blink load
PARAMETER
43
Temperature Alarm Response
Turn on load
PARAMETER
44
Time of Alarm State
PARAMETER
50
First Channel - Power Reports: Threshold
PARAMETER
51
First Channel - Power Reports: Minimum Time Between Reports
PARAMETER
53
First Channel - Energy Reports: Threshold
PARAMETER
54
Second Channel - Power Reports: Threshold
PARAMETER
55
Second Channel - Power Reports: Minimum Time Between Reports
PARAMETER
57
Second Channel - Energy Reports: Threshold
PARAMETER
58
Periodic Active Power Reports
PARAMETER
59
Periodic Energy Reports
PARAMETER
60
Include Consumption By Device Itself in Reports
If enabled, it will be included in the reports for the first channel
PARAMETER
13
First Channel - Pulse Time for Blink Mode
