Hi there,
Running a good working zwave network for quite some time now. Today I added a GreenWave PowerNode 6 device. I know they can be a pita, but I had them working in Domoticz for a long time. They needed polling though for getting consumption reports.
Anyway, added it without problems. OZWCP and logs shows it reporting instantly if I push the connect button and the xml file has all command classes and states. Unfortunately HA is not showing all sensors. And this is something I don’t understand. As I understood HA loads all sensors from the xml file (and then from the controller). HA shows a few (listing them as I have configured them in customize, polling is at 60000 btw):
switch.gw_powernode_1_switch_19_0:
polling_intensity: 1
sensor.gw_powernode_1_energy_19_0:
sensor.gw_powernode_1_power_19_8:
sensor.gw_powernode_1_previous_reading_19_1:
hidden: true
sensor.gw_powernode_1_previous_reading_19_9:
hidden: true
Looking at the zwave logs, I see the controller receiving every switch and sensor available. The sensors HA is showing look to me like they’re the “root” switches/sensors, and not the “slave” sensors for the 6 ports. Command classes in the xml file show this:
<Node id="19" name="GW PowerNode 1" location="" basic="4" generic="16" specific="1" type="Binary Power Switch" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete">
<Manufacturer id="99" name="GreenWave">
<Product type="3" id="4" name="PowerNode 6 port" />
</Manufacturer>
<CommandClasses>
<CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="5" innif="true" mapping="37">
<Instance index="1" endpoint="1" />
<Instance index="2" endpoint="2" />
<Instance index="3" endpoint="3" />
<Instance index="4" endpoint="4" />
<Instance index="5" endpoint="5" />
<Instance index="6" endpoint="6" />
</CommandClass>
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="5" innif="true">
<Value type="bool" genre="user" instance="1" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="bool" genre="user" instance="2" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="bool" genre="user" instance="3" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="bool" genre="user" instance="4" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="bool" genre="user" instance="5" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
<Value type="bool" genre="user" instance="6" index="0" label="Switch" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="True" />
</CommandClass>
<CommandClass id="39" name="COMMAND_CLASS_SWITCH_ALL" version="1" request_flags="5" innif="true">
<Instance index="1" />
<Value type="list" genre="system" instance="1" index="0" label="Switch All" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="3" size="1">
<Item label="Disabled" value="0" />
<Item label="Off Enabled" value="1" />
<Item label="On Enabled" value="2" />
<Item label="On and Off Enabled" value="255" />
</Value>
</CommandClass>
<CommandClass id="50" name="COMMAND_CLASS_METER" version="2" request_flags="3" innif="true">
<Value type="decimal" genre="user" instance="1" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="32.8930" />
<Value type="decimal" genre="user" instance="1" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="32.8930" />
<Value type="int" genre="user" instance="1" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="decimal" genre="user" instance="1" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="2.9" />
<Value type="decimal" genre="user" instance="1" index="9" label="Previous Reading" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="2.9" />
<Value type="int" genre="user" instance="1" index="10" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="bool" genre="user" instance="1" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="1" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="decimal" genre="user" instance="2" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.2484" />
<Value type="decimal" genre="user" instance="2" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.2484" />
<Value type="int" genre="user" instance="2" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="decimal" genre="user" instance="2" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="2.0" />
<Value type="decimal" genre="user" instance="2" index="9" label="Previous Reading" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="2.0" />
<Value type="int" genre="user" instance="2" index="10" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="bool" genre="user" instance="2" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="2" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="decimal" genre="user" instance="3" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="2.3642" />
<Value type="decimal" genre="user" instance="3" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="2.3642" />
<Value type="int" genre="user" instance="3" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="decimal" genre="user" instance="3" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.0" />
<Value type="decimal" genre="user" instance="3" index="9" label="Previous Reading" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.0" />
<Value type="int" genre="user" instance="3" index="10" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="bool" genre="user" instance="3" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="3" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="decimal" genre="user" instance="4" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.5267" />
<Value type="decimal" genre="user" instance="4" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="1.5267" />
<Value type="int" genre="user" instance="4" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="decimal" genre="user" instance="4" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.7" />
<Value type="decimal" genre="user" instance="4" index="9" label="Previous Reading" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.7" />
<Value type="int" genre="user" instance="4" index="10" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="bool" genre="user" instance="4" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="4" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="decimal" genre="user" instance="5" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="8.9909" />
<Value type="decimal" genre="user" instance="5" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="8.9909" />
<Value type="int" genre="user" instance="5" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="decimal" genre="user" instance="5" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="12.6" />
<Value type="decimal" genre="user" instance="5" index="9" label="Previous Reading" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="12.6" />
<Value type="int" genre="user" instance="5" index="10" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="bool" genre="user" instance="5" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="5" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
<Value type="decimal" genre="user" instance="6" index="0" label="Energy" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="9.5761" />
<Value type="decimal" genre="user" instance="6" index="1" label="Previous Reading" units="kWh" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="9.5761" />
<Value type="int" genre="user" instance="6" index="2" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="decimal" genre="user" instance="6" index="8" label="Power" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.3" />
<Value type="decimal" genre="user" instance="6" index="9" label="Previous Reading" units="W" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="0.3" />
<Value type="int" genre="user" instance="6" index="10" label="Interval" units="seconds" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="-2147483648" max="2147483647" value="9" />
<Value type="bool" genre="user" instance="6" index="32" label="Exporting" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="False" />
<Value type="button" genre="system" instance="6" index="33" label="Reset" units="" read_only="false" write_only="true" verify_changes="false" poll_intensity="0" min="0" max="0" />
</CommandClass>
<CommandClass id="86" name="COMMAND_CLASS_CRC_16_ENCAP" version="1" request_flags="5" innif="true">
</CommandClass>
<CommandClass id="96" name="COMMAND_CLASS_MULTI_INSTANCE/CHANNEL" version="2" request_flags="1" innif="true" mapping="endpoints">
</CommandClass>
<CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="5" innif="true">
<Value type="byte" genre="config" instance="1" index="0" label="Power delta" units="%" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="100" value="10">
<Help>Consumer variation required to send notification. From 1 to 100, default 10</Help>
</Value>
<Value type="byte" genre="config" instance="1" index="1" label="No communication light" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="255" value="255">
<Help>After how many minutes the GreenWave device should start flashing if the controller didn't communicate with this device</Help>
</Value>
<Value type="list" genre="config" instance="1" index="2" label="Room color" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1">
<Help>The room color (Corner wheel color) on the GreenWave device</Help>
<Item label="Black (empty)" value="128" />
<Item label="Green (1)" value="129" />
<Item label="Dark Blue (2)" value="130" />
<Item label="Red (3)" value="131" />
<Item label="Yellow (4)" value="132" />
<Item label="Purple (5)" value="133" />
<Item label="Orange (6)" value="134" />
<Item label="Light Blue (7)" value="135" />
<Item label="Pink (8)" value="136" />
<Item label="Locked" value="137" />
</Value>
<Value type="list" genre="config" instance="1" index="3" label="Power on relay" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="2" vindex="2" size="1">
<Help>Relais state after a power loss</Help>
<Item label="All OFF" value="0" />
<Item label="Remember last state" value="1" />
<Item label="All ON" value="2" />
</Value>
<Value type="list" genre="config" instance="1" index="4" label="LED on network error" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="1" vindex="1" size="1">
<Help>Enable/Disable the LED on network error</Help>
<Item label="Disable" value="0" />
<Item label="Enable" value="1" />
</Value>
</CommandClass>
<CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="5" innif="true">
</CommandClass>
<CommandClass id="117" name="COMMAND_CLASS_PROTECTION" version="1" request_flags="5" innif="true">
<Value type="list" genre="system" instance="1" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
<Item label="Unprotected" value="0" />
<Item label="Protection by Sequence" value="1" />
<Item label="No Operation Possible" value="2" />
</Value>
<Value type="list" genre="system" instance="2" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="list" genre="system" instance="3" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="list" genre="system" instance="4" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="list" genre="system" instance="5" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
<Value type="list" genre="system" instance="6" index="0" label="Protection" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1">
</Value>
</CommandClass>
<CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="1" request_flags="5" innif="true">
<Associations num_groups="4">
<Group index="1" max_associations="1" label="Wheel" auto="true">
<Node id="1" />
</Group>
<Group index="2" max_associations="1" label="Relay health" auto="false" />
<Group index="3" max_associations="1" label="Power level" auto="false" />
<Group index="4" max_associations="1" label="Overcurrent protection" auto="false" />
</Associations>
</CommandClass>
<CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="5" innif="true">
<Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" />
<Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.33" />
<Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="4.21" />
</CommandClass>
</CommandClasses>
</Node>
Not sure how to go from here as zwave seems to be working fine (logs show good communication) but HA doesn’t pick up the sensors. Normally when I add a zwave device if it shows up in OZWCP and zwave has clean logs, HA picks them up automatically in states. After that I start using the entities in states in customize.
Has anyone seen this behavior before?
/edit
To be honest, I’m still at 33.1 unfortunately. Waiting for influxdb changes, have to migrate data I think and not looking forward to doing that twice. Upgrading > 34.0 breaks the current influxdb integration for me.
