This should have one reboot where everything came up dead, and a subsequent reboot where one node came up alive.
2018-05-26 20:33:56.698 Always, OpenZwave Version 1.4.2926 Starting Up
2018-05-26 20:33:58.635 Info, Setting Up Provided Network Key for Secure Communications
2018-05-26 20:33:58.642 Info, mgr, Added driver for controller /dev/ttyS0
2018-05-26 20:33:58.642 Info, Opening controller /dev/ttyS0
2018-05-26 20:33:58.642 Info, Trying to open serial port /dev/ttyS0 (attempt 1)
2018-05-26 20:33:58.642 Info, Serial port /dev/ttyS0 opened (attempt 1)
2018-05-26 20:33:58.643 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-05-26 20:33:58.643 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-05-26 20:33:58.643 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-05-26 20:33:58.643 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-05-26 20:33:58.643 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-05-26 20:33:58.643 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2018-05-26 20:33:58.646 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x30, 0x35, 0x00, 0x01, 0x97
2018-05-26 20:33:58.646 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2018-05-26 20:33:58.646 Info, contrlr, Static Controller library, version Z-Wave 4.05
2018-05-26 20:33:58.646 Detail, Node045, Expected reply was received
2018-05-26 20:33:58.646 Detail, Node045, Message transaction complete
2018-05-26 20:33:58.646 Detail, contrlr, Removing current message
2018-05-26 20:33:58.647 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2018-05-26 20:33:58.649 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xcf, 0x1a, 0x77, 0x16, 0x01, 0x63
2018-05-26 20:33:58.649 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xcf1a7716. Our node ID = 1
2018-05-26 20:33:58.649 Detail, Node026, Expected reply was received
2018-05-26 20:33:58.649 Detail, Node026, Message transaction complete
2018-05-26 20:33:58.649 Detail, contrlr, Removing current message
2018-05-26 20:33:58.649 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-05-26 20:33:58.650 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2018-05-26 20:33:58.651 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2018-05-26 20:33:58.651 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2018-05-26 20:33:58.651 Info, contrlr, The PC controller is a primary controller.
2018-05-26 20:33:58.651 Detail, Node247, Expected reply was received
2018-05-26 20:33:58.651 Detail, Node247, Message transaction complete
2018-05-26 20:33:58.651 Detail, contrlr, Removing current message
2018-05-26 20:33:58.651 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-05-26 20:33:58.656 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x05, 0x04, 0x01, 0x47, 0x04, 0x00, 0x00, 0x02, 0xfe, 0x83, 0xff, 0x88, 0xcf, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x80, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x40, 0x1a, 0x00, 0x5e
2018-05-26 20:33:58.656 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2018-05-26 20:33:58.656 Info, contrlr, Serial API Version: 5.4
2018-05-26 20:33:58.656 Info, contrlr, Manufacturer ID: 0x0147
2018-05-26 20:33:58.656 Info, contrlr, Product Type: 0x0400
2018-05-26 20:33:58.657 Info, contrlr, Product ID: 0x0002
2018-05-26 20:33:58.657 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2018-05-26 20:33:58.657 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2018-05-26 20:33:58.657 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2018-05-26 20:33:58.657 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2018-05-26 20:33:58.657 Detail, Node004, Expected reply was received
2018-05-26 20:33:58.657 Detail, Node004, Message transaction complete
2018-05-26 20:33:58.657 Detail, contrlr, Removing current message
2018-05-26 20:33:58.657 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-05-26 20:33:58.659 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2018-05-26 20:33:58.659 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2018-05-26 20:33:58.659 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2018-05-26 20:33:58.659 Detail, Node172, Expected reply was received
2018-05-26 20:33:58.659 Detail, Node172, Message transaction complete
2018-05-26 20:33:58.659 Detail, contrlr, Removing current message
2018-05-26 20:33:58.659 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2018-05-26 20:33:58.712 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x9f, 0x0d, 0x3d, 0x08, 0xc4, 0xc6, 0x45, 0x50, 0x3e, 0x90, 0x87, 0xee, 0x6a, 0xce, 0xcc, 0x18, 0x1e, 0x70, 0xab, 0xa8, 0xd2, 0xae, 0x23, 0x60, 0xa9, 0xef, 0x06, 0xa1, 0x16, 0xa3, 0x9d, 0x7a, 0x00
2018-05-26 20:33:58.712 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2018-05-26 20:33:58.712 Detail, Node032, Expected reply was received
2018-05-26 20:33:58.712 Detail, Node032, Message transaction complete
2018-05-26 20:33:58.712 Detail, contrlr, Removing current message
2018-05-26 20:33:58.713 Detail,
2018-05-26 20:33:58.713 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2018-05-26 20:33:58.772 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x39, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xfd
2018-05-26 20:33:58.772 Info, mgr, Driver with Home ID of 0xcf1a7716 is now ready.
2018-05-26 20:33:58.791 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2018-05-26 20:33:58.791 Info, contrlr, Node 001 - Known
2018-05-26 20:33:58.791 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2018-05-26 20:33:58.791 Detail, Node001, QueryStage_CacheLoad
2018-05-26 20:33:58.791 Info, Node001, Node Identity Codes: 0147:0400:0002
2018-05-26 20:33:58.791 Detail, Node001, QueryStage_Associations
2018-05-26 20:33:58.791 Detail, Node001, QueryStage_Neighbors
2018-05-26 20:33:58.791 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2018-05-26 20:33:58.792 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2018-05-26 20:33:58.792 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2018-05-26 20:33:58.792 Info, contrlr, Node 004 - Known
2018-05-26 20:33:58.792 Detail, Node004, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2018-05-26 20:33:58.792 Detail, Node004, QueryStage_CacheLoad
2018-05-26 20:33:58.792 Info, Node004, Node Identity Codes: 0000:0000:0000
2018-05-26 20:33:58.792 Info, Node004, NoOperation::Set - Routing=true
2018-05-26 20:33:58.792 Detail, Node004, Queuing (NoOp) NoOperation_Set (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xcc
2018-05-26 20:33:58.792 Detail, Node004, Queuing (Query) Query Stage Complete (CacheLoad)
2018-05-26 20:33:58.792 Info, contrlr, Node 005 - Known
2018-05-26 20:33:58.792 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2018-05-26 20:33:58.792 Detail, Node005, QueryStage_CacheLoad
2018-05-26 20:33:58.792 Info, Node005, Node Identity Codes: 0000:0000:0000
2018-05-26 20:33:58.792 Info, Node005, NoOperation::Set - Routing=true
2018-05-26 20:33:58.792 Detail, Node005, Queuing (NoOp) NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xcc
2018-05-26 20:33:58.792 Detail, Node005, Queuing (Query) Query Stage Complete (CacheLoad)
2018-05-26 20:33:58.792 Info, contrlr, Node 006 - Known
2018-05-26 20:33:58.792 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2018-05-26 20:33:58.792 Detail, Node006, QueryStage_CacheLoad
2018-05-26 20:33:58.792 Info, Node006, Node Identity Codes: 001d:0602:0334
2018-05-26 20:33:58.792 Info, Node006, NoOperation::Set - Routing=true
2018-05-26 20:33:58.792 Detail, Node006, Queuing (NoOp) NoOperation_Set (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x00, 0x00, 0x25, 0x0c, 0xc8
2018-05-26 20:33:58.793 Detail, Node006, Queuing (Query) Query Stage Complete (CacheLoad)
2018-05-26 20:33:58.793 Detail, Expected reply was received
2018-05-26 20:33:58.793 Detail, Message transaction complete
2018-05-26 20:33:58.793 Detail, contrlr, Removing current message
2018-05-26 20:33:58.793 Detail, Node001, Notification: DriverReady
-SNIP-
2018-05-26 20:33:58.963 Detail, Node006, Notification: ValueAdded
2018-05-26 20:33:58.967 Detail, Node006, Notification: NodeNaming
2018-05-26 20:33:58.969 Detail,
2018-05-26 20:33:58.969 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2018-05-26 20:33:58.970 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2018-05-26 20:33:58.971 Detail,
2018-05-26 20:33:58.971 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2018-05-26 20:33:58.971 Detail, Node015, Expected reply was received
2018-05-26 20:33:58.971 Detail, Node015, Message transaction complete
2018-05-26 20:33:58.971 Detail, contrlr, Removing current message
2018-05-26 20:33:58.971 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2018-05-26 20:33:58.972 Detail, contrlr, Removing current message
2018-05-26 20:33:58.972 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2018-05-26 20:33:58.977 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7e
2018-05-26 20:33:58.977 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2018-05-26 20:33:58.977 Info, Node001, Neighbors of this node are:
2018-05-26 20:33:58.977 Info, Node001, Node 6
2018-05-26 20:33:58.977 Detail, Expected reply was received
2018-05-26 20:33:58.977 Detail, Message transaction complete
2018-05-26 20:33:58.977 Detail, Node001, Removing current message
2018-05-26 20:33:58.978 Detail,
2018-05-26 20:33:58.978 Info, Node004, Sending (NoOp) message (Callback ID=0x0a, Expected Reply=0x13) - NoOperation_Set (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xcc
2018-05-26 20:33:59.042 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-26 20:33:59.042 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-26 20:34:10.133 Error, Node004, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-05-26 20:34:10.133 Detail, Node004, Removing current message
2018-05-26 20:34:10.133 Detail, Node004, Notification: Notification - TimeOut
2018-05-26 20:34:10.144 Detail,
2018-05-26 20:34:10.144 Info, Node005, Sending (NoOp) message (Callback ID=0x0b, Expected Reply=0x13) - NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xcc
2018-05-26 20:34:10.209 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-26 20:34:10.209 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-26 20:34:10.215 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x0b, 0x01, 0x00, 0x07, 0xe6
2018-05-26 20:34:10.215 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2018-05-26 20:34:10.215 Info, Node005, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2018-05-26 20:34:10.215 Warning, Node005, WARNING: Device is not a sleeping node.
2018-05-26 20:34:10.215 Info, Node005, QueryStageRetry stage CacheLoad requested stage CacheLoad max 3 retries 0 pending 1
2018-05-26 20:34:10.215 Detail, Node001, Expected callbackId was received
2018-05-26 20:34:10.215 Detail, Node001, Expected reply was received
2018-05-26 20:34:10.215 Detail, Node001, Message transaction complete
2018-05-26 20:34:10.215 Detail, Node005, Removing current message
2018-05-26 20:34:10.215 Detail, Node005, Notification: Notification - NoOperation
2018-05-26 20:34:10.217 Detail,
2018-05-26 20:34:10.217 Info, Node006, Sending (NoOp) message (Callback ID=0x0c, Expected Reply=0x13) - NoOperation_Set (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x00, 0x00, 0x25, 0x0c, 0xc8
2018-05-26 20:34:10.224 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-26 20:34:10.224 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-26 20:34:14.573 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x0c, 0x01, 0x01, 0xb3, 0x54
2018-05-26 20:34:14.573 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2018-05-26 20:34:14.573 Info, Node006, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2018-05-26 20:34:14.574 Warning, Node006, WARNING: Device is not a sleeping node.
2018-05-26 20:34:14.574 Info, Node006, QueryStageRetry stage CacheLoad requested stage CacheLoad max 3 retries 0 pending 1
2018-05-26 20:34:14.574 Detail, Node001, Expected callbackId was received
2018-05-26 20:34:14.574 Detail, Node001, Expected reply was received
2018-05-26 20:34:14.574 Detail, Node001, Message transaction complete
2018-05-26 20:34:14.574 Detail, Node006, Removing current message
2018-05-26 20:34:14.574 Detail, Node006, Notification: Notification - NoOperation
2018-05-26 20:34:14.577 Detail, Node001, Query Stage Complete (Neighbors)
2018-05-26 20:34:14.577 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2018-05-26 20:34:14.577 Detail, Node001, QueryStage_Session
2018-05-26 20:34:14.577 Detail, Node001, QueryStage_Dynamic
2018-05-26 20:34:14.577 Detail, Node001, QueryStage_Configuration
2018-05-26 20:34:14.577 Detail, Node001, QueryStage_Complete
2018-05-26 20:34:14.578 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2018-05-26 20:34:14.578 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=0
2018-05-26 20:34:14.578 Detail, Node001, Notification: NodeQueriesComplete
2018-05-26 20:34:14.580 Detail, Node004, Query Stage Complete (CacheLoad)
2018-05-26 20:34:14.580 Detail, Node004, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
2018-05-26 20:34:14.581 Detail, Node004, QueryStage_Associations
2018-05-26 20:34:14.581 Detail, Node004, QueryStage_Neighbors
2018-05-26 20:34:14.581 Detail, Requesting routing info (neighbor list) for Node 4
2018-05-26 20:34:14.581 Detail, Node004, Queuing (Command) Get Routing Info (Node=4): 0x01, 0x07, 0x00, 0x80, 0x04, 0x00, 0x00, 0x03, 0x7f
2018-05-26 20:34:14.581 Detail, Node004, Queuing (Query) Query Stage Complete (Neighbors)
2018-05-26 20:34:14.581 Info, Node004, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=4): 0x01, 0x07, 0x00, 0x80, 0x04, 0x00, 0x00, 0x03, 0x7f
2018-05-26 20:34:14.586 Detail, Node004, Received: 0x01, 0x20, 0x01, 0x80, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x6e
2018-05-26 20:34:14.587 Info, Node004, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2018-05-26 20:34:14.587 Info, Node004, Neighbors of this node are:
2018-05-26 20:34:14.587 Info, Node004, Node 5
2018-05-26 20:34:14.587 Info, Node004, Node 6
2018-05-26 20:34:14.587 Detail, Expected reply was received
2018-05-26 20:34:14.587 Detail, Message transaction complete
2018-05-26 20:34:14.587 Detail, Node004, Removing current message
2018-05-26 20:34:14.587 Detail, Node005, Query Stage Complete (CacheLoad)
2018-05-26 20:34:14.587 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=1 queryStage=CacheLoad live=1
2018-05-26 20:34:14.587 Detail, Node005, QueryStage_CacheLoad
2018-05-26 20:34:14.587 Info, Node005, Node Identity Codes: 0000:0000:0000
2018-05-26 20:34:14.588 Info, Node005, NoOperation::Set - Routing=true
2018-05-26 20:34:14.588 Detail, Node005, Queuing (NoOp) NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0d, 0xca
2018-05-26 20:34:14.588 Detail, Node005, Queuing (Query) Query Stage Complete (CacheLoad)
2018-05-26 20:34:14.588 Info, Node005, Sending (NoOp) message (Callback ID=0x0d, Expected Reply=0x13) - NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x0d, 0xca
2018-05-26 20:34:14.653 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-26 20:34:14.653 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-26 20:34:14.888 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x0d, 0x01, 0x00, 0x1e, 0xf9
2018-05-26 20:34:14.888 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x0d received (expected 0x0d)
2018-05-26 20:34:14.888 Info, Node005, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2018-05-26 20:34:14.888 Warning, Node005, WARNING: Device is not a sleeping node.
2018-05-26 20:34:14.888 Info, Node005, QueryStageRetry stage CacheLoad requested stage CacheLoad max 3 retries 1 pending 1
2018-05-26 20:34:14.888 Detail, Node001, Expected callbackId was received
2018-05-26 20:34:14.888 Detail, Node001, Expected reply was received
2018-05-26 20:34:14.889 Detail, Node001, Message transaction complete
2018-05-26 20:34:14.889 Detail, Node005, Removing current message
2018-05-26 20:34:14.889 Detail, Node005, Notification: Notification - NoOperation
2018-05-26 20:34:14.892 Detail, Node006, Query Stage Complete (CacheLoad)
2018-05-26 20:34:14.892 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=1 queryStage=CacheLoad live=1
2018-05-26 20:34:14.892 Detail, Node006, QueryStage_CacheLoad
2018-05-26 20:34:14.892 Info, Node006, Node Identity Codes: 001d:0602:0334
2018-05-26 20:34:14.892 Info, Node006, NoOperation::Set - Routing=true
2018-05-26 20:34:14.892 Detail, Node006, Queuing (NoOp) NoOperation_Set (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x00, 0x00, 0x25, 0x0e, 0xca
2018-05-26 20:34:14.892 Detail, Node006, Queuing (Query) Query Stage Complete (CacheLoad)
2018-05-26 20:34:14.892 Info, Node006, Sending (NoOp) message (Callback ID=0x0e, Expected Reply=0x13) - NoOperation_Set (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x00, 0x00, 0x25, 0x0e, 0xca
2018-05-26 20:34:14.900 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-26 20:34:14.900 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-26 20:34:18.971 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x0e, 0x01, 0x01, 0x98, 0x7d
2018-05-26 20:34:18.971 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x0e received (expected 0x0e)
2018-05-26 20:34:18.971 Info, Node006, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2018-05-26 20:34:18.972 Warning, Node006, WARNING: Device is not a sleeping node.
2018-05-26 20:34:18.972 Info, Node006, QueryStageRetry stage CacheLoad requested stage CacheLoad max 3 retries 1 pending 1
2018-05-26 20:34:18.972 Detail, Node001, Expected callbackId was received
2018-05-26 20:34:18.972 Detail, Node001, Expected reply was received
2018-05-26 20:34:18.972 Detail, Node001, Message transaction complete
2018-05-26 20:34:18.972 Detail, Node006, Removing current message
2018-05-26 20:34:18.972 Detail, Node006, Notification: Notification - NoOperation
2018-05-26 20:34:18.975 Detail, Node004, Query Stage Complete (Neighbors)
2018-05-26 20:34:18.975 Detail, Node004, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2018-05-26 20:34:18.975 Detail, Node004, QueryStage_Session
2018-05-26 20:34:18.976 Detail, Node004, Queuing (Query) SwitchAllCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x27, 0x02, 0x25, 0x0f, 0xec
2018-05-26 20:34:18.976 Detail, Node004, Queuing (Query) Query Stage Complete (Session)
2018-05-26 20:34:18.976 Detail, Node005, Query Stage Complete (CacheLoad)
2018-05-26 20:34:18.976 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=2 queryStage=CacheLoad live=1
2018-05-26 20:34:18.976 Detail, Node005, QueryStage_CacheLoad
2018-05-26 20:34:18.976 Info, Node005, Node Identity Codes: 0000:0000:0000
2018-05-26 20:34:18.976 Info, Node005, NoOperation::Set - Routing=true
2018-05-26 20:34:18.976 Detail, Node005, Queuing (NoOp) NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x10, 0xd7
2018-05-26 20:34:18.976 Detail, Node005, Queuing (Query) Query Stage Complete (CacheLoad)
2018-05-26 20:34:18.977 Detail,
2018-05-26 20:34:18.977 Info, Node005, Sending (NoOp) message (Callback ID=0x10, Expected Reply=0x13) - NoOperation_Set (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x00, 0x00, 0x25, 0x10, 0xd7
2018-05-26 20:34:19.041 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-26 20:34:19.042 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-26 20:34:19.276 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x10, 0x01, 0x00, 0x1d, 0xe7
2018-05-26 20:34:19.277 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x10 received (expected 0x10)
2018-05-26 20:34:19.277 Info, Node005, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2018-05-26 20:34:19.277 Warning, Node005, WARNING: Device is not a sleeping node.
2018-05-26 20:34:19.277 Error, Node005, ERROR: node presumed dead
2018-05-26 20:34:19.277 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2018-05-26 20:34:19.277 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2018-05-26 20:34:19.277 Info, Node005, QueryStageRetry stage CacheLoad requested stage CacheLoad max 3 retries 2 pending 1
2018-05-26 20:34:19.277 Detail, Node001, Expected callbackId was received
2018-05-26 20:34:19.277 Detail, Node001, Expected reply was received
2018-05-26 20:34:19.277 Detail, Node001, Message transaction complete
2018-05-26 20:34:19.278 Detail, Node005, Removing current message
2018-05-26 20:34:19.278 Detail, Node005, Notification: Notification - NoOperation
2018-05-26 20:34:19.280 Detail, Node005, Notification: Notification - Node Dead
2018-05-26 20:34:19.283 Detail, Node006, Query Stage Complete (CacheLoad)
2018-05-26 20:34:19.283 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=2 queryStage=CacheLoad live=1
2018-05-26 20:34:19.283 Detail, Node006, QueryStage_CacheLoad
2018-05-26 20:34:19.283 Info, Node006, Node Identity Codes: 001d:0602:0334
2018-05-26 20:34:19.283 Info, Node006, NoOperation::Set - Routing=true
2018-05-26 20:34:19.283 Detail, Node006, Queuing (NoOp) NoOperation_Set (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x00, 0x00, 0x25, 0x11, 0xd5
2018-05-26 20:34:19.283 Detail, Node006, Queuing (Query) Query Stage Complete (CacheLoad)
2018-05-26 20:34:19.283 Info, Node006, Sending (NoOp) message (Callback ID=0x11, Expected Reply=0x13) - NoOperation_Set (Node=6): 0x01, 0x09, 0x00, 0x13, 0x06, 0x02, 0x00, 0x00, 0x25, 0x11, 0xd5
2018-05-26 20:34:19.291 Detail, Node006, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-26 20:34:19.291 Detail, Node006, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-26 20:34:23.361 Detail, Node006, Received: 0x01, 0x07, 0x00, 0x13, 0x11, 0x01, 0x01, 0x98, 0x62
2018-05-26 20:34:23.361 Detail, Node006, ZW_SEND_DATA Request with callback ID 0x11 received (expected 0x11)
2018-05-26 20:34:23.362 Info, Node006, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2018-05-26 20:34:23.362 Warning, Node006, WARNING: Device is not a sleeping node.
2018-05-26 20:34:23.362 Error, Node006, ERROR: node presumed dead
2018-05-26 20:34:23.362 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2018-05-26 20:34:23.362 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2018-05-26 20:34:23.362 Info, Node006, QueryStageRetry stage CacheLoad requested stage CacheLoad max 3 retries 2 pending 1
2018-05-26 20:34:23.362 Detail, Node001, Expected callbackId was received
2018-05-26 20:34:23.362 Detail, Node001, Expected reply was received
2018-05-26 20:34:23.362 Detail, Node001, Message transaction complete
2018-05-26 20:34:23.362 Detail, Node006, Removing current message
2018-05-26 20:34:23.363 Detail, Node006, Notification: Notification - NoOperation
2018-05-26 20:34:23.366 Detail, Node006, Notification: Notification - Node Dead
2018-05-26 20:34:23.369 Detail,
2018-05-26 20:34:23.369 Info, Node004, Sending (Query) message (Callback ID=0x0f, Expected Reply=0x04) - SwitchAllCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x27, 0x02, 0x25, 0x0f, 0xec
2018-05-26 20:34:23.434 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-26 20:34:23.434 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-26 20:34:23.684 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0x0f, 0x01, 0x00, 0x1f, 0xfa
2018-05-26 20:34:23.684 Detail, Node004, ZW_SEND_DATA Request with callback ID 0x0f received (expected 0x0f)
2018-05-26 20:34:23.684 Info, Node004, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2018-05-26 20:34:23.684 Warning, Node004, WARNING: Device is not a sleeping node.
2018-05-26 20:34:23.684 Detail, Node001, Expected callbackId was received
2018-05-26 20:34:27.783 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0x0f, 0x01, 0x01, 0xb9, 0x5d
2018-05-26 20:34:27.784 Detail, Node004, ZW_SEND_DATA Request with callback ID 0x0f received (expected 0x00)
2018-05-26 20:34:27.784 Warning, Node004, WARNING: Unexpected Callback ID received
2018-05-26 20:34:33.370 Error, Node004, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-05-26 20:34:33.370 Detail, Node004, Removing current message
2018-05-26 20:34:33.370 Detail, Node004, Notification: Notification - TimeOut
2018-05-26 20:34:33.373 Detail, Node004, Query Stage Complete (Session)
2018-05-26 20:34:33.373 Detail, Node004, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2018-05-26 20:34:33.373 Detail, Node004, QueryStage_Dynamic
2018-05-26 20:34:33.373 Detail, Node004, Queuing (Send) SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0x12, 0xf0
2018-05-26 20:34:33.373 Detail, Node004, Queuing (Query) Query Stage Complete (Dynamic)
2018-05-26 20:34:33.374 Detail,
2018-05-26 20:34:33.374 Info, Node004, Sending (Send) message (Callback ID=0x12, Expected Reply=0x04) - SwitchMultilevelCmd_Get (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x26, 0x02, 0x25, 0x12, 0xf0
2018-05-26 20:34:33.439 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-26 20:34:33.439 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-26 20:34:37.817 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0x12, 0x01, 0x01, 0xbc, 0x45
2018-05-26 20:34:37.818 Detail, Node004, ZW_SEND_DATA Request with callback ID 0x12 received (expected 0x12)
2018-05-26 20:34:37.818 Info, Node004, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2018-05-26 20:34:37.818 Warning, Node004, WARNING: Device is not a sleeping node.
2018-05-26 20:34:37.818 Detail, Node001, Expected callbackId was received
2018-05-26 20:34:43.375 Error, Node004, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-05-26 20:34:43.375 Detail, Node004, Removing current message
2018-05-26 20:34:43.376 Detail, Node004, Notification: Notification - TimeOut
2018-05-26 20:34:43.378 Detail, Node005, Query Stage Complete (CacheLoad)
2018-05-26 20:34:43.378 Detail, Node005, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=0
2018-05-26 20:34:43.379 Detail, Node006, Query Stage Complete (CacheLoad)
2018-05-26 20:34:43.379 Detail, Node006, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=0
2018-05-26 20:34:43.379 Detail, Node004, Query Stage Complete (Dynamic)
2018-05-26 20:34:43.379 Detail, Node004, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2018-05-26 20:34:43.379 Detail, Node004, QueryStage_Configuration
2018-05-26 20:34:43.379 Detail, Node004, QueryStage_Complete
2018-05-26 20:34:43.379 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2018-05-26 20:34:43.379 Warning, CheckCompletedNodeQueries all=1, deadFound=1 sleepingOnly=1
2018-05-26 20:34:43.379 Info, Node query processing complete except for dead nodes.
2018-05-26 20:34:43.379 Detail, Node004, Notification: NodeQueriesComplete
2018-05-26 20:34:43.382 Detail, contrlr, Notification: AllNodesQueriedSomeDead
