I’m having trouble with several Z-Wave devices that display the message: “Cannot change status. Disabled by Config entry.” I’ve been struggling to identify the source of this configuration issue.
So far, I’ve verified:
Home Assistant’s device and entity settings (nothing explicitly disabled).
Configuration YAML files (no entries disabling devices).
Z-Wave integration settings (devices are included and appear correctly configured).
I’ve also tried re-interviewing the devices and restarting Home Assistant without success.
Has anyone encountered the “Disabled by Config entry” message before, or can anyone suggest other settings or logs I might check?
The way I fixed this was by shutting down HA and directly editing the device registry file in the .storage directory to reenable the device. If you try this, I recommend making a backup copy of the file and perhaps an HA backup to be safe. Post the entry if you want help.
