My HA setup includes a Gen 5 Z-Wave Aeon Labs Z-Stick USB Controller, three Aeon MultiSensor 6 devices, and three TKB TZ88E Wall Plug Switch / Meters. After I ran the update to 39, I got all kinds of errors, so I decided to start from scratch and reset all my zwave devices and reinstall home assistant. Even after starting fresh, I still get the following errors:
17-03-08 13:19:24 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform zwave
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 151, in _async_setup_platform
entity_platform.add_entities, discovery_info
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/sensor/zwave.py", line 43, in setup_platform
add_devices([ZWaveMultilevelSensor(value)])
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/sensor/zwave.py", line 55, in __init__
zwave.ZWaveDeviceEntity.__init__(self, value, DOMAIN)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py", line 681, in __init__
self._update_attributes()
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py", line 712, in _update_attributes
label=['Power'])
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py", line 763, in get_value
return self._value_handler(method='get', **kwargs)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py", line 731, in _value_handler
class_id=cid, **kwargs).values())
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/openzwave-0.3.2-py3.4.egg/openzwave/node.py", line 445, in get_values
for value in self.values:
RuntimeError: dictionary changed size during iteration
This looks to be a problem with Open Zwave talked about here. In that post (now closed) it says:
"This is a problem inside openzwave, and can’t be fixed in the HA code.
As it doesn’t affect the behaviour, and the battery level will be set later on in the setup, I close this."
But my z-wave Aeon Multisensor devices are going haywire. This is from my logbook:
Showing entries for
8 March 2017
13:34
Aeotec ZW100 MultiSensor 6 Burglar changed to 0
13:34
Aeotec ZW100 MultiSensor 6 SourceNodeId changed to 0
13:34
Aeotec ZW100 MultiSensor 6 Alarm Type changed to 0
13:34
Aeotec ZW100 MultiSensor 6 Alarm Level changed to 0
13:34
Aeotec ZW100 MultiSensor 6 Ultraviolet changed to 0.0
13:34
Wenzhou TKB Control System TZ88 Smart Energy Plug-in Switch Alarm Level changed to 0
13:34
Wenzhou TKB Control System TZ88 Smart Energy Plug-in Switch Alarm Type changed to 0
13:34
Wenzhou TKB Control System TZ88 Smart Energy Plug-in Switch Exporting changed to False
13:33
13:33
13:33
13:30
livingroom turned off
13:30
Wenzhou TKB Control System TZ88 Smart Energy Plug-in Switch Switch turned off
13:30
livingroom turned on
13:30
Wenzhou TKB Control System TZ88 Smart Energy Plug-in Switch Switch turned on
13:29
bedroom turned on
13:29
string lights turned on
13:29
13:29
13:29
13:29
13:29
13:28
13:28
13:28
13:28
13:28
13:28
13:28
13:28
13:28
13:28
13:27
Aeotec ZW100 MultiSensor 6 Sensor turned on
13:22
13:22
13:22
13:21
13:21
13:21
13:20
13:20
13:20
13:19
Temp Living Room High has been triggered
13:19
hallway turned off
13:19
13:19
Home Assistant started
13:18
yr Symbol changed to 46
13:17
Home Assistant stopped
13:16
Kodi changed to playing
13:14
13:14
13:14
13:14
13:13
13:13
13:13
13:12
13:12
13:12
13:11
13:11
13:11
13:10
13:10
13:10
13:08
Aeotec ZW100 MultiSensor 6 Sensor turned off
13:07
13:07
12:59
12:59
12:59
12:59
12:59
12:59
12:58
12:58
12:58
12:55
12:55
12:55
12:54
12:54
12:51
12:51
12:51
12:51
12:45
12:45
hallway turned off
12:45
12:45
12:45
12:44
12:40
12:40
12:40
12:38
Living Room Motion changed to 0
12:38
12:38
12:38
12:38
12:38
Aeotec ZW100 MultiSensor 6 Burglar changed to 8
12:38
12:38
12:38
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:25
12:24
12:24
12:24
12:24
hallway turned off
12:24
12:24
12:24
Home Assistant restarted
12:06
12:05
12:05
12:03
12:03
12:03
12:03
12:03
12:03
12:02
12:02
12:02
12:00
12:00
11:58
11:58
11:55
11:55
11:55
11:55
11:51
Living Room Motion changed to 8
11:51
11:51
11:51
11:40
11:40
11:40
11:40
11:40
11:40
11:40
11:40
11:38
11:38
11:38
11:29
11:29
11:29
11:29
11:13
11:13
11:13
11:13
11:05
11:05
11:03
11:03
11:00
11:00
10:58
10:58
10:55
10:55
10:55
10:55
10:53
10:53
10:53
10:53
10:44
10:44
10:44
10:44
10:40
10:40
10:40
10:40
10:38
10:38
10:38
10:27
10:27
10:27
10:27
10:05
10:05
10:03
10:03
10:00
10:00
09:58
09:58
09:55
09:55
09:55
09:55
09:40
09:40
09:40
09:40
09:38
09:38
09:38
09:38
09:38
09:38
09:38
09:28
09:28
09:28
09:28
09:06
09:06
09:06
09:06
09:06
09:05
09:05
09:03
09:03
09:00
09:00
08:58
08:58
08:57
08:57
08:57
08:57
08:55
08:55
08:55
08:55
08:40
08:40
08:40
08:40
08:38
08:38
08:38
08:38
08:38
08:38
08:38
08:24
08:24
08:24
08:24
08:11
08:11
08:11
08:11
08:05
08:05
08:03
08:03
08:00
08:00
07:58
07:58
07:55
07:55
07:55
07:55
07:52
07:52
07:52
07:52
07:40
07:40
07:40
07:40
07:38
07:38
07:38
07:38
07:38
07:38
07:38
07:13
07:13
07:13
07:05
07:05
07:05
07:05
07:05
07:05
07:03
07:03
07:00
07:00
06:58
06:58
06:55
06:55
06:55
06:55
06:54
06:54
06:54
06:54
06:40
06:40
06:40
06:40
06:39
06:39
06:39
06:39
06:38
06:38
06:38
06:26
Sun has risen
06:26
06:26
06:26
06:26
I’m not sure what’s going on, or what to try next. Any thoughts?
