Suddenly my Z-wave devices started to report status only on a restart of hassio.
I run a hassio docker on a NUC with Z-stick gen.5
Looks like the values are frosen. In the z-wave logs it looks like its getting some reports, but the values are the same. (i.e power consumption, on/off status etc.)
If i restart Hassio, i get the correct values in the moment z-wave network has started, but these values will not change until i restart again.
Any clues what to do or try?
I use the Z-wave integration and no reference to Z-wave in configuration.yaml
I had similar issue with getting values of analog inputs from Fibaro Smart Implant (I use it connected to IR distance sensor to check if car is in garage). I ended up with small automation forcing refreshing sensor value every 10 seconds. Here is the code I use (obviously you will need to update node_id and value_id):
