Z-Wave Dimmer Control WiFi Smart Bulb In Another Room?
Hey everyone,
New to Home Assistant, and loving it!
I am trying to accomplish something which in my mind should be easy. However, my mind is beyond my knowledge of Home Assistant!! :smiley:
So, what I have is a Z-Wave Dimmer in Room A with standard bulbs, and in Room B I have a Smart Bulb.
What I want to do is to have the Smart Bulb in Room B to brightness adjust when the Z-Wave Dimmer in Room A is adjusted.
Can this be done in yaml, or Node-RED?
I have been searching through the community here which is awesome, and there is plenty of stuff on grouping lights, but I haven’t come across anything that does this.
If I’ve missed it please forgive me and point me in the right direction… I don’t want to waste anyone’s time.
Thanks.
This can be done with an automation.
This is similar to what you want:
- id: '1599884610597'
  alias: NanoMote Button 1 Short
  description: ''
  - event_data:
      entity_id: zwave.aeotec_limited_zwa003_nanomote_quad
      scene_data: 7680
      scene_id: 1
    event_type: zwave.scene_activated
    platform: event
  condition: []
  - data: {}
    entity_id: light.leviton_light_office
    service: light.turn_off
Thanks for your response.
However, can you give me some more information on what you have attached. This looks like it activates a scene of some kind.
how will that adjust the brightness of the light bulb, as the brightness of the dimmer is adjusted?
Thanks,
Simon
That is an Automation.
https://www.home-assistant.io/docs/z-wave/device-specific/
Look at the link it will tell you what scene data and id to use for each ‘action’ on the switch.
Thank you :smile: I appreciate your time.
