I’m using Yale B1L push button locks.
They work great.
However, they’re slow to update the lock status in Home Assistant.
I was curious if this is normal or if anyone is using a lock that is instant status?
They work great.
I have a Kwikset and have to poll it for some status updates. It still takes approximately 10-15 seconds for the status to reflect properly on the HA frontend. I don’t know if yours requires polling, but you can try it by adding it under the zwave:
section of your configuration. The trade off though is it will drain the batteries in the lock quicker.
I think I figured out my problem.
I was being lazy and testing my automation using the HASS interface to lock/unlock instead of actually doing it at the lock.
Doing it at the lock updates the status within a few seconds, so it should be fast enough to trigger my “just arrived” automation. Good enough.
Thanks for the suggestion!
