I replaced the batteries on my zwave motion sensor today and then preformed a Reboot System under advanced options. Now my zwave is not connected in my home assistant configuration but appears to be working fine within its separate UI. Do I need to start something or link something? Not sure why my devices are appearing offline.
Try pulling the Zwave stick out and insert it back to USB. Helps a lot of times…
I preformed a restart home assistant and that worked. Weird
There is a problem with zwavejs being restarted when HA is running or HA being started when zwavejs is not running. Specifically subscriptions for device events do not get established / reestablished.
