I recently added a Monoprice Z-Wave Dual Relay and everything is working fine, with one exception. The longer home assistant is running, the more switches get added. On a restart of home assistant, there are normally 4 switches:
So far the count hasnāt gone over 8, although I still havenāt figured out why it starts with 3 and escalates as time goes on. Oh well, theyāre hidden.
I have them too. They will stop around the 128 mark. I have on up to 38 now, and I believe every time you heal/restart zwave it will bump by at least 2. Iāve been meaning to submit it as bug to the openzwave people, but I am not sure how to debug it.
I also have recently installed these dual relay switches. For the most part they work fine, but if I have two switches turned on, on one relay and then turn one or both switches on on the other relay, it usually trips the breaker they are on.
