### Describe the issue you are experiencing
My zigbee2mqqt was failing once in …a while. Rebooting the system resolved it. Today it happened again so i started digging through the log files, there i found in de debug log of zigbee2mqtt that the USB Dongle was suddenly disconnected. Looking into the HA core logfiles i could see at that time not only my zigbee dongle became unavailable, but also my Bluetooth chip and DSMR P1 USB dongle.
If i go into the terminal and do a less /dev/tty… there is no USB device available.
I Also have a Intel Nuc, NUC5i3RYH with HA:
Home Assistant 2024.1.3
Supervisor 2023.12.0
Operating System 11.4
Frontend 20240104.0
The USB dongle is also extended with a sort usb extend cable (20 cm)
If i go the all hardware under system i see a couple of usb ports listed as:
**usb1**
Subsystem:
usb
Device path:
/dev/bus/usb/001/001
Attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/001
DEVNUM: '001'
DEVPATH: /devices/pci0000:00/0000:00:1d.0/usb1
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-pci-0000_00_1d_0
ID_MODEL: EHCI_Host_Controller
ID_MODEL_ENC: EHCI\x20Host\x20Controller
ID_MODEL_ID: '0002'
ID_PATH: pci-0000:00:1d.0
ID_PATH_TAG: pci-0000_00_1d_0
ID_REVISION: '0601'
ID_SERIAL: Linux_6.1.71-haos_ehci_hcd_EHCI_Host_Controller_0000:00:1d.0
ID_SERIAL_SHORT: 0000:00:1d.0
ID_USB_INTERFACES: ':090000:'
ID_USB_MODEL: EHCI_Host_Controller
ID_USB_MODEL_ENC: EHCI\x20Host\x20Controller
ID_USB_MODEL_ID: '0002'
ID_USB_REVISION: '0601'
ID_USB_SERIAL: Linux_6.1.71-haos_ehci_hcd_EHCI_Host_Controller_0000:00:1d.0
ID_USB_SERIAL_SHORT: 0000:00:1d.0
ID_USB_VENDOR: Linux_6.1.71-haos_ehci_hcd
ID_USB_VENDOR_ENC: Linux\x206.1.71-haos\x20ehci_hcd
ID_USB_VENDOR_ID: 1d6b
ID_VENDOR: Linux_6.1.71-haos_ehci_hcd
ID_VENDOR_ENC: Linux\x206.1.71-haos\x20ehci_hcd
ID_VENDOR_ID: 1d6b
MAJOR: '189'
MINOR: '0'
PRODUCT: 1d6b/2/601
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 9/0/0
USEC_INITIALIZED: '1594405'
**usb2**
Subsystem:
usb
Device path:
/dev/bus/usb/002/001
Attributes:
BUSNUM: '002'
DEVNAME: /dev/bus/usb/002/001
DEVNUM: '001'
DEVPATH: /devices/pci0000:00/0000:00:14.0/usb2
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-pci-0000_00_14_0
ID_MODEL: xHCI_Host_Controller
ID_MODEL_ENC: xHCI\x20Host\x20Controller
ID_MODEL_ID: '0002'
ID_PATH: pci-0000:00:14.0
ID_PATH_TAG: pci-0000_00_14_0
ID_REVISION: '0601'
ID_SERIAL: Linux_6.1.71-haos_xhci-hcd_xHCI_Host_Controller_0000:00:14.0
ID_SERIAL_SHORT: '0000:00:14.0'
ID_USB_MODEL: xHCI_Host_Controller
ID_USB_MODEL_ENC: xHCI\x20Host\x20Controller
ID_USB_SERIAL: Linux_6.1.71-haos_xhci-hcd_xHCI_Host_Controller_0000:00:14.0
ID_USB_SERIAL_SHORT: '0000:00:14.0'
ID_USB_VENDOR: Linux_6.1.71-haos_xhci-hcd
ID_USB_VENDOR_ENC: Linux\x206.1.71-haos\x20xhci-hcd
ID_VENDOR: Linux_6.1.71-haos_xhci-hcd
ID_VENDOR_ENC: Linux\x206.1.71-haos\x20xhci-hcd
ID_VENDOR_ID: 1d6b
MAJOR: '189'
MINOR: '128'
PRODUCT: 1d6b/2/601
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 9/0/1
USEC_INITIALIZED: '1601101'
**ttyUSB0**
/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
Subsystem:
tty
Device path:
/dev/ttyUSB0
ID:
Attributes:
DEVLINKS: >-
/dev/serial/by-path/pci-0000:00:14.0-usb-0:4:1.0-port0
DEVNAME: /dev/ttyUSB0
DEVPATH: /devices/pci0000:00/0000:00:14.0/usb2/2-4/2-4:1.0/ttyUSB0/tty/ttyUSB0
ID_BUS: usb
ID_MODEL: USB_Serial
ID_MODEL_ENC: USB\x20Serial
ID_MODEL_ID: '7523'
ID_PATH: pci-0000:00:14.0-usb-0:4:1.0
ID_PATH_TAG: pci-0000_00_14_0-usb-0_4_1_0
ID_REVISION: '0264'
ID_SERIAL: 1a86_USB_Serial
ID_TYPE: generic
ID_USB_DRIVER: ch341
ID_USB_INTERFACES: ':ff0102:'
ID_USB_INTERFACE_NUM: '00'
ID_USB_MODEL: USB_Serial
ID_USB_MODEL_ENC: USB\x20Serial
ID_USB_MODEL_ID: '7523'
ID_USB_REVISION: '0264'
ID_USB_SERIAL: 1a86_USB_Serial
ID_USB_TYPE: generic
ID_USB_VENDOR: 1a86
ID_USB_VENDOR_ENC: 1a86
ID_USB_VENDOR_ID: 1a86
ID_VENDOR: 1a86
ID_VENDOR_ENC: 1a86
ID_VENDOR_ID: 1a86
MAJOR: '188'
MINOR: '0'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '2079542'
**ttyUSB1**
/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A174J5O9-if00-port0
Subsystem:
tty
Device path:
/dev/ttyUSB1
ID:
Attributes:
DEVLINKS: >-
/dev/serial/by-path/pci-0000:00:14.0-usb-0:3:1.0-port0
DEVNAME: /dev/ttyUSB1
DEVPATH: /devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.0/ttyUSB1/tty/ttyUSB1
ID_BUS: usb
ID_MODEL: FT232R_USB_UART
ID_MODEL_ENC: FT232R\x20USB\x20UART
ID_MODEL_ID: '6001'
ID_PATH: pci-0000:00:14.0-usb-0:3:1.0
ID_PATH_TAG: pci-0000_00_14_0-usb-0_3_1_0
ID_REVISION: '0600'
ID_SERIAL: FTDI_FT232R_USB_UART_A174J5O9
ID_SERIAL_SHORT: A174J5O9
ID_TYPE: generic
ID_USB_DRIVER: ftdi_sio
ID_USB_INTERFACES: ':ffffff:'
ID_USB_MODEL: FT232R_USB_UART
ID_USB_MODEL_ENC: FT232R\x20USB\x20UART
ID_USB_MODEL_ID: '6001'
ID_USB_REVISION: '0600'
ID_USB_SERIAL: FTDI_FT232R_USB_UART_A174J5O9
ID_USB_SERIAL_SHORT: A174J5O9
ID_USB_VENDOR: FTDI
ID_USB_VENDOR_ENC: FTDI
ID_USB_VENDOR_ID: '0403'
ID_VENDOR: FTDI
ID_VENDOR_ENC: FTDI
ID_VENDOR_ID: '0403'
MAJOR: '188'
MINOR: '1'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '2140064'
This is wat the core logfiles tell right before failing all usb ports:
2023-11-01 15:22:22.211 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'temperature' when rendering '{{value_json.temperature}}'
2023-11-01 15:22:23.233 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'temperature' when rendering '{{value_json.temperature}}'
2023-11-01 15:22:24.257 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'temperature' when rendering '{{value_json.temperature}}'
2023-11-01 15:22:25.277 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'temperature' when rendering '{{value_json.temperature}}'
2023-11-01 15:22:26.342 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'temperature' when rendering '{{value_json.temperature}}'
2023-11-01 15:47:31.498 ERROR (SyncWorker_9) [custom_components.dhl.sensor] API returned 401
2023-11-01 16:12:34.818 WARNING (MainThread) [bluetooth_auto_recovery.recover] Could not reset the power state of the Bluetooth adapter hci0 [34:13:E8:24:BF:4D] due to timeout after 5 seconds
2023-11-01 16:12:48.572 WARNING (MainThread) [bluetooth_auto_recovery.recover] Could not cycle the Bluetooth adapter hci0 [34:13:E8:24:BF:4D]: [Errno 110] Operation timed out
2023-11-01 16:12:53.574 WARNING (MainThread) [bluetooth_auto_recovery.recover] Bluetooth adapter hci0 [34:13:E8:24:BF:4D] could not be reset:
2023-11-01 16:14:18.755 ERROR (MainThread) [dsmr_parser.clients.protocol] disconnected due to exception
File "/usr/local/lib/python3.11/site-packages/serial_asyncio/__init__.py", line 115, in _read_ready
data = self._serial.read(self._max_read_size)
File "/usr/local/lib/python3.11/site-packages/serial/serialposix.py", line 595, in read
raise SerialException(
serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2023-11-01 16:14:19.164 ERROR (MainThread) [bluetooth_auto_recovery.recover] Unexpected error while attempting USB reset of hci0: [Errno 19] No such device
zigbee2mqtt stopped 16:14:18
Zigbee2MQTT:debug 2023-11-01 16:14:08: Received MQTT message on 'homeassistant/climate/diyless_thermostat_dhw/config' with data '{"name":"DIYLESS DHW","unique_id":"diyless_thermostat_dhw","dev":{"ids":[ "00:00:00:00:00:02" ],"mdl":"DIYLESS Thermostat","sw":"1.7","mf":"DIYLESS"},"~":"diyless_thermostat","avty_t":"~/tele/LWT","pl_avail":"Online","pl_not_avail":"Offline","act_t":"~/stat/things/thermostat/properties","act_tpl":"{{value_json.DHWAction}}","mode_cmd_t":"~/cmnd/things/thermostat/properties/DHWMode","mode_stat_t":"~/stat/things/thermostat/properties","mode_stat_tpl":"{{value_json.DHWMode}}","temp_cmd_t":"~/cmnd/things/thermostat/properties/DHWSetpoint","temp_stat_t":"~/stat/things/thermostat/properties","temp_stat_tpl":"{{value_json.DHWSetpoint}}","curr_temp_t":"~/stat/things/thermostat/properties","curr_temp_tpl":"{{value_json.DHWTemperature}}","pl_on":true,"pl_off":false,"min_temp":"30","max_temp":"80","temp_step":"1","modes":["heat","off"]}'
Zigbee2MQTT:error 2023-11-01 16:14:18: Adapter disconnected, stopping
Zigbee2MQTT:debug 2023-11-01 16:14:18: Saving state to file /share/zigbee2mqtt/state.json
Zigbee2MQTT:info 2023-11-01 16:14:18: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'offline'
Zigbee2MQTT:info 2023-11-01 16:14:18: Disconnecting from MQTT server
Zigbee2MQTT:info 2023-11-01 16:14:18: Stopping zigbee-herdsman...
Zigbee2MQTT:error 2023-11-01 16:14:18: Failed to stop Zigbee2MQTT
This allmost looks like drivers failing or something, who can help?
Post on the community with other users with the same issue:
[https://community.home-assistant.io/t/usb-ports-lost/446289/9?u=djansen1987](https://community.home-assistant.io/t/usb-ports-lost/446289/9?u=djansen1987)
### What operating system image do you use?
generic-x86-64 (Generic UEFI capable x86-64 systems)
### What version of Home Assistant Operating System is installed?
11.4
### Did you upgrade the Operating System.
Yes
### Steps to reproduce the issue
1. Random interval USB Ports become unavailable
2. Check ssh to check /dev/tty*** (none) (aditially tried to unplug and plug in the usb devices to diverent ports without luck)
3. Reboot host -> all port become avalible
### Anything in the Supervisor logs that might be useful for us?
```txt
### Anything in the Host logs that might be useful for us?
```txt
Jan 15 09:22:32 homeassistant kernel: audit: type=1300 audit(1705310552.288:242): arch=c000003e syscall=321 success=yes exit=15 a0=5 a1=c000131be0 a2=78 a3=0 items=0 ppid=4255 pid=4264 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="runc" exe="/usr/bin/runc" subj=unconfined key=(null)
Jan 15 09:22:46 homeassistant systemd[1]: var-lib-docker-overlay2-1507281147c6c4e8867d872898d0044d916b0ca7713382e6bab710ecd60008a5\x2dinit-merged.mount: Deactivated successfully.
Jan 15 09:22:46 homeassistant systemd[1]: mnt-data-docker-overlay2-1507281147c6c4e8867d872898d0044d916b0ca7713382e6bab710ecd60008a5\x2dinit-merged.mount: Deactivated successfully.
Jan 15 09:22:46 homeassistant systemd[1]: Started libcontainer container 8f506e81224a89ed3d88fe732cd6fa36dfb1d29f0a802d5b7c0367fb49145303.
Jan 15 09:22:46 homeassistant kernel: kauditd_printk_skb: 1 callbacks suppressed
Jan 15 09:22:46 homeassistant kernel: audit: type=1334 audit(1705310566.734:243): prog-id=69 op=LOAD
Jan 15 09:22:46 homeassistant kernel: audit: type=1334 audit(1705310566.735:244): prog-id=70 op=LOAD
Jan 15 09:22:46 homeassistant kernel: audit: type=1300 audit(1705310566.735:244): arch=c000003e syscall=321 success=yes exit=16 a0=5 a1=c00018d988 a2=78 a3=0 items=0 ppid=5026 pid=5037 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="runc" exe="/usr/bin/runc" subj=unconfined key=(null)
Jan 15 09:22:46 homeassistant kernel: audit: type=1327 audit(1705310566.735:244): proctitle=72756E63002D2D726F6F74002F7661722F72756E2F646F636B65722F72756E74696D652D72756E632F6D6F6279002D2D6C6F67002F72756E2F636F6E7461696E6572642F696F2E636F6E7461696E6572642E72756E74696D652E76322E7461736B2F6D6F62792F38663530366538313232346138396564336438386665373332
Jan 15 09:22:46 homeassistant kernel: audit: type=1334 audit(1705310566.735:245): prog-id=71 op=LOAD
Jan 15 09:22:46 homeassistant kernel: audit: type=1300 audit(1705310566.735:245): arch=c000003e syscall=321 success=yes exit=18 a0=5 a1=c00018d720 a2=78 a3=0 items=0 ppid=5026 pid=5037 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="runc" exe="/usr/bin/runc" subj=unconfined key=(null)
Jan 15 09:22:46 homeassistant kernel: audit: type=1327 audit(1705310566.735:245): proctitle=72756E63002D2D726F6F74002F7661722F72756E2F646F636B65722F72756E74696D652D72756E632F6D6F6279002D2D6C6F67002F72756E2F636F6E7461696E6572642F696F2E636F6E7461696E6572642E72756E74696D652E76322E7461736B2F6D6F62792F38663530366538313232346138396564336438386665373332
Jan 15 09:22:46 homeassistant kernel: audit: type=1334 audit(1705310566.735:246): prog-id=71 op=UNLOAD
Jan 15 09:22:46 homeassistant kernel: audit: type=1334 audit(1705310566.735:247): prog-id=70 op=UNLOAD
Jan 15 09:22:46 homeassistant kernel: audit: type=1334 audit(1705310566.735:248): prog-id=72 op=LOAD
Jan 15 09:23:18 homeassistant systemd[1]: var-lib-docker-overlay2-c320d1b31de8067ebe01d69b814033d43f1cff7828093c3b0c6885484b6db61e\x2dinit-merged.mount: Deactivated successfully.
Jan 15 09:23:18 homeassistant systemd[1]: mnt-data-docker-overlay2-c320d1b31de8067ebe01d69b814033d43f1cff7828093c3b0c6885484b6db61e\x2dinit-merged.mount: Deactivated successfully.
Jan 15 09:23:18 homeassistant kernel: hassio: port 7(veth0b6ed9e) entered blocking state
Jan 15 09:23:18 homeassistant kernel: hassio: port 7(veth0b6ed9e) entered disabled state
Jan 15 09:23:18 homeassistant kernel: device veth0b6ed9e entered promiscuous mode
Jan 15 09:23:18 homeassistant kernel: kauditd_printk_skb: 2 callbacks suppressed
Jan 15 09:23:18 homeassistant kernel: audit: type=1700 audit(1705310598.977:249): dev=veth0b6ed9e prom=256 old_prom=0 auid=4294967295 uid=0 gid=0 ses=4294967295
Jan 15 09:23:18 homeassistant kernel: audit: type=1300 audit(1705310598.977:249): arch=c000003e syscall=44 success=yes exit=40 a0=c a1=c0015082a0 a2=28 a3=0 items=0 ppid=1 pid=486 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="dockerd" exe="/usr/bin/dockerd" subj=unconfined key=(null)
Jan 15 09:23:18 homeassistant NetworkManager[400]: <info> [1705310598.9803] manager: (veth355de26): new Veth device (/org/freedesktop/NetworkManager/Devices/21)
Jan 15 09:23:18 homeassistant kernel: audit: type=1327 audit(1705310598.977:249): proctitle=2F7573722F62696E2F646F636B657264002D480066643A2F2F002D2D636F6E7461696E6572643D2F72756E2F636F6E7461696E6572642F636F6E7461696E6572642E736F636B
Jan 15 09:23:18 homeassistant NetworkManager[400]: <info> [1705310598.9849] manager: (veth0b6ed9e): new Veth device (/org/freedesktop/NetworkManager/Devices/22)
Jan 15 09:23:19 homeassistant kernel: audit: type=1325 audit(1705310599.001:250): table=nat:84 family=2 entries=1 op=nft_register_rule pid=5224 subj=unconfined comm="iptables"
Jan 15 09:23:19 homeassistant kernel: audit: type=1300 audit(1705310599.001:250): arch=c000003e syscall=46 success=yes exit=508 a0=3 a1=7ffd8560a1d0 a2=0 a3=7ffd8560a1bc items=0 ppid=486 pid=5224 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-nft-multi" subj=unconfined key=(null)
Jan 15 09:23:19 homeassistant kernel: audit: type=1327 audit(1705310599.001:250): proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D74006E6174002D4100444F434B4552002D7000746370002D6400302F30002D2D64706F72740031363237002D6A00444E4154002D2D746F2D64657374696E6174696F6E003137322E33302E33332E313A313632370000002D690068617373696F
Jan 15 09:23:19 homeassistant kernel: audit: type=1325 audit(1705310599.010:251): table=filter:85 family=2 entries=1 op=nft_register_rule pid=5228 subj=unconfined comm="iptables"
Jan 15 09:23:19 homeassistant kernel: audit: type=1300 audit(1705310599.010:251): arch=c000003e syscall=46 success=yes exit=648 a0=3 a1=7fffe344a5c0 a2=0 a3=7fffe344a5ac items=0 ppid=486 pid=5228 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/sbin/xtables-nft-multi" subj=unconfined key=(null)
Jan 15 09:23:19 homeassistant kernel: audit: type=1327 audit(1705310599.010:251): proctitle=2F7573722F7362696E2F69707461626C6573002D2D77616974002D740066696C746572002D4100444F434B45520000002D690068617373696F002D6F0068617373696F002D7000746370002D64003137322E33302E33332E31002D2D64706F72740031363237002D6A00414343455054
Jan 15 09:23:19 homeassistant kernel: audit: type=1325 audit(1705310599.015:252): table=nat:86 family=2 entries=1 op=nft_register_rule pid=5230 subj=unconfined comm="iptables"
Jan 15 09:23:19 homeassistant systemd[1]: Started libcontainer container 77376f4ad73e5042a5e7fa168c2e2afec375aed8943005561b36b2effb5b43f2.
Jan 15 09:23:19 homeassistant kernel: eth0: renamed from veth355de26
Jan 15 09:23:19 homeassistant kernel: IPv6: ADDRCONF(NETDEV_CHANGE): veth0b6ed9e: link becomes ready
Jan 15 09:23:19 homeassistant kernel: hassio: port 7(veth0b6ed9e) entered blocking state
Jan 15 09:23:19 homeassistant kernel: hassio: port 7(veth0b6ed9e) entered forwarding state
Jan 15 09:23:19 homeassistant NetworkManager[400]: <info> [1705310599.2439] device (veth0b6ed9e): carrier: link connected
Jan 15 09:23:19 homeassistant systemd[1]: Started libcontainer container 3edac1d828fc5dd86d9a5f10918d08e2359dd953cf2263e3cfde7960b29177e2.
Jan 15 09:23:19 homeassistant kernel: hassio: port 8(vethce3844a) entered blocking state
Jan 15 09:23:19 homeassistant kernel: hassio: port 8(vethce3844a) entered disabled state
Jan 15 09:23:19 homeassistant kernel: device vethce3844a entered promiscuous mode
Jan 15 09:23:19 homeassistant kernel: hassio: port 8(vethce3844a) entered forwarding state
Jan 15 09:23:19 homeassistant NetworkManager[400]: <info> [1705310599.7336] manager: (veth367d9d6): new Veth device (/org/freedesktop/NetworkManager/Devices/23)
Jan 15 09:23:19 homeassistant NetworkManager[400]: <info> [1705310599.7419] manager: (vethce3844a): new Veth device (/org/freedesktop/NetworkManager/Devices/24)
Jan 15 09:23:19 homeassistant systemd[1]: Started libcontainer container 9fa691a5c0f052bed984d0f7ad914404b97fa9f19073852ce409d6a66323ceb8.
Jan 15 09:23:19 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-77376f4ad73e5042a5e7fa168c2e2afec375aed8943005561b36b2effb5b43f2-runc.YICmO9.mount: Deactivated successfully.
Jan 15 09:23:20 homeassistant kernel: eth0: renamed from veth367d9d6
Jan 15 09:23:20 homeassistant kernel: IPv6: ADDRCONF(NETDEV_CHANGE): vethce3844a: link becomes ready
Jan 15 09:23:20 homeassistant kernel: hassio: port 8(vethce3844a) entered blocking state
Jan 15 09:23:20 homeassistant kernel: hassio: port 8(vethce3844a) entered forwarding state
Jan 15 09:23:20 homeassistant NetworkManager[400]: <info> [1705310600.1743] device (vethce3844a): carrier: link connected
Jan 15 09:23:20 homeassistant systemd[1]: var-lib-docker-overlay2-0f20a07eb46ea2b2fe713cbdc1ffef91c4c774a9ec5ce876c770ebab14027a4d\x2dinit-merged.mount: Deactivated successfully.
Jan 15 09:23:20 homeassistant systemd[1]: mnt-data-docker-overlay2-0f20a07eb46ea2b2fe713cbdc1ffef91c4c774a9ec5ce876c770ebab14027a4d\x2dinit-merged.mount: Deactivated successfully.
Jan 15 09:23:20 homeassistant NetworkManager[400]: <info> [1705310600.4631] manager: (vethddab1dd): new Veth device (/org/freedesktop/NetworkManager/Devices/25)
Jan 15 09:23:20 homeassistant NetworkManager[400]: <info> [1705310600.4676] manager: (veth28de15e): new Veth device (/org/freedesktop/NetworkManager/Devices/26)
Jan 15 09:23:20 homeassistant kernel: hassio: port 9(veth28de15e) entered blocking state
Jan 15 09:23:20 homeassistant kernel: hassio: port 9(veth28de15e) entered disabled state
Jan 15 09:23:20 homeassistant kernel: device veth28de15e entered promiscuous mode
Jan 15 09:23:20 homeassistant kernel: hassio: port 9(veth28de15e) entered forwarding state
Jan 15 09:23:20 homeassistant systemd[1]: Started libcontainer container 128b5a6c8131ce44695d52fc02604795193e94eee9bc15ee83354b29478a520f.
Jan 15 09:23:20 homeassistant kernel: eth0: renamed from vethddab1dd
Jan 15 09:23:21 homeassistant kernel: IPv6: ADDRCONF(NETDEV_CHANGE): veth28de15e: link becomes ready
Jan 15 09:23:21 homeassistant NetworkManager[400]: <info> [1705310601.0055] device (veth28de15e): carrier: link connected
Jan 15 09:23:26 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-128b5a6c8131ce44695d52fc02604795193e94eee9bc15ee83354b29478a520f-runc.9g0fz3.mount: Deactivated successfully.
Jan 15 09:23:35 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-2413245af44a10267fe2f4ed23a836a3151126dca7e3b84ce55ccded2fea9a96-runc.4emfk4.mount: Deactivated successfully.
Jan 15 09:23:36 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-128b5a6c8131ce44695d52fc02604795193e94eee9bc15ee83354b29478a520f-runc.kd60jk.mount: Deactivated successfully.
Jan 15 09:24:11 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-128b5a6c8131ce44695d52fc02604795193e94eee9bc15ee83354b29478a520f-runc.UYphFO.mount: Deactivated successfully.
Jan 15 09:24:19 homeassistant systemd[1]: run-docker-runtime\x2drunc-moby-3edac1d828fc5dd86d9a5f10918d08e2359dd953cf2263e3cfde7960b29177e2-runc.34PfgK.mount: Deactivated successfully.
Jan 15 09:24:22 homeassistant kernel: kauditd_printk_skb: 146 callbacks suppressed
Jan 15 09:24:22 homeassistant kernel: audit: type=1334 audit(1705310662.126:309): prog-id=89 op=LOAD
Jan 15 09:24:22 homeassistant kernel: audit: type=1334 audit(1705310662.126:310): prog-id=90 op=LOAD
Jan 15 09:24:22 homeassistant kernel: audit: type=1334 audit(1705310662.126:311): prog-id=91 op=LOAD
Jan 15 09:24:22 homeassistant systemd[1]: Starting Hostname Service...
Jan 15 09:24:22 homeassistant systemd[1]: Started Hostname Service.
Jan 15 09:24:22 homeassistant kernel: audit: type=1334 audit(1705310662.531:312): prog-id=92 op=LOAD
Jan 15 09:24:22 homeassistant kernel: audit: type=1334 audit(1705310662.531:313): prog-id=93 op=LOAD
Jan 15 09:24:22 homeassistant kernel: audit: type=1334 audit(1705310662.531:314): prog-id=94 op=LOAD
Jan 15 09:24:22 homeassistant systemd[1]: Starting Time & Date Service...
Jan 15 09:24:22 homeassistant systemd[1]: Started Time & Date Service.
Jan 15 09:24:52 homeassistant systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Jan 15 09:24:52 homeassistant kernel: audit: type=1334 audit(1705310692.586:315): prog-id=91 op=UNLOAD
Jan 15 09:24:52 homeassistant kernel: audit: type=1334 audit(1705310692.586:316): prog-id=90 op=UNLOAD
Jan 15 09:24:52 homeassistant kernel: audit: type=1334 audit(1705310692.586:317): prog-id=89 op=UNLOAD
Jan 15 09:24:52 homeassistant systemd[1]: systemd-timedated.service: Deactivated successfully.
Jan 15 09:24:52 homeassistant kernel: audit: type=1334 audit(1705310692.867:318): prog-id=94 op=UNLOAD
Jan 15 09:24:52 homeassistant kernel: audit: type=1334 audit(1705310692.867:319): prog-id=93 op=UNLOAD
Jan 15 09:24:52 homeassistant kernel: audit: type=1334 audit(1705310692.867:320): prog-id=92 op=UNLOAD
Jan 15 09:35:30 homeassistant kernel: audit: type=1334 audit(1705311330.812:321): prog-id=95 op=LOAD
Jan 15 09:35:30 homeassistant systemd-timesyncd[472]: Network configuration changed, trying to establish connection.
Jan 15 09:35:30 homeassistant systemd-timesyncd[472]: Contacted time server 162.159.200.123:123 (time.cloudflare.com).
Jan 15 09:35:30 homeassistant systemd[1]: Started Journal Gateway Service.
Jan 15 09:35:31 homeassistant systemd-journal-gatewayd[10721]: microhttpd: MHD_OPTION_EXTERNAL_LOGGER is not the first option specified for the daemon. Some messages may be printed by the standard MHD logger.
Jan 15 09:36:36 homeassistant systemd[1]: Starting Cleanup of Temporary Directories...
Jan 15 09:36:36 homeassistant systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Jan 15 09:36:36 homeassistant systemd[1]: Finished Cleanup of Temporary Directories.
Jan 15 09:36:36 homeassistant systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dclean.service.mount: Deactivated successfully.
### System information
## System Information
version | core-2024.1.3
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.11.6
os_name | Linux
os_version | 6.1.71-haos
arch | x86_64
timezone | Europe/Amsterdam
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4924
Installed Version | 1.33.0
Stage | running
Available Repositories | 1377
Downloaded Repositories | 11
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | true
subscription_expiration | August 7, 2024 at 2:00 AM
relayer_connected | true
relayer_region | eu-central-1
remote_enabled | true
remote_connected | true
alexa_enabled | false
google_enabled | true
remote_server | eu-central-1-3.ui.nabu.casa
certificate_status | ready
instance_id | a00d7c3253584417bca037041fbc4817
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 11.4
update_channel | stable
supervisor_version | supervisor-2023.12.0
agent_version | 1.6.0
docker_version | 24.0.7
disk_total | 458.4 GB
disk_used | 88.9 GB
healthy | true
supported | true
board | generic-x86-64
supervisor_api | ok
version_api | ok
installed_addons | Samba share (12.2.0), Home Assistant Google Drive Backup (0.112.1), Node-RED (17.0.2), Mosquitto broker (6.4.0), motionEye (0.20.0), Terminal & SSH (9.8.1), ESPHome (2023.12.5), AirCast (4.1.1), emby (4.7.11), Zigbee2MQTT (1.35.1-1), Advanced SSH & Web Terminal (17.0.3), Matter Server (5.0.2), AirSonos (4.1.1), FTP (5.0.1), Nextcloud (28.0.1-6), Music Assistant BETA (2.0.0b82)
</details>
<details><summary>Dashboards</summary>
dashboards | 2
resources | 6
views | 31
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | January 5, 2024 at 5:38 PM
current_recorder_run | January 15, 2024 at 10:22 AM
estimated_db_size | 2373.16 MiB
database_engine | sqlite
database_version | 3.41.2
</details>
<details><summary>Spotify</summary>
api_endpoint_reachable | ok
</details>
### Additional information
_No response_
