I have a problem with multiple DS18B20 sensors.
If I only have one sensor, it works fine. But when I connect a second one I don’t get any temp.
Hassio 2.12 run on a raspberry pi 3b with on-board Zwave-me card.
Hope for a simple resolution
/B
/B
I don’t have any of those FGBS-222 devices, but with other Fibaros devices you have to connect all sensors at the time of including/adding them to Home Assistant (IOW your zwave controller). Sensors added afterwards will not be recognized.
Yes, it is so.
I got it to work as you wrote, add all sensors before add the device to Home assistant Z-wave.
Thanks.
Hi there
I’m struggling to get out the DS18B20 tempvalues from the smart implant but haven’t figured how to do it since the documentation around this sucks. So far I haven’t been able to get out a single value, tried with one and six AND re-included the devise after each change. Can you please give me a hint how you did it?
I’m running the latest Hassio setup on a R-Pi4 and an Aeotec z-stick gen 5.
me too, a setup of the code would be welcome
