I’ve been using 2 of these thermostats (GoControl z-wave thermostat) all summer and they were working perfectly…until it got cold. I discovered that HA only shows the following services for both of my thermostats (dual zone HVAC units):
I’m able to change the operation mode to Heat, but then the temp is not controllable. No matter what, it does not seem to respond to heat services at all.
Long story short, I have the same thermostat and have no issue at the moment (it was a bit of a rocky road though).
Originally I had to modify the zwave configs to get it working.
Then it was added at the source.
Then I think their were two versions of HA that broke the heat function.
This was fixed fairly quickly though in a following point release.
I also have a pair of these thermostats and am having the same issue.
can you elaborate on “I ended up pulling the latest GoControl dev file and uploading it. I wasn’t able to do it on Hass, but I was with Hassbian.”
or what to add to “the zwave configs to get it working.”
right now i have all 4 entities for the down stairs tstat and they all show the current temp and that it’s in heat mode - but they show different set points that are all wrong?
