So I’ve got Z-Wave working and it recognizes my GE 14292 toggle switch and shows it in the Z-Wave panel, but I don’t get a switch control in the UI and I’m at a loss as to how I might add one. Do I add a switch device, and if so what platform, etc?
does it show up in switch domain, in the states page?
It shows up as “zwave.ge_14292_inwall_smart_toggle_switch”.
Yes, that always shows up with new included devices. I’m talking about anything in the switch domain. It would start with switch.xxxxxxxxxxxxxxxxxxxx.
nope, nothing in the switch domain…
Did you set it up through the zwave config tab? I.E. naming the node, etc
Once you pair the device try restarting HA, see if the switch object shows up then.
Renamed the node, restarted HA, shows as “ready” on the Z-Wave panel, and zwave.parlor_light entity, but no switch.* entity.
In the zwave menu in HA, when you select it from the drop down, is anything populated in the “entities of this…” dropdown?
Note if this is a dimmer switch it shows up as a light not switch
Nothing shows up under “entities of this node” for the parlor light.
And this is a simple toggle switch, not a dimmer.
Try removing the device in the zwave menu then re-add it using the “Add Secure Node” (make sure you have a key set in your zwave config) and see if that helps at all. It might be requiring you to pair securely for the switch to be exposed.
I have the “flat face” version of these switches and I didn’t have to do any of this.
@claud9999 what z stick are you using to connect to the device?
Neither did I, have the 14291 paddle switches, but just throwing out ideas for him to try.
Yah, that’s what I have. I’m wondering if its his z stick. Or maybe he accidentally reprogrammed the behavior by changing the reporting type
Ok so it should just work “automagically”, eh?
The stick reports as “Sigma Designs UZB Z-Wave USB Adapter”. It’s a “HomeSeer SmartStick+ Z-Wave Plus USB Interface” card (bought off Amazon.) Could very well be the stick, but it does seem to be reporting everything correctly…
can you paste your OZW_Log.txt so we can see if there’s an error?
copy/paste:
2018-03-26 07:27:17.727 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xf80b4c9e. Our node ID = 1
2018-03-26 07:27:17.727 Detail, Node011, Expected reply was received
2018-03-26 07:27:17.727 Detail, Node011, Message transaction complete
2018-03-26 07:27:17.727 Detail, contrlr, Removing current message
2018-03-26 07:27:17.727 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2018-03-26 07:27:17.729 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x08, 0xf7
2018-03-26 07:27:17.729 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2018-03-26 07:27:17.729 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2018-03-26 07:27:17.729 Info, contrlr, The PC controller is a primary controller.
2018-03-26 07:27:17.729 Detail, Node247, Expected reply was received
2018-03-26 07:27:17.729 Detail, Node247, Message transaction complete
2018-03-26 07:27:17.729 Detail, contrlr, Removing current message
2018-03-26 07:27:17.729 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2018-03-26 07:27:17.732 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x04, 0x20, 0x00, 0x00, 0x00, 0x01, 0x00, 0x01, 0xfe, 0x81, 0xff, 0x88, 0xcf, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x80, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0x03
2018-03-26 07:27:17.732 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2018-03-26 07:27:17.732 Info, contrlr, Serial API Version: 4.32
2018-03-26 07:27:17.732 Info, contrlr, Manufacturer ID: 0x0000
2018-03-26 07:27:17.732 Info, contrlr, Product Type: 0x0001
2018-03-26 07:27:17.732 Info, contrlr, Product ID: 0x0001
2018-03-26 07:27:17.732 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2018-03-26 07:27:17.732 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2018-03-26 07:27:17.732 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2018-03-26 07:27:17.732 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2018-03-26 07:27:17.732 Detail, Node032, Expected reply was received
2018-03-26 07:27:17.732 Detail, Node032, Message transaction complete
2018-03-26 07:27:17.732 Detail, contrlr, Removing current message
2018-03-26 07:27:17.732 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2018-03-26 07:27:17.734 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2018-03-26 07:27:17.734 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2018-03-26 07:27:17.734 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2018-03-26 07:27:17.734 Detail, Node172, Expected reply was received
2018-03-26 07:27:17.734 Detail, Node172, Message transaction complete
2018-03-26 07:27:17.734 Detail, contrlr, Removing current message
2018-03-26 07:27:17.734 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2018-03-26 07:27:17.790 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x77, 0x2c, 0x62, 0x0c, 0x1b, 0x8c, 0x79, 0x80, 0x9d, 0x10, 0xf2, 0xdc, 0xe9, 0xa6, 0x8b, 0x9e, 0x33, 0x7e, 0x4f, 0x65, 0x2f, 0x14, 0x3e, 0x78, 0x86, 0xee, 0x76, 0x18, 0x95, 0x5b, 0x4b, 0x0a, 0xd7
2018-03-26 07:27:17.790 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2018-03-26 07:27:17.790 Detail, Node032, Expected reply was received
2018-03-26 07:27:17.790 Detail, Node032, Message transaction complete
2018-03-26 07:27:17.790 Detail, contrlr, Removing current message
2018-03-26 07:27:17.790 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2018-03-26 07:27:17.887 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc7
2018-03-26 07:27:17.887 Info, mgr, Driver with Home ID of 0xf80b4c9e is now ready.
2018-03-26 07:27:17.889 Detail, Node002, Queuing (Controller) Delete All Return Routes
2018-03-26 07:27:17.889 Detail, Node002, Queuing (Controller) Assign Return Route
2018-03-26 07:27:17.889 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2018-03-26 07:27:17.889 Info, contrlr, Node 001 - Known
2018-03-26 07:27:17.889 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2018-03-26 07:27:17.889 Detail, Node001, QueryStage_CacheLoad
2018-03-26 07:27:17.889 Info, Node001, Node Identity Codes: 0000:0001:0001
2018-03-26 07:27:17.889 Detail, Node001, QueryStage_Associations
2018-03-26 07:27:17.889 Detail, Node001, QueryStage_Neighbors
2018-03-26 07:27:17.889 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2018-03-26 07:27:17.889 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2018-03-26 07:27:17.889 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2018-03-26 07:27:17.889 Info, contrlr, Node 002 - Known
2018-03-26 07:27:17.889 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2018-03-26 07:27:17.889 Detail, Node002, QueryStage_CacheLoad
2018-03-26 07:27:17.889 Info, Node002, Node Identity Codes: 0063:4952:3037
2018-03-26 07:27:17.889 Info, Node002, NoOperation::Set - Routing=true
2018-03-26 07:27:17.889 Detail, Node002, Queuing (NoOp) NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xca
2018-03-26 07:27:17.889 Detail, Node002, Queuing (Query) Query Stage Complete (CacheLoad)
2018-03-26 07:27:17.890 Detail, Expected reply was received
2018-03-26 07:27:17.890 Detail, Message transaction complete
2018-03-26 07:27:17.890 Detail, contrlr, Removing current message
2018-03-26 07:27:17.890 Detail, Node001, Notification: DriverReady
2018-03-26 07:27:17.891 Detail, Node001, Notification: NodeAdded
2018-03-26 07:27:17.894 Detail, Node001, Notification: NodeProtocolInfo
2018-03-26 07:27:17.894 Detail, Node001, Notification: EssentialNodeQueriesComplete
2018-03-26 07:27:17.894 Detail, Node001, Notification: ValueAdded
2018-03-26 07:27:17.895 Detail, Node002, Notification: NodeAdded
2018-03-26 07:27:17.897 Detail, Node002, Notification: NodeProtocolInfo
2018-03-26 07:27:17.897 Detail, Node002, Notification: EssentialNodeQueriesComplete
2018-03-26 07:27:17.897 Detail, Node002, Notification: ValueAdded
2018-03-26 07:27:17.898 Detail, Node002, Notification: ValueAdded
2018-03-26 07:27:17.899 Detail, Node002, Notification: ValueAdded
2018-03-26 07:27:17.899 Detail, Node002, Notification: Group
2018-03-26 07:27:17.899 Detail, Node002, Notification: NodeNaming
2018-03-26 07:27:17.899 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2018-03-26 07:27:17.901 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2018-03-26 07:27:17.901 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2018-03-26 07:27:17.901 Detail, Node015, Expected reply was received
2018-03-26 07:27:17.901 Detail, Node015, Message transaction complete
2018-03-26 07:27:17.901 Detail, contrlr, Removing current message
2018-03-26 07:27:17.901 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2018-03-26 07:27:17.902 Detail, contrlr, Removing current message
2018-03-26 07:27:17.902 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2018-03-26 07:27:17.907 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5c
2018-03-26 07:27:17.907 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2018-03-26 07:27:17.907 Info, Node001, Neighbors of this node are:
2018-03-26 07:27:17.907 Info, Node001, Node 2
2018-03-26 07:27:17.907 Detail, Expected reply was received
2018-03-26 07:27:17.907 Detail, Message transaction complete
2018-03-26 07:27:17.907 Detail, Node001, Removing current message
2018-03-26 07:27:17.907 Info, Node002, Sending (NoOp) message (Callback ID=0x0a, Expected Reply=0x13) - NoOperation_Set (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x00, 0x00, 0x25, 0x0a, 0xca
2018-03-26 07:27:17.918 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-03-26 07:27:17.918 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-03-26 07:27:17.934 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x0a, 0x00, 0xe3
2018-03-26 07:27:17.934 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0a received (expected 0x0a)
2018-03-26 07:27:17.935 Info, Node002, Request RTT 27 Average Request RTT 27
2018-03-26 07:27:17.935 Detail, Expected callbackId was received
2018-03-26 07:27:17.935 Detail, Expected reply was received
2018-03-26 07:27:17.935 Detail, Message transaction complete
2018-03-26 07:27:17.935 Detail, Node002, Removing current message
2018-03-26 07:27:17.935 Detail, Node002, Notification: Notification - NoOperation
2018-03-26 07:27:17.935 Info, Deleting all return routes from node 2
2018-03-26 07:27:17.935 Detail, Node002, Queuing (Command) ControllerCommand_DeleteAllReturnRoutess (Node=2): 0x01, 0x05, 0x00, 0x47, 0x02, 0x0b, 0xb4
2018-03-26 07:27:17.935 Detail, Notification: ControllerCommand - Starting
2018-03-26 07:27:17.935 Info, Node002, Sending (Command) message (Callback ID=0x0b, Expected Reply=0x47) - ControllerCommand_DeleteAllReturnRoutess (Node=2): 0x01, 0x05, 0x00, 0x47, 0x02, 0x0b, 0xb4
2018-03-26 07:27:17.943 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x47, 0x01, 0xbc
2018-03-26 07:27:17.943 Info, Node002, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE - command in progress
2018-03-26 07:27:17.943 Detail, Notification: ControllerCommand - InProgress
2018-03-26 07:27:18.049 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x47, 0x0b, 0x00, 0xb6
2018-03-26 07:27:18.049 Info, Node002, Received reply to FUNC_ID_ZW_DELETE_RETURN_ROUTE for node 2 - SUCCESS
2018-03-26 07:27:18.049 Detail, Expected callbackId was received
2018-03-26 07:27:18.049 Detail, Expected reply was received
2018-03-26 07:27:18.049 Detail, Message transaction complete
2018-03-26 07:27:18.049 Detail, Node002, Removing current message
2018-03-26 07:27:18.049 Detail, Notification: ControllerCommand - Completed
2018-03-26 07:27:18.049 Info, Assigning return route from node 2 to node 1
2018-03-26 07:27:18.050 Detail, Node002, Queuing (Command) ControllerCommand_AssignReturnRoute (Node=2): 0x01, 0x06, 0x00, 0x46, 0x02, 0x01, 0x0c, 0xb0
2018-03-26 07:27:18.050 Detail, Notification: ControllerCommand - Starting
2018-03-26 07:27:18.050 Info, Node002, Sending (Command) message (Callback ID=0x0c, Expected Reply=0x46) - ControllerCommand_AssignReturnRoute (Node=2): 0x01, 0x06, 0x00, 0x46, 0x02, 0x01, 0x0c, 0xb0
2018-03-26 07:27:18.061 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x46, 0x01, 0xbd
2018-03-26 07:27:18.061 Info, Node002, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE - command in progress
2018-03-26 07:27:18.061 Detail, Notification: ControllerCommand - InProgress
2018-03-26 07:27:18.346 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x46, 0x0c, 0x00, 0xb0
2018-03-26 07:27:18.346 Info, Node002, Received reply to FUNC_ID_ZW_ASSIGN_RETURN_ROUTE for node 2 - SUCCESS
2018-03-26 07:27:18.346 Detail, Expected callbackId was received
2018-03-26 07:27:18.346 Detail, Expected reply was received
2018-03-26 07:27:18.346 Detail, Message transaction complete
2018-03-26 07:27:18.346 Detail, Node002, Removing current message
2018-03-26 07:27:18.346 Detail, Notification: ControllerCommand - Completed
2018-03-26 07:27:18.347 Detail, Node001, Query Stage Complete (Neighbors)
2018-03-26 07:27:18.347 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2018-03-26 07:27:18.347 Detail, Node001, QueryStage_Session
2018-03-26 07:27:18.347 Detail, Node001, QueryStage_Dynamic
2018-03-26 07:27:18.347 Detail, Node001, QueryStage_Configuration
2018-03-26 07:27:18.347 Detail, Node001, QueryStage_Complete
2018-03-26 07:27:18.347 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2018-03-26 07:27:18.347 Warning, CheckCompletedNodeQueries all=0, deadFound=0 sleepingOnly=0
2018-03-26 07:27:18.347 Detail, Node001, Notification: NodeQueriesComplete
2018-03-26 07:27:18.347 Detail, Node002, Query Stage Complete (CacheLoad)
2018-03-26 07:27:18.347 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Associations live=1
2018-03-26 07:27:18.347 Detail, Node002, QueryStage_Associations
2018-03-26 07:27:18.347 Info, Node002, Number of association groups reported for node 2 is 3.
2018-03-26 07:27:18.347 Info, Node002, Get Associations for group 1 of node 2
2018-03-26 07:27:18.347 Detail, Node002, Queuing (Send) AssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x85, 0x02, 0x01, 0x25, 0x0d, 0x49
2018-03-26 07:27:18.347 Detail, Node002, Queuing (Query) Query Stage Complete (Associations)
2018-03-26 07:27:18.347 Info, Node002, Sending (Send) message (Callback ID=0x0d, Expected Reply=0x04) - AssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x85, 0x02, 0x01, 0x25, 0x0d, 0x49
2018-03-26 07:27:18.354 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-03-26 07:27:18.354 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-03-26 07:27:18.370 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x0d, 0x00, 0xe4
2018-03-26 07:27:18.371 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0d received (expected 0x0d)
2018-03-26 07:27:18.371 Info, Node002, Request RTT 23 Average Request RTT 25
2018-03-26 07:27:18.371 Detail, Expected callbackId was received
2018-03-26 07:27:18.382 Detail, Node002, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x85, 0x03, 0x01, 0x05, 0x00, 0x01, 0x70
2018-03-26 07:27:18.382 Info, Node002, Response RTT 35 Average Response RTT 35
2018-03-26 07:27:18.382 Info, Node002, Received Association report from node 2, group 1, containing 1 associations
2018-03-26 07:27:18.382 Info, Node002, The group contains:
2018-03-26 07:27:18.382 Info, Node002, Node 1
2018-03-26 07:27:18.382 Info, Node002, Get Associations for group 2 of node 2
2018-03-26 07:27:18.382 Detail, Node002, Queuing (Send) AssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x85, 0x02, 0x02, 0x25, 0x0e, 0x49
2018-03-26 07:27:18.382 Detail, Node002, Expected reply and command class was received
2018-03-26 07:27:18.382 Detail, Node002, Message transaction complete
2018-03-26 07:27:18.382 Detail, Node002, Removing current message
2018-03-26 07:27:18.382 Info, Node002, Sending (Send) message (Callback ID=0x0e, Expected Reply=0x04) - AssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x85, 0x02, 0x02, 0x25, 0x0e, 0x49
2018-03-26 07:27:18.390 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-03-26 07:27:18.390 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-03-26 07:27:18.407 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x0e, 0x00, 0xe7
2018-03-26 07:27:18.407 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0e received (expected 0x0e)
2018-03-26 07:27:18.407 Info, Node002, Request RTT 24 Average Request RTT 24
2018-03-26 07:27:18.407 Detail, Expected callbackId was received
2018-03-26 07:27:18.419 Detail, Node002, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x02, 0x05, 0x85, 0x03, 0x02, 0x05, 0x00, 0x76
2018-03-26 07:27:18.419 Info, Node002, Response RTT 36 Average Response RTT 35
2018-03-26 07:27:18.419 Info, Node002, Received Association report from node 2, group 2, containing 0 associations
2018-03-26 07:27:18.419 Info, Node002, Get Associations for group 3 of node 2
2018-03-26 07:27:18.419 Detail, Node002, Queuing (Send) AssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x85, 0x02, 0x03, 0x25, 0x0f, 0x49
2018-03-26 07:27:18.419 Detail, Node002, Expected reply and command class was received
2018-03-26 07:27:18.419 Detail, Node002, Message transaction complete
2018-03-26 07:27:18.419 Detail, Node002, Removing current message
2018-03-26 07:27:18.419 Detail, Node002, Notification: Group
2018-03-26 07:27:18.419 Info, Node002, Sending (Send) message (Callback ID=0x0f, Expected Reply=0x04) - AssociationCmd_Get (Node=2): 0x01, 0x0a, 0x00, 0x13, 0x02, 0x03, 0x85, 0x02, 0x03, 0x25, 0x0f, 0x49
2018-03-26 07:27:18.427 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-03-26 07:27:18.427 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-03-26 07:27:18.444 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x0f, 0x00, 0xe6
2018-03-26 07:27:18.444 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x0f received (expected 0x0f)
2018-03-26 07:27:18.444 Info, Node002, Request RTT 25 Average Request RTT 24
2018-03-26 07:27:18.444 Detail, Expected callbackId was received
2018-03-26 07:27:18.456 Detail, Node002, Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x02, 0x05, 0x85, 0x03, 0x03, 0x05, 0x00, 0x77
2018-03-26 07:27:18.456 Info, Node002, Response RTT 36 Average Response RTT 35
2018-03-26 07:27:18.456 Info, Node002, Received Association report from node 2, group 3, containing 0 associations
2018-03-26 07:27:18.456 Info, Node002, Querying associations for node 2 is complete.
2018-03-26 07:27:18.456 Detail, Node002, Expected reply and command class was received
2018-03-26 07:27:18.456 Detail, Node002, Message transaction complete
2018-03-26 07:27:18.456 Detail, Node002, Removing current message
2018-03-26 07:27:18.456 Detail, Node002, Notification: Group
2018-03-26 07:27:18.456 Detail, Node002, Query Stage Complete (Associations)
2018-03-26 07:27:18.456 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Neighbors live=1
2018-03-26 07:27:18.456 Detail, Node002, QueryStage_Neighbors
2018-03-26 07:27:18.456 Detail, Requesting routing info (neighbor list) for Node 2
2018-03-26 07:27:18.456 Detail, Node002, Queuing (Command) Get Routing Info (Node=2): 0x01, 0x07, 0x00, 0x80, 0x02, 0x00, 0x00, 0x03, 0x79
2018-03-26 07:27:18.456 Detail, Node002, Queuing (Query) Query Stage Complete (Neighbors)
2018-03-26 07:27:18.456 Info, Node002, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=2): 0x01, 0x07, 0x00, 0x80, 0x02, 0x00, 0x00, 0x03, 0x79
2018-03-26 07:27:18.460 Detail, Node002, Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5f
2018-03-26 07:27:18.460 Info, Node002, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2018-03-26 07:27:18.460 Info, Node002, Neighbors of this node are:
2018-03-26 07:27:18.460 Info, Node002, Node 1
2018-03-26 07:27:18.460 Detail, Expected reply was received
2018-03-26 07:27:18.460 Detail, Message transaction complete
2018-03-26 07:27:18.460 Detail, Node002, Removing current message
2018-03-26 07:27:18.460 Detail, Node002, Query Stage Complete (Neighbors)
2018-03-26 07:27:18.460 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2018-03-26 07:27:18.460 Detail, Node002, QueryStage_Session
2018-03-26 07:27:18.460 Detail, Node002, Queuing (Query) SwitchAllCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x27, 0x02, 0x25, 0x10, 0xf5
2018-03-26 07:27:18.460 Detail, Node002, Queuing (Query) PowerlevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x73, 0x02, 0x25, 0x11, 0xa0
2018-03-26 07:27:18.460 Detail, Node002, Queuing (Query) Query Stage Complete (Session)
2018-03-26 07:27:18.460 Info, Node002, Sending (Query) message (Callback ID=0x10, Expected Reply=0x04) - SwitchAllCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x27, 0x02, 0x25, 0x10, 0xf5
2018-03-26 07:27:18.468 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-03-26 07:27:18.469 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-03-26 07:27:18.488 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x10, 0x00, 0xf9
2018-03-26 07:27:18.488 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x10 received (expected 0x10)
2018-03-26 07:27:18.488 Info, Node002, Request RTT 27 Average Request RTT 25
2018-03-26 07:27:18.488 Detail, Expected callbackId was received
2018-03-26 07:27:18.499 Detail, Node002, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x27, 0x03, 0xff, 0x28
2018-03-26 07:27:18.499 Info, Node002, Response RTT 39 Average Response RTT 37
2018-03-26 07:27:18.499 Detail, Node002, Initial read of value
2018-03-26 07:27:18.499 Info, Node002, Received SwitchAll report from node 2: On and Off Enabled
2018-03-26 07:27:18.499 Detail, Node002, Expected reply and command class was received
2018-03-26 07:27:18.499 Detail, Node002, Message transaction complete
2018-03-26 07:27:18.499 Detail, Node002, Removing current message
2018-03-26 07:27:18.499 Detail, Node002, Notification: ValueChanged
2018-03-26 07:27:18.500 Detail,
2018-03-26 07:27:18.500 Info, Node002, Sending (Query) message (Callback ID=0x11, Expected Reply=0x04) - PowerlevelCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x73, 0x02, 0x25, 0x11, 0xa0
2018-03-26 07:27:18.508 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-03-26 07:27:18.508 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-03-26 07:27:18.525 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x11, 0x00, 0xf8
2018-03-26 07:27:18.525 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x11 received (expected 0x11)
2018-03-26 07:27:18.525 Info, Node002, Request RTT 24 Average Request RTT 24
2018-03-26 07:27:18.525 Detail, Expected callbackId was received
2018-03-26 07:27:18.536 Detail, Node002, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x02, 0x04, 0x73, 0x03, 0x00, 0x00, 0x87
2018-03-26 07:27:18.536 Info, Node002, Response RTT 36 Average Response RTT 36
2018-03-26 07:27:18.536 Info, Node002, Received a PowerLevel report: PowerLevel=Normal, Timeout=0
2018-03-26 07:27:18.536 Detail, Node002, Initial read of value
2018-03-26 07:27:18.536 Detail, Node002, Expected reply and command class was received
2018-03-26 07:27:18.536 Detail, Node002, Message transaction complete
2018-03-26 07:27:18.536 Detail, Node002, Removing current message
2018-03-26 07:27:18.536 Detail, Node002, Notification: ValueChanged
2018-03-26 07:27:18.537 Detail, Node002, Notification: ValueChanged
2018-03-26 07:27:18.537 Detail, Node002, Query Stage Complete (Session)
2018-03-26 07:27:18.537 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Dynamic live=1
2018-03-26 07:27:18.537 Detail, Node002, QueryStage_Dynamic
2018-03-26 07:27:18.537 Detail, Node002, Queuing (Send) SwitchBinaryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x25, 0x02, 0x25, 0x12, 0xf5
2018-03-26 07:27:18.537 Detail, Node002, Queuing (Query) Query Stage Complete (Dynamic)
2018-03-26 07:27:18.537 Info, Node002, Sending (Send) message (Callback ID=0x12, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x25, 0x02, 0x25, 0x12, 0xf5
2018-03-26 07:27:18.545 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-03-26 07:27:18.545 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2018-03-26 07:27:18.561 Detail, Node002, Received: 0x01, 0x05, 0x00, 0x13, 0x12, 0x00, 0xfb
2018-03-26 07:27:18.561 Detail, Node002, ZW_SEND_DATA Request with callback ID 0x12 received (expected 0x12)
2018-03-26 07:27:18.561 Info, Node002, Request RTT 23 Average Request RTT 23
2018-03-26 07:27:18.561 Detail, Expected callbackId was received
2018-03-26 07:27:18.572 Detail, Node002, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x25, 0x03, 0x00, 0xd5
2018-03-26 07:27:18.572 Info, Node002, Response RTT 35 Average Response RTT 35
2018-03-26 07:27:18.572 Info, Node002, Received SwitchBinary report from node 2: level=Off
2018-03-26 07:27:18.572 Detail, Node002, Initial read of value
2018-03-26 07:27:18.572 Detail, Node002, Expected reply and command class was received
2018-03-26 07:27:18.572 Detail, Node002, Message transaction complete
2018-03-26 07:27:18.572 Detail, Node002, Removing current message
2018-03-26 07:27:18.572 Detail, Node002, Notification: ValueChanged
2018-03-26 07:27:18.573 Detail, Node002, Query Stage Complete (Dynamic)
2018-03-26 07:27:18.573 Detail, Node002, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2018-03-26 07:27:18.573 Detail, Node002, QueryStage_Configuration
2018-03-26 07:27:18.573 Detail, Node002, QueryStage_Complete
2018-03-26 07:27:18.573 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2018-03-26 07:27:18.573 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2018-03-26 07:27:18.573 Info, Node query processing complete.
2018-03-26 07:27:18.573 Detail, Node002, Notification: NodeQueriesComplete
2018-03-26 07:27:18.573 Detail, contrlr, Notification: AllNodesQueried
I have two of these switches and they work fine. If I recollect correctly, I had to edit the manufacturer_specific.xml and copy the 14292-toggle-switch.xml file from github before they would pair.
I believe my switch is pairing (it shows up in the ZWave panel) but HA is not adding a switch device.
Switched to a new computer and moved this stick over, and still the same behavior. Any thoughts?
