Z-Wave graph (without the python)
3.1 is available on Github - let me know if it fixes the problem with blank screen please. Make sure to clear browser cache after uploading new version.
Issues addressed:
  • Fix for Javscript Error in Log, blank screen - “Uncaught SyntaxError: Unexpected token ‘<’” (hopefully)
  • Added ‘tap’ and ‘touchstart’ event for mobile devices. (Thank you @dennykorsukewitz!)
  • Changed the colors of legends and sub legends. #DarkMode (Thank you @dennykorsukewitz!)
In ozw there are no zwave.whatever entities any longer, this may make your task slightly harder.
Looks good, @AdamNaj thank you!
Well, good point!
As I said I’m not a programmer… sometimes I just get a code, try to analyse it and I’m able to modufy it by analogies… Now, some time ago I made modifications to another custom component, text-divider-row and I found there some code lines that take variable from theme (if exists) and otherwise use predefined value. A bit tricky as it seems to use different language, but perhaps this would be something reapplicable? here is the complete code (I marked with /MM/ comment line that shows how it is done, line 193):
Copyright (c) Microsoft Corporation.
Permission to use, copy, modify, and/or distribute this software for any
purpose with or without fee is hereby granted.
THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES WITH
REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF MERCHANTABILITY
AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY SPECIAL, DIRECT,
INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES WHATSOEVER RESULTING FROM
LOSS OF USE, DATA OR PROFITS, WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR
OTHER TORTIOUS ACTION, ARISING OUT OF OR IN CONNECTION WITH THE USE OR
PERFORMANCE OF THIS SOFTWARE.
function t(t,e,s,i){var n,r=arguments.length,o=r<3?e:null===i?i=Object.getOwnPropertyDescriptor(e,s):i;if("object"==typeof Reflect&&"function"==typeof Reflect.decorate)o=Reflect.decorate(t,e,s,i);else for(var a=t.length-1;a>=0;a--)(n=t[a])&&(o=(r<3?n(o):r>3?n(e,s,o):n(e,s))||o);return r>3&&o&&Object.defineProperty(e,s,o),o
 * @license
 * Copyright (c) 2017 The Polymer Project Authors. All rights reserved.
 * This code may only be used under the BSD style license found at
 * http://polymer.github.io/LICENSE.txt
 * The complete set of authors may be found at
 * http://polymer.github.io/AUTHORS.txt
 * The complete set of contributors may be found at
 * http://polymer.github.io/CONTRIBUTORS.txt
 * Code distributed by Google as part of the polymer project is also
 * subject to an additional IP rights grant found at
 * http://polymer.github.io/PATENTS.txt
 */}const e="undefined"!=typeof window&&null!=window.customElements&&void 0!==window.customElements.polyfillWrapFlushCallback,s=(t,e,s=null)=>{for(;e!==s;){const s=e.nextSibling;t.removeChild(e),e=s}},i=`{{lit-${String(Math.random()).slice(2)}}}`,n=`\x3c!--${i}--\x3e`,r=new RegExp(`${i}|${n}`);class o{constructor(t,e){this.parts=[],this.element=e;const s=[],n=[],o=document.createTreeWalker(e.content,133,null,!1);let l=0,h=-1,p=0;const{strings:u,values:{length:_}}=t;for(;p<_;){const t=o.nextNode();if(null!==t){if(h++,1===t.nodeType){if(t.hasAttributes()){const e=t.attributes,{length:s}=e;let i=0;for(let t=0;t<s;t++)a(e[t].name,"$lit$")&&i++;for(;i-- >0;){const e=u[p],s=d.exec(e)[2],i=s.toLowerCase()+"$lit$",n=t.getAttribute(i);t.removeAttribute(i);const o=n.split(r);this.parts.push({type:"attribute",index:h,name:s,strings:o}),p+=o.length-1}}"TEMPLATE"===t.tagName&&(n.push(t),o.currentNode=t.content)}else if(3===t.nodeType){const e=t.data;if(e.indexOf(i)>=0){const i=t.parentNode,n=e.split(r),o=n.length-1;for(let e=0;e<o;e++){let s,r=n[e];if(""===r)s=c();else{const t=d.exec(r);null!==t&&a(t[2],"$lit$")&&(r=r.slice(0,t.index)+t[1]+t[2].slice(0,-"$lit$".length)+t[3]),s=document.createTextNode(r)}i.insertBefore(s,t),this.parts.push({type:"node",index:++h})}""===n[o]?(i.insertBefore(c(),t),s.push(t)):t.data=n[o],p+=o}}else if(8===t.nodeType)if(t.data===i){const e=t.parentNode;null!==t.previousSibling&&h!==l||(h++,e.insertBefore(c(),t)),l=h,this.parts.push({type:"node",index:h}),null===t.nextSibling?t.data="":(s.push(t),h--),p++}else{let e=-1;for(;-1!==(e=t.data.indexOf(i,e+1));)this.parts.push({type:"node",index:-1}),p++}}else o.currentNode=n.pop()}for(const t of s)t.parentNode.removeChild(t)}}const a=(t,e)=>{const s=t.length-e.length;return s>=0&&t.slice(s)===e},l=t=>-1!==t.index,c=()=>document.createComment(""),d=/([ \x09\x0a\x0c\x0d])([^\0-\x1F\x7F-\x9F "'>=/]+)([ \x09\x0a\x0c\x0d]*=[ \x09\x0a\x0c\x0d]*(?:[^ \x09\x0a\x0c\x0d"'`<>=]*|"[^"]*|'[^']*))$/;function h(t,e){const{element:{content:s},parts:i}=t,n=document.createTreeWalker(s,133,null,!1);let r=u(i),o=i[r],a=-1,l=0;const c=[];let d=null;for(;n.nextNode();){a++;const t=n.currentNode;for(t.previousSibling===d&&(d=null),e.has(t)&&(c.push(t),null===d&&(d=t)),null!==d&&l++;void 0!==o&&o.index===a;)o.index=null!==d?-1:o.index-l,r=u(i,r),o=i[r]}c.forEach(t=>t.parentNode.removeChild(t))}const p=t=>{let e=11===t.nodeType?0:1;const s=document.createTreeWalker(t,133,null,!1);for(;s.nextNode();)e++;return e},u=(t,e=-1)=>{for(let s=e+1;s<t.length;s++){const e=t[s];if(l(e))return s}return-1};
 * @license
const _=new WeakMap,m=t=>"function"==typeof t&&_.has(t),f={},y={};
 * @license
class g{constructor(t,e,s){this.__parts=[],this.template=t,this.processor=e,this.options=s}update(t){let e=0;for(const s of this.__parts)void 0!==s&&s.setValue(t[e]),e++;for(const t of this.__parts)void 0!==t&&t.commit()}_clone(){const t=e?this.template.element.content.cloneNode(!0):document.importNode(this.template.element.content,!0),s=[],i=this.template.parts,n=document.createTreeWalker(t,133,null,!1);let r,o=0,a=0,c=n.nextNode();for(;o<i.length;)if(r=i[o],l(r)){for(;a<r.index;)a++,"TEMPLATE"===c.nodeName&&(s.push(c),n.currentNode=c.content),null===(c=n.nextNode())&&(n.currentNode=s.pop(),c=n.nextNode());if("node"===r.type){const t=this.processor.handleTextExpression(this.options);t.insertAfterNode(c.previousSibling),this.__parts.push(t)}else this.__parts.push(...this.processor.handleAttributeExpressions(c,r.name,r.strings,this.options));o++}else this.__parts.push(void 0),o++;return e&&(document.adoptNode(t),customElements.upgrade(t)),t}}
 * @license
 */const v=` ${i} `;class S{constructor(t,e,s,i){this.strings=t,this.values=e,this.type=s,this.processor=i}getHTML(){const t=this.strings.length-1;let e="",s=!1;for(let r=0;r<t;r++){const t=this.strings[r],o=t.lastIndexOf("\x3c!--");s=(o>-1||s)&&-1===t.indexOf("--\x3e",o+1);const a=d.exec(t);e+=null===a?t+(s?v:n):t.substr(0,a.index)+a[1]+a[2]+"$lit$"+a[3]+i}return e+=this.strings[t],e}getTemplateElement(){const t=document.createElement("template");return t.innerHTML=this.getHTML(),t}}
 * @license
 */const w=t=>null===t||!("object"==typeof t||"function"==typeof t),b=t=>Array.isArray(t)||!(!t||!t[Symbol.iterator]);class x{constructor(t,e,s){this.dirty=!0,this.element=t,this.name=e,this.strings=s,this.parts=[];for(let t=0;t<s.length-1;t++)this.parts[t]=this._createPart()}_createPart(){return new P(this)}_getValue(){const t=this.strings,e=t.length-1;let s="";for(let i=0;i<e;i++){s+=t[i];const e=this.parts[i];if(void 0!==e){const t=e.value;if(w(t)||!b(t))s+="string"==typeof t?t:String(t);else for(const e of t)s+="string"==typeof e?e:String(e)}}return s+=t[e],s}commit(){this.dirty&&(this.dirty=!1,this.element.setAttribute(this.name,this._getValue()))}}class P{constructor(t){this.value=void 0,this.committer=t}setValue(t){t===f||w(t)&&t===this.value||(this.value=t,m(t)||(this.committer.dirty=!0))}commit(){for(;m(this.value);){const t=this.value;this.value=f,t(this)}this.value!==f&&this.committer.commit()}}class N{constructor(t){this.value=void 0,this.__pendingValue=void 0,this.options=t}appendInto(t){this.startNode=t.appendChild(c()),this.endNode=t.appendChild(c())}insertAfterNode(t){this.startNode=t,this.endNode=t.nextSibling}appendIntoPart(t){t.__insert(this.startNode=c()),t.__insert(this.endNode=c())}insertAfterPart(t){t.__insert(this.startNode=c()),this.endNode=t.endNode,t.endNode=this.startNode}setValue(t){this.__pendingValue=t}commit(){if(null===this.startNode.parentNode)return;for(;m(this.__pendingValue);){const t=this.__pendingValue;this.__pendingValue=f,t(this)}const t=this.__pendingValue;t!==f&&(w(t)?t!==this.value&&this.__commitText(t):t instanceof S?this.__commitTemplateResult(t):t instanceof Node?this.__commitNode(t):b(t)?this.__commitIterable(t):t===y?(this.value=y,this.clear()):this.__commitText(t))}__insert(t){this.endNode.parentNode.insertBefore(t,this.endNode)}__commitNode(t){this.value!==t&&(this.clear(),this.__insert(t),this.value=t)}__commitText(t){const e=this.startNode.nextSibling,s="string"==typeof(t=null==t?"":t)?t:String(t);e===this.endNode.previousSibling&&3===e.nodeType?e.data=s:this.__commitNode(document.createTextNode(s)),this.value=t}__commitTemplateResult(t){const e=this.options.templateFactory(t);if(this.value instanceof g&&this.value.template===e)this.value.update(t.values);else{const s=new g(e,t.processor,this.options),i=s._clone();s.update(t.values),this.__commitNode(i),this.value=s}}__commitIterable(t){Array.isArray(this.value)||(this.value=[],this.clear());const e=this.value;let s,i=0;for(const n of t)s=e[i],void 0===s&&(s=new N(this.options),e.push(s),0===i?s.appendIntoPart(this):s.insertAfterPart(e[i-1])),s.setValue(n),s.commit(),i++;i<e.length&&(e.length=i,this.clear(s&&s.endNode))}clear(t=this.startNode){s(this.startNode.parentNode,t.nextSibling,this.endNode)}}class C{constructor(t,e,s){if(this.value=void 0,this.__pendingValue=void 0,2!==s.length||""!==s[0]||""!==s[1])throw new Error("Boolean attributes can only contain a single expression");this.element=t,this.name=e,this.strings=s}setValue(t){this.__pendingValue=t}commit(){for(;m(this.__pendingValue);){const t=this.__pendingValue;this.__pendingValue=f,t(this)}if(this.__pendingValue===f)return;const t=!!this.__pendingValue;this.value!==t&&(t?this.element.setAttribute(this.name,""):this.element.removeAttribute(this.name),this.value=t),this.__pendingValue=f}}class E extends x{constructor(t,e,s){super(t,e,s),this.single=2===s.length&&""===s[0]&&""===s[1]}_createPart(){return new T(this)}_getValue(){return this.single?this.parts[0].value:super._getValue()}commit(){this.dirty&&(this.dirty=!1,this.element[this.name]=this._getValue())}}class T extends P{}let A=!1;(()=>{try{const t={get capture(){return A=!0,!1}};window.addEventListener("test",t,t),window.removeEventListener("test",t,t)}catch(t){}})();class V{constructor(t,e,s){this.value=void 0,this.__pendingValue=void 0,this.element=t,this.eventName=e,this.eventContext=s,this.__boundHandleEvent=t=>this.handleEvent(t)}setValue(t){this.__pendingValue=t}commit(){for(;m(this.__pendingValue);){const t=this.__pendingValue;this.__pendingValue=f,t(this)}if(this.__pendingValue===f)return;const t=this.__pendingValue,e=this.value,s=null==t||null!=e&&(t.capture!==e.capture||t.once!==e.once||t.passive!==e.passive),i=null!=t&&(null==e||s);s&&this.element.removeEventListener(this.eventName,this.__boundHandleEvent,this.__options),i&&(this.__options=k(t),this.element.addEventListener(this.eventName,this.__boundHandleEvent,this.__options)),this.value=t,this.__pendingValue=f}handleEvent(t){"function"==typeof this.value?this.value.call(this.eventContext||this.element,t):this.value.handleEvent(t)}}const k=t=>t&&(A?{capture:t.capture,passive:t.passive,once:t.once}:t.capture)
 * @license
 */;function O(t){let e=U.get(t.type);void 0===e&&(e={stringsArray:new WeakMap,keyString:new Map},U.set(t.type,e));let s=e.stringsArray.get(t.strings);if(void 0!==s)return s;const n=t.strings.join(i);return s=e.keyString.get(n),void 0===s&&(s=new o(t,t.getTemplateElement()),e.keyString.set(n,s)),e.stringsArray.set(t.strings,s),s}const U=new Map,R=new WeakMap;
 * @license
 */const M=new
 * @license
class{handleAttributeExpressions(t,e,s,i){const n=e[0];if("."===n){return new E(t,e.slice(1),s).parts}if("@"===n)return[new V(t,e.slice(1),i.eventContext)];if("?"===n)return[new C(t,e.slice(1),s)];return new x(t,e,s).parts}handleTextExpression(t){return new N(t)}};
 * @license
 */"undefined"!=typeof window&&(window.litHtmlVersions||(window.litHtmlVersions=[])).push("1.2.1");const z=(t,...e)=>new S(t,e,"html",M)
 * @license
 */,j=(t,e)=>`${t}--${e}`;let $=!0;void 0===window.ShadyCSS?$=!1:void 0===window.ShadyCSS.prepareTemplateDom&&(console.warn("Incompatible ShadyCSS version detected. Please update to at least @webcomponents/[email protected] and @webcomponents/[email protected]."),$=!1);const q=t=>e=>{const s=j(e.type,t);let n=U.get(s);void 0===n&&(n={stringsArray:new WeakMap,keyString:new Map},U.set(s,n));let r=n.stringsArray.get(e.strings);if(void 0!==r)return r;const a=e.strings.join(i);if(r=n.keyString.get(a),void 0===r){const s=e.getTemplateElement();$&&window.ShadyCSS.prepareTemplateDom(s,t),r=new o(e,s),n.keyString.set(a,r)}return n.stringsArray.set(e.strings,r),r},I=["html","svg"],F=new Set,L=(t,e,s)=>{F.add(t);const i=s?s.element:document.createElement("template"),n=e.querySelectorAll("style"),{length:r}=n;if(0===r)return void window.ShadyCSS.prepareTemplateStyles(i,t);const o=document.createElement("style");for(let t=0;t<r;t++){const e=n[t];e.parentNode.removeChild(e),o.textContent+=e.textContent}(t=>{I.forEach(e=>{const s=U.get(j(e,t));void 0!==s&&s.keyString.forEach(t=>{const{element:{content:e}}=t,s=new Set;Array.from(e.querySelectorAll("style")).forEach(t=>{s.add(t)}),h(t,s)})})})(t);const a=i.content;s?function(t,e,s=null){const{element:{content:i},parts:n}=t;if(null==s)return void i.appendChild(e);const r=document.createTreeWalker(i,133,null,!1);let o=u(n),a=0,l=-1;for(;r.nextNode();){l++;for(r.currentNode===s&&(a=p(e),s.parentNode.insertBefore(e,s));-1!==o&&n[o].index===l;){if(a>0){for(;-1!==o;)n[o].index+=a,o=u(n,o);return}o=u(n,o)}}}(s,o,a.firstChild):a.insertBefore(o,a.firstChild),window.ShadyCSS.prepareTemplateStyles(i,t);const l=a.querySelector("style");if(window.ShadyCSS.nativeShadow&&null!==l)e.insertBefore(l.cloneNode(!0),e.firstChild);else if(s){a.insertBefore(o,a.firstChild);const t=new Set;t.add(o),h(s,t)}};window.JSCompiler_renameProperty=(t,e)=>t;const B={toAttribute(t,e){switch(e){case Boolean:return t?"":null;case Object:case Array:return null==t?t:JSON.stringify(t)}return t},fromAttribute(t,e){switch(e){case Boolean:return null!==t;case Number:return null===t?null:Number(t);case Object:case Array:return JSON.parse(t)}return t}},H=(t,e)=>e!==t&&(e==e||t==t),W={attribute:!0,type:String,converter:B,reflect:!1,hasChanged:H};class D extends HTMLElement{constructor(){super(),this._updateState=0,this._instanceProperties=void 0,this._updatePromise=new Promise(t=>this._enableUpdatingResolver=t),this._changedProperties=new Map,this._reflectingProperties=void 0,this.initialize()}static get observedAttributes(){this.finalize();const t=[];return this._classProperties.forEach((e,s)=>{const i=this._attributeNameForProperty(s,e);void 0!==i&&(this._attributeToPropertyMap.set(i,s),t.push(i))}),t}static _ensureClassProperties(){if(!this.hasOwnProperty(JSCompiler_renameProperty("_classProperties",this))){this._classProperties=new Map;const t=Object.getPrototypeOf(this)._classProperties;void 0!==t&&t.forEach((t,e)=>this._classProperties.set(e,t))}}static createProperty(t,e=W){if(this._ensureClassProperties(),this._classProperties.set(t,e),e.noAccessor||this.prototype.hasOwnProperty(t))return;const s="symbol"==typeof t?Symbol():"__"+t,i=this.getPropertyDescriptor(t,s,e);void 0!==i&&Object.defineProperty(this.prototype,t,i)}static getPropertyDescriptor(t,e,s){return{get(){return this[e]},set(s){const i=this[t];this[e]=s,this._requestUpdate(t,i)},configurable:!0,enumerable:!0}}static getPropertyOptions(t){return this._classProperties&&this._classProperties.get(t)||W}static finalize(){const t=Object.getPrototypeOf(this);if(t.hasOwnProperty("finalized")||t.finalize(),this.finalized=!0,this._ensureClassProperties(),this._attributeToPropertyMap=new Map,this.hasOwnProperty(JSCompiler_renameProperty("properties",this))){const t=this.properties,e=[...Object.getOwnPropertyNames(t),..."function"==typeof Object.getOwnPropertySymbols?Object.getOwnPropertySymbols(t):[]];for(const s of e)this.createProperty(s,t[s])}}static _attributeNameForProperty(t,e){const s=e.attribute;return!1===s?void 0:"string"==typeof s?s:"string"==typeof t?t.toLowerCase():void 0}static _valueHasChanged(t,e,s=H){return s(t,e)}static _propertyValueFromAttribute(t,e){const s=e.type,i=e.converter||B,n="function"==typeof i?i:i.fromAttribute;return n?n(t,s):t}static _propertyValueToAttribute(t,e){if(void 0===e.reflect)return;const s=e.type,i=e.converter;return(i&&i.toAttribute||B.toAttribute)(t,s)}initialize(){this._saveInstanceProperties(),this._requestUpdate()}_saveInstanceProperties(){this.constructor._classProperties.forEach((t,e)=>{if(this.hasOwnProperty(e)){const t=this[e];delete this[e],this._instanceProperties||(this._instanceProperties=new Map),this._instanceProperties.set(e,t)}})}_applyInstanceProperties(){this._instanceProperties.forEach((t,e)=>this[e]=t),this._instanceProperties=void 0}connectedCallback(){this.enableUpdating()}enableUpdating(){void 0!==this._enableUpdatingResolver&&(this._enableUpdatingResolver(),this._enableUpdatingResolver=void 0)}disconnectedCallback(){}attributeChangedCallback(t,e,s){e!==s&&this._attributeToProperty(t,s)}_propertyToAttribute(t,e,s=W){const i=this.constructor,n=i._attributeNameForProperty(t,s);if(void 0!==n){const t=i._propertyValueToAttribute(e,s);if(void 0===t)return;this._updateState=8|this._updateState,null==t?this.removeAttribute(n):this.setAttribute(n,t),this._updateState=-9&this._updateState}}_attributeToProperty(t,e){if(8&this._updateState)return;const s=this.constructor,i=s._attributeToPropertyMap.get(t);if(void 0!==i){const t=s.getPropertyOptions(i);this._updateState=16|this._updateState,this[i]=s._propertyValueFromAttribute(e,t),this._updateState=-17&this._updateState}}_requestUpdate(t,e){let s=!0;if(void 0!==t){const i=this.constructor,n=i.getPropertyOptions(t);i._valueHasChanged(this[t],e,n.hasChanged)?(this._changedProperties.has(t)||this._changedProperties.set(t,e),!0!==n.reflect||16&this._updateState||(void 0===this._reflectingProperties&&(this._reflectingProperties=new Map),this._reflectingProperties.set(t,n))):s=!1}!this._hasRequestedUpdate&&s&&(this._updatePromise=this._enqueueUpdate())}requestUpdate(t,e){return this._requestUpdate(t,e),this.updateComplete}async _enqueueUpdate(){this._updateState=4|this._updateState;try{await this._updatePromise}catch(t){}const t=this.performUpdate();return null!=t&&await t,!this._hasRequestedUpdate}get _hasRequestedUpdate(){return 4&this._updateState}get hasUpdated(){return 1&this._updateState}performUpdate(){this._instanceProperties&&this._applyInstanceProperties();let t=!1;const e=this._changedProperties;try{t=this.shouldUpdate(e),t?this.update(e):this._markUpdated()}catch(e){throw t=!1,this._markUpdated(),e}t&&(1&this._updateState||(this._updateState=1|this._updateState,this.firstUpdated(e)),this.updated(e))}_markUpdated(){this._changedProperties=new Map,this._updateState=-5&this._updateState}get updateComplete(){return this._getUpdateComplete()}_getUpdateComplete(){return this._updatePromise}shouldUpdate(t){return!0}update(t){void 0!==this._reflectingProperties&&this._reflectingProperties.size>0&&(this._reflectingProperties.forEach((t,e)=>this._propertyToAttribute(e,this[e],t)),this._reflectingProperties=void 0),this._markUpdated()}updated(t){}firstUpdated(t){}}D.finalized=!0;
 * @license
const J=(t,e)=>"method"===e.kind&&e.descriptor&&!("value"in e.descriptor)?Object.assign(Object.assign({},e),{finisher(s){s.createProperty(e.key,t)}}):{kind:"field",key:Symbol(),placement:"own",descriptor:{},initializer(){"function"==typeof e.initializer&&(this[e.key]=e.initializer.call(this))},finisher(s){s.createProperty(e.key,t)}};
@license
Copyright (c) 2019 The Polymer Project Authors. All rights reserved.
http://polymer.github.io/LICENSE.txt The complete set of authors may be found at
http://polymer.github.io/AUTHORS.txt The complete set of contributors may be
found at http://polymer.github.io/CONTRIBUTORS.txt Code distributed by Google as
part of the polymer project is also subject to an additional IP rights grant
found at http://polymer.github.io/PATENTS.txt
const X="adoptedStyleSheets"in Document.prototype&&"replace"in CSSStyleSheet.prototype,G=Symbol();class K{constructor(t,e){if(e!==G)throw new Error("CSSResult is not constructable. Use `unsafeCSS` or `css` instead.");this.cssText=t}get styleSheet(){return void 0===this._styleSheet&&(X?(this._styleSheet=new CSSStyleSheet,this._styleSheet.replaceSync(this.cssText)):this._styleSheet=null),this._styleSheet}toString(){return this.cssText}}const Q=(t,...e)=>{const s=e.reduce((e,s,i)=>e+(t=>{if(t instanceof K)return t.cssText;if("number"==typeof t)return t;throw new Error(`Value passed to 'css' function must be a 'css' function result: ${t}. Use 'unsafeCSS' to pass non-literal values, but\n            take care to ensure page security.`)})(s)+t[i+1],t[0]);return new K(s,G)};
 * @license
(window.litElementVersions||(window.litElementVersions=[])).push("2.3.1");const Y={};class Z extends D{static getStyles(){return this.styles}static _getUniqueStyles(){if(this.hasOwnProperty(JSCompiler_renameProperty("_styles",this)))return;const t=this.getStyles();if(void 0===t)this._styles=[];else if(Array.isArray(t)){const e=(t,s)=>t.reduceRight((t,s)=>Array.isArray(s)?e(s,t):(t.add(s),t),s),s=e(t,new Set),i=[];s.forEach(t=>i.unshift(t)),this._styles=i}else this._styles=[t]}initialize(){super.initialize(),this.constructor._getUniqueStyles(),this.renderRoot=this.createRenderRoot(),window.ShadowRoot&&this.renderRoot instanceof window.ShadowRoot&&this.adoptStyles()}createRenderRoot(){return this.attachShadow({mode:"open"})}adoptStyles(){const t=this.constructor._styles;0!==t.length&&(void 0===window.ShadyCSS||window.ShadyCSS.nativeShadow?X?this.renderRoot.adoptedStyleSheets=t.map(t=>t.styleSheet):this._needsShimAdoptedStyleSheets=!0:window.ShadyCSS.ScopingShim.prepareAdoptedCssText(t.map(t=>t.cssText),this.localName))}connectedCallback(){super.connectedCallback(),this.hasUpdated&&void 0!==window.ShadyCSS&&window.ShadyCSS.styleElement(this)}update(t){const e=this.render();super.update(t),e!==Y&&this.constructor.render(e,this.renderRoot,{scopeName:this.localName,eventContext:this}),this._needsShimAdoptedStyleSheets&&(this._needsShimAdoptedStyleSheets=!1,this.constructor._styles.forEach(t=>{const e=document.createElement("style");e.textContent=t.cssText,this.renderRoot.appendChild(e)}))}render(){return Y}}Z.finalized=!0,Z.render=(t,e,i)=>{if(!i||"object"!=typeof i||!i.scopeName)throw new Error("The `scopeName` option is required.");const n=i.scopeName,r=R.has(e),o=$&&11===e.nodeType&&!!e.host,a=o&&!F.has(n),l=a?document.createDocumentFragment():e;if(((t,e,i)=>{let n=R.get(e);void 0===n&&(s(e,e.firstChild),R.set(e,n=new N(Object.assign({templateFactory:O},i))),n.appendInto(e)),n.setValue(t),n.commit()})(t,l,Object.assign({templateFactory:q(n)},i)),a){const t=R.get(l);R.delete(l);const i=t.value instanceof g?t.value.template:void 0;L(n,l,i),s(e,e.firstChild),e.appendChild(l),R.set(e,t)}!r&&o&&window.ShadyCSS.styleElement(e.host)};console.info("%c  TEXT-DIVIDER-ROW  \n%c  Version 1.4.0     ","color: orange; font-weight: bold; background: black","color: white; font-weight: bold; background: dimgray");let tt=class extends Z{setConfig(t){if(!t||!t.text)throw new Error("Error in card configuration.");this._config=t}render(){return this._config?z`
      <h2 class="text-divider"><span>${this._config.text}</span></h2>
    `:z``}static get styles(){return Q`
      :host {
        display: block;
        position: relative;
        --divider-color: var(--text-divider-color, var(--secondary-text-color)); /*MM*/
        --font-size: var(--text-divider-font-size, 14px);
        --line-size: var(--text-divider-line-size, 1px);
        --font-weight: var(--text-divider-font-weight, normal);
        --margin-top: var(--text-divider-margin-top, 1em);
        --margin-bottom: var(--text-divider-margin-bottom, 1em);
        --text-divider-text: var(--text-divider-text, var(--divider-color));
      .text-divider {
        margin: 0;
        margin-top: var(--text-divider-margin-top);
        margin-bottom: var(--text-divider-margin-bottom);
        line-height: 0;
        text-align: center;
        white-space: nowrap;
        display: flex;
        align-items: center;
      .text-divider span {
        padding: 0.7em;
        color: var(--text-divider-text);
        font-size: var(--font-size);
        font-weight: var(--font-weight)
      .text-divider:before,
      .text-divider:after {
        content: '';
        background: var(--divider-color);
        display: block;
        height: var(--line-size);
        width: 100%;
    `}};var et,st;t([(t,e)=>void 0!==e?((t,e,s)=>{e.constructor.createProperty(s,t)})(et,t,e):J(et,t)],tt.prototype,"_config",void 0),tt=t([(st="text-divider-row",t=>"function"==typeof t?((t,e)=>(window.customElements.define(t,e),e))(st,t):((t,e)=>{const{kind:s,elements:i}=e;return{kind:s,elements:i,finisher(e){window.customElements.define(t,e)}}})(st,t))],tt);
Perhaps this will help?
3.2 is available on Github
Make sure to clear browser cache after uploading the new version.
Issues addressed:
  • Pinch to zoom added for the benefit of mobile device users
  • Touch has been made somewhat less eager to open the More Info dialog. Doesn’t happen on touch start but rather on tap. Otherwise, pinch-to-zoom was somewhat of a nightmare.
This sounds like a great technique. If you wanted to modify it this way, I’d love to incorporate your contribution!
Hello
I just tried to follow above for the z-wave graph and in particular this post:
I have the .js file in /config/www/ but when clicking the zwave graph panlen that showed up on the GUI it is just nothing there.
Also in the log i get messages like this
2020-10-18 15:57:22 ERROR (MainThread) [frontend.js.latest.202010012] https://192.168.1.89:8123/local/zwavegraph3.js:6:1 Uncaught SyntaxError: Unexpected token ‘<’
Suggestions are more than welcome :slight_smile:
I am facing the same problem… HA version 0.116.2
Are getting the same error message?
I under stand that the error is referenced somewhere in this post above but I cant find it… google points to it but I don’t know how to search these huge threads :confused:
Handy dandy search button at the top:
Tried that but could not find any hits in my duckduck search :frowning:
Anyway, reinstalled the .js and now itworkd´s fine!
Getting the same error here. Deleted the .js and config, restarted, reinstalled. same same…
2020-11-03 01:22:40 ERROR (MainThread) [frontend.js.latest.202010214] http://192.168.1.25:8123/local/zwavegraph3.js:6:1 Uncaught SyntaxError: Unexpected token ‘<’
Where is the value “not connected” based on? I have two devices that according to the Z-Wave Graph are not connected but work fine regardless. One is a AC switch.
Looking at the properties of the device I see no reason for it to classify as unconnected.
Getting the Unexpected token error as well. Tried to remove, reinstall, and reboot but had no luck.
Error:
Logger: frontend.js.latest.202011112
Source: components/system_log/init.py:193
First occurred: 1:14:54 PM (1 occurrences)
Last logged: 1:14:54 PM
http://homeassistant.local:8123/local/zwavegraph3.js:7:1 Uncaught SyntaxError: Unexpected token ‘<’
I had this same error and it was due to having the file in a sub directory of the root directory, once I moved it to the root directory the error went away and it started working.
So, you just moved it to the root of the config folder? Did you have to change anything in the configuration.yaml file?
I moved it to www also know as local folder. This is what my config looks like
panel_custom:
  - name: zwave-graph-panel
    sidebar_title: Z-Wave Graph
    sidebar_icon: mdi:access-point-network
    module_url: /local/zwavegraph3.js
    config:
      ranker: network-simplex
      edge_visibility: relevant
      grouping: z-wave
Ahh, yeah that’s where I have it and the yaml matches. Still getting the error.
this happens if you download the webpage that displays the code on github vs the actual .js file.
ie if you just used wget to pull the file onto your ha appliance try using something like:
wget https://raw.githubusercontent.com/AdamNaj/ZWaveGraphHA/master/zwavegraph3.js
That worked. Thank you!!!
