Hi all, sorry I havenāt been around much, work is keeping me busy.
Hereās an update which should fix the width issues for users with small z-wave networks.
<dom-module id='ha-panel-zwavegraph2'>
<template>
<style include="ha-style">
.node.Layer1 > rect, .node.Layer1 > circle
fill: lightblue;
.node.Layer2 > rect, .node.Layer2 > circle
fill: yellow;
.node.Layer3 > rect, .node.Layer3 > circle
fill: green;
.node.Layer4 > rect, .node.Layer4 > circle
fill: orange;
.node.Layer5 > rect, .node.Layer5 > circle
fill: grey;
.node.Error > rect, .node.Error > circle
fill: red;
.node.unset > rect, .node.unset > circle
fill: white;
.node > rect, .node > circle
stroke: black;
.node text
font-size: 12px;
.edgePath path {
stroke: #333;
fill: #333;
stroke-width: 1.5px;
</style>
<app-header-layout has-scrolling-region>
<app-header slot="header" fixed>
<app-toolbar>
<ha-menu-button narrow='[[narrow]]' show-menu='[[showMenu]]'></ha-menu-button>
<div main-title>Zwave Graph</div>
</app-toolbar>
</app-header>
<div class="content">
<svg id="svg"></svg>
</div>
</app-header-layout>
</template>
</dom-module>
<script src="https://d3js.org/d3.v4.min.js" charset="utf-8"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/dagre-d3/0.6.1/dagre-d3.js"></script>
<script>
class HaPanelZWave extends Polymer.Element {
static get is() { return 'ha-panel-zwavegraph2'; }
static get properties() {
return {
// Home Assistant object
hass: Object,
// If should render in narrow mode
narrow: {
type: Boolean,
value: false,
// If sidebar is currently shown
showMenu: {
type: Boolean,
value: false,
// Home Assistant panel info99
// panel.config contains config passed to register_panel serverside
panel: Object,
ready() {
super.ready();
var data=this.listNodes(this.hass);
var g = new dagreD3.graphlib.Graph().setGraph({});
g.graph().rankDir="BT";
g.graph().nodeSep=15;
for (var i = 0; i < data["nodes"].length; i++) {
var node=data["nodes"][i];
g.setNode(node.id, node);
for (var i =0; i< data["edges"].length; i++)
g.setEdge(data["edges"][i].from, data["edges"][i].to, {label:"", arrowhead: "undirected"})
// Create the renderer
var render = new dagreD3.render();
var svg=d3.select(this.$.svg);
var inner = svg.append("g").attr("transform", "translate(20,120)scale(1)");
g.graph().minlen = 0;
// Run the renderer. This is what draws the final graph.
render(inner, g);
// Add the title element to be used for a tooltip (SVG functionality)
inner.selectAll("g.node")
.append("title").html(function(d) {return g.node(d).title;});
svg.attr('height', g.graph().height + 140);
svg.attr('width', g.graph().width + 140);
var legends=[{shape: "rect", color:"lightblue", text:"Hub"},
{shape: "rect", color:"yellow", text:"1 hop"},
{shape: "rect", color:"green", text:"2 hops"},
{shape: "rect", color:"orange", text:"3 hops"},
{shape: "rect", color:"grey", text:"4 hops"},
{shape: "rect", color:"red", text:"Failed Node"},
{shape: "rect", color:"white", text:"Unconnected"}];
this.addLegend(svg, legends, 5, 20);
legends = [{shape: "circle", text: "Mains power", color: "black"},
{shape: "rect", text: "Battery power", color: "black"}]
this.addLegend(svg, legends, svg.attr("width")*.75, 20)
addLegend(svg, legends, startX, startY)
for(var counter=0;counter < legends.length;counter++)
if (legends[counter].shape == "circle")
svg.append(legends[counter].shape)
.attr('cx', startX + 5 )
.attr('cy',startY + 5 + 20 * counter)
.attr('r', 5)
.style("stroke", "black")
.style("fill", legends[counter].color);
else
.attr('x',startX)
.attr('y',startY + 20 * counter)
.attr('width', 10)
.attr('height', 10)
svg.append('text')
.attr("x", startX + 20)
.attr("y", startY + 10 + 20*counter)
.text(legends[counter].text)
.attr("class", "textselected")
.style("text-anchor", "start")
.style("font-size", 15);
listNodes(hass) {
let states=new Array();
for (let state in hass.states)
states.push({name:state, entity:hass.states[state]});
let zwaves = states.filter((s) => {return s.name.indexOf("zwave.") ==0});
let result= {"edges":[], "nodes":[]};
let hubNode=0;
let neighbours={};
for (let b in zwaves)
let id=zwaves[b].entity.attributes["node_id"];
let node = zwaves[b].entity;
if (node.attributes["capabilities"].filter(
(s) => {return s =="primaryController"}).length > 0)
hubNode=id;
neighbours[id]=node.attributes['neighbors'];
let entities = states.filter((s) => {
return ((s.name.indexOf("zwave.") == -1) &&
(s.entity.attributes["node_id"] == id)) });
let batlev=node.attributes.battery_level;
let entity={"id": id,
"label": (node.attributes["node_name"] + " (" + node.attributes["averageResponseRTT"]+"ms)").replace(/ /g, "\n"),
"class": "unset",
"shape": batlev != undefined ? "rect" : "circle",
"title": "<b>"+node.attributes["node_name"]+"</b>" +
"<br />Node: " + id + (node.attributes["is_zwave_plus"] ? "+" : "") +
"<br />Product Name: " + node.attributes["product_name"] +
"<br />Average Request RTT: " + node.attributes["averageResponseRTT"]+"ms" +
"<br />Power source: " + (batlev != undefined ? "battery (" + batlev +"%)" : "mains") +
"<br />" + entities.length + " entities",
"forwards": (node.attributes.is_awake && node.attributes.is_ready && !node.attributes.is_failed &&
node.attributes.capabilities.includes("listening"))
if (node.attributes["is_failed"])
entity.label = "FAILED: "+entity.label;
entity["font.multi"]=true;
entity["title"]="<b>FAILED: </b>"+entity.title;
entity["group"]="Failed";
if (hubNode == id)
entity.label="ZWave Hub";
entity.borderWidth= 2;
entity.fixed=true;
result.nodes.push(entity);
if (hubNode > 0)
let layer=0;
let previousRow=[hubNode];
let mappedNodes=[hubNode];
while (previousRow.length > 0)
layer = layer+1;
let nextRow=[];
for (let target in previousRow)
result.nodes.filter((n) => {return ((n.id ==previousRow[target]) && (n.group="unset"))})
.every((d) => {d.class="Layer" + layer;})
if (result.nodes.filter((n) => {return ((n.id == previousRow[target]) && (n.forwards))}).length > 0)
let row=neighbours[previousRow[target]];
for (let node in row)
if (!mappedNodes.includes(row[node]))
result.edges.push({"from":row[node], "to":previousRow[target]});
nextRow.push(row[node]);
for (let idx in nextRow)
mappedNodes.push(nextRow[idx]);
previousRow = nextRow;
return result;
customElements.define(HaPanelZWave.is, HaPanelZWave);
</script>
