They will appear like that every time you restart Home Assistant and will remain this way to the moment they wake up and report their neighbors. Once they wake up for the first time, they will fall into place.
Thanks for the clarification works great so far
I just get a blank page. api/panel_custom/zwave
request returns 200 but empty response. This is using @AdamNaj latest gist
Which browser are you using? I noticed it doesnât render on my iPad in the HA app (Safari I assume).
Works on my PC on Firefox.
thank you so much. Its very easy to setup and works great. Nice work!
Any idea why the nodes are overlapping the legend?
Just installed everything this evening. It all looks great and I was able to integrate it pretty easily after digging through this post. The battery visualization is really a neat feature to have. So far no issues, but will report after some usage.
One questions I have in regards to you last postâhow is it that one can go about adding the rooms within the z-wave config? Is this something that has to be performed manually?
Ran into some weirdness when I implemented this in my Home Assistant environment.
2018-12-24 08:54:58 ERROR (MainThread) [frontend.js.latest.201812112] http://homeassistant.example.com:8123/api/panel_custom/zwavegraph2:173:15 Uncaught ReferenceError: dagreD3 is not defined
I can see my nodes but thereâs no mesh data between them. Is anyone else getting this error?
You need to edit the Open Z-Wave config and for nodes that you want to listed in a group fill-in the location attribute.
<Node id="4" name="Living Room TV Plug" location="Living Room" ...>
</Node>
Great, thanks for the confirmation. I did see that currently the z-wave node lists the location as location="". Iâll go through and update and see how that all pans out.
Hi!
What file is it that I need to edit?
The /config/zwcfg_*.xml?
Tried it, but the locations are reset to ââ each time i restart Hass, and the grouping is not showing up in the graph.
Could you give me some pointers?
Thanks!
Thatâs because this file is technically a cache for the Z-Wave state and HA saves it before shutting down.
You need to stop Home Assistant, edit the file and then start it again.
Thanks!
Now got the location to stick, but the grouping is still not showing up however.
screenshot of the OZW settings file
I downloaded the latest html version earlier today from gist
Try clearing out the browser cache.
I was getting the same. No connections until I used AdamNajâs grouped version, Now it works.
I am not entirely sure what I am doing wrong but on chrome it shows " Error while loading this panel." when I go on the tab. I copy pasted the github one into panels and put the other part into my configurations.yaml. It also shows no errors in the log file.
did you copy from the raw format on github?
It was my browerâs cache. I tried everything but after clearing it it just worked. Donât ask me
Appears that all of my devices show as unconnected devices even though some are not. Any suggestions?
