Z Wave help needed!
Need a hand with Z-wave issues using a HUSBZB-1 stick. Zigbee devices working fine but my z-wave devices became undetectable.
I reset the only z wave device I have running to try and “repair” it (which didn’t work) then found the actual integration in HA to also be unresponsive to the stick. I then uninstalled the z wave integration and tried reinstalling and haven’t been able since. Keep getting the following errors.
I clicked around the ui for days to see if an obvious fix was there. Clearly nothing. I’ve googled and searched for days but don’t see an obvious path the follow.
Any help or direction would be greatly appreciated! Thanks in advance!
Can you share the addon logs? Are you maybe using ZWaveJS UI as well? What USB path is configured?
And for when you get ZWave JS back up and running what devices (down to model number if you have it) are giving you an issue?
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[08:04:32] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[08:04:34] INFO: Virtual Machine detected, disabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[08:04:34] INFO: Successfully send discovery information to Home Assistant.
2022-12-08T13:04:38.294Z DRIVER   ███████╗ ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗             ██╗ ███████╗
2022-12-08T13:04:38.304Z DRIVER   version 10.3.0
2022-12-08T13:04:38.305Z DRIVER
2022-12-08T13:04:38.450Z CONFIG   version 10.3.0
2022-12-08T13:04:40.436Z CNTRLR   querying controller IDs...
2022-12-08T13:04:41.875Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2022-12-08T13:04:52.001Z CNTRLR   No response from controller after 2/3 attempts. Scheduling next try in 1100 ms
2022-12-08T13:04:53.122Z DRIVER   unexpected response, discarding...
2022-12-08T13:04:54.127Z DRIVER   Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
                                  from the controller (ZW0200)
                                      at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Drive
                                  r.ts:3990:23)
                                      at ZWaveController.identify (/usr/src/node_modules/zwave-js/src/lib/contro
                                  ller/Controller.ts:713:33)
                                      at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src
                                  /lib/driver/Driver.ts:1208:26)
                                      at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Dr
                                  iver.ts:1015:16)
Error in driver ZWaveError: Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
    at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:3990:23)
    at ZWaveController.identify (/usr/src/node_modules/zwave-js/src/lib/controller/Controller.ts:713:33)
    at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1208:26)
    at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1015:16) (ZW0100)
    at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1032:6)
    at processTicksAndRejections (node:internal/process/task_queues:96:5) {
  code: 100,
  context: undefined,
  transactionSource: undefined
Shutting down
[13:04:54] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
[13:04:54] INFO: Service restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
I’m running only the zooz 4-in-1
Zooz 700 Series Z-Wave Plus 4-in-1 Sensor ZSE40 (Motion / Light / Temperature / Humidity) https://a.co/d/gi8U0YU
Please let me know if I shared the correct log file or not. I’m somewhat new to this. Thanks so much in advance for your help!
What kind of VM solution are you using? Have you tried reconnecting the HUSBZB-1 stick? How is it passed to HA? What path(s) are configured for the Z-Wave and Zigbee addons?
It’s one of the correct logs.
Here’s what I see - rather what I don’t.
I don’t see zwavejs griping about not ‘seeing’ your port or not able to ‘open’ the port.
Instead comms are failing when the service tries to talk to your stick.
Are you using a USB extension cord or USB hub or is the stick plugged directly into your host?
Plugged directly into the computer. It’s always been like this (for over 1 year now) and never been a problem.
As I mentioned above, the Zigbee component of this stick works great.
I feel it’s a software issue that I simply am too naive to know where to look.
VM running in unraid.
What you’re seeing is either:
Vm can’t talk to usb stick.
For this make sure. Your Vm solution is properly allowing the USB device to be mounted by your Vm.
HA can’t talk to USB stick -
This is usually either configuration
Check that you are using the By-id path to your stick and not the shorthand port identification. (sometimes the port can change, especially in VM land, ByID prevents this)
Or
USB interference - short extension /USB hub is usually enough to mitigate this.
So out of those, the cheapest and easiest ways to try to fix this - verify you are using the by-id path and then put in a short USB cable between the machine and the device… There’s long standing issues with these sticks and USB bus interference.
The errors you display are a dead ringer for what people see when interference is causing issues. Also let’s just say the nortek combination stick isn’t the best of the bunch.
When you get that done is the Aeotec USB or battery powered.
thanks for the reply!
i ensured that the proper by-id was selected (coincidentally there are two duplicate paths, in addition to the generic shorthand). i’ve tried to do this process using both by-id’s and still it timed out.
i also added the usb extenson prior to doing all this, rebooted the server, and rebooted the VM a few times.
is the final line of your reply suggesting a different (Aeotec) device in place of the one I have? I am more than happy to replace this with another stick / hub if that was the solution.
thanks again for your help!
figured it out. I turned OFF Watchdog. That seemingly did the trick.
