I’ve got a fresh install of Home Assistant (OS) running. The ZigBee part of my husbzb-1 works fine. The Z-Wave is giving me problems. Everything seems to be installed fine but I cannot add devices. I’ve started the inclusion progress but nothing gets detected. I’ve tried a Walli dimmer and two Fibaro Wall Plugs. None of them seem to get detected. All of the devices are reset to factory defaults.
Anyone got any pointers where to look for the problem?
2022-01-07T15:55:39.992Z CNTRLR Performing soft reset...
2022-01-07T15:55:40.025Z CNTRLR Waiting for the controller to reconnect...
2022-01-07T15:55:41.110Z CNTRLR reconnected and restarted
2022-01-07T15:55:41.159Z CNTRLR querying version info...
2022-01-07T15:55:41.188Z CNTRLR received version info:
controller type: Static Controller
library version: Z-Wave 6.10
2022-01-07T15:55:41.190Z CNTRLR supported Z-Wave features:
· SmartStart
2022-01-07T15:55:41.191Z CNTRLR querying controller capabilities...
2022-01-07T15:55:41.247Z CNTRLR received controller capabilities:
controller role: primary
is in other network: false
is SIS present: true
was real primary: false
is a SUC: true
2022-01-07T15:55:41.249Z CNTRLR querying serial API setup capabilities...
2022-01-07T15:55:41.307Z CNTRLR supported serial API setup commands:
· GetSupportedCommands
· SetTxStatusReport
· SetPowerlevel
· GetPowerlevel
· GetMaximumPayloadSize
2022-01-07T15:55:41.308Z CNTRLR Enabling TX status report...
2022-01-07T15:55:41.351Z CNTRLR Enabling TX status report successful...
2022-01-07T15:55:41.352Z CNTRLR finding SUC...
2022-01-07T15:55:41.413Z CNTRLR This is the SUC
2022-01-07T15:55:41.413Z CNTRLR querying node information...
2022-01-07T15:55:41.501Z CNTRLR received node information:
controller is a SUC: true
controller is a slave: false
controller supports timers: false
nodes in the network: 1
2022-01-07T15:55:41.535Z CNTRLR [Node 001] Embedded device config loaded
2022-01-07T15:55:41.552Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2022-01-07T15:55:41.579Z CNTRLR serial API timeouts overwritten. The old values were: ack = 1500 ms, byte = 15
0 ms
2022-01-07T15:55:41.579Z CNTRLR Interview completed
Starting server on 0.0.0.0:3000
2022-01-07T15:55:41.613Z CNTRLR [Node 001] The node is alive.
2022-01-07T15:55:41.615Z CNTRLR [Node 001] The node is ready to be used
2022-01-07T15:55:41.616Z CNTRLR All nodes are ready to be used
ZwaveJS server listening on 0.0.0.0:3000
New client
2022-01-07T15:57:29.265Z CNTRLR Starting inclusion process with strategy Default...
2022-01-07T15:57:29.316Z CNTRLR The controller is now ready to add nodes
2022-01-07T15:58:29.857Z CNTRLR stopping inclusion process...
2022-01-07T15:58:29.947Z CNTRLR The inclusion process was stopped
