I had generated a unique key at the very beginning.
I actually got the lock to show up now by setting remove node, pressing the pair button, waiting a few seconds, setting ‘add node secure’, pressing the pair button, waiting 45-60 sec until zwave log activity stopped, and then restarting Hass. After this the lock shows up, but shows a ‘Dead (CacheLoad)’ status under the Zwave section in States.
If I try a ‘Heal Network’ I get this in the logs:
2017-10-27 14:38:19.049 Detail, Node001, Queuing (Controller) Request Node Neighbor Update
2017-10-27 14:38:19.051 Info, Requesting Neighbor Update for node 1
2017-10-27 14:38:19.051 Detail, Node002, Queuing (Controller) Request Node Neighbor Update
2017-10-27 14:38:19.052 Detail, Node001, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x11, 0xa2
2017-10-27 14:38:19.053 Detail, Notification: ControllerCommand - Starting
2017-10-27 14:38:19.072 Detail,
2017-10-27 14:38:19.073 Info, Node001, Sending (Command) message (Callback ID=0x11, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=1): 0x01, 0x05, 0x00, 0x48, 0x01, 0x11, 0xa2
2017-10-27 14:38:19.103 Detail, Node001, Received: 0x01, 0x05, 0x00, 0x48, 0x11, 0x21, 0x82
2017-10-27 14:38:19.104 Detail,
2017-10-27 14:38:19.105 Info, Node001, REQUEST_NEIGHBOR_UPDATE_STARTED
2017-10-27 14:38:19.106 Detail, Node033, Expected callbackId was received
2017-10-27 14:38:19.107 Detail, Node033, Expected reply was received
2017-10-27 14:38:19.108 Detail, Node033, Message transaction complete
2017-10-27 14:38:19.109 Detail, Node001, Removing current message
2017-10-27 14:38:19.111 Detail, Notification: ControllerCommand - InProgress
2017-10-27 14:38:41.625 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0x11, 0x23, 0x80
2017-10-27 14:38:41.626 Detail,
2017-10-27 14:38:41.627 Warning, WARNING: REQUEST_NEIGHBOR_UPDATE_FAILED
2017-10-27 14:38:41.628 Detail, Notification: ControllerCommand - Failed
2017-10-27 14:38:41.632 Info, Requesting Neighbor Update for node 2
2017-10-27 14:38:41.633 Detail, Node002, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=2): 0x01, 0x05, 0x00, 0x48, 0x02, 0x12, 0xa2
2017-10-27 14:38:41.634 Detail, Notification: ControllerCommand - Starting
2017-10-27 14:38:41.638 Error, Node002, ERROR: Dropping command because node is presumed dead
2017-10-27 14:38:41.639 Detail, Node002, Removing current message
2017-10-27 14:38:41.640 Detail, Notification: ControllerCommand - Error - Failed
