Hi from Cyprus. My new installation is driving me nuts. The output from the OZW log is below. This appears to open the serial port…but then the driver fails. I haven’t managed to find out why.
Any ideas please?
2019-09-30 17:18:12.768 Always, OpenZwave Version 1.4.3440 Starting Up
2019-09-30 17:18:22.480 Info, Setting Up Provided Network Key for Secure Communications
2019-09-30 17:18:22.489 Info, mgr, Added driver for controller /dev/ttyAMA0
2019-09-30 17:18:22.489 Info, Opening controller /dev/ttyAMA0
2019-09-30 17:18:22.490 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2019-09-30 17:18:22.490 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2019-09-30 17:18:22.492 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-09-30 17:18:22.492 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-09-30 17:18:22.492 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-09-30 17:18:22.492 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-09-30 17:18:22.492 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-09-30 17:18:22.493 Detail,
2019-09-30 17:18:22.493 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-09-30 17:18:22.496 Detail, contrlr, Notification: DriverFailed
