According to the instructions (https://www.home-assistant.io/docs/z-wave/installation) Z-Wave can be set up either through the GUI or through the configuration.yaml file. I configured it through the GUI and thought I would see how it was printed in configuration.yaml afterwards. Weird enough, there is nothing there. This is very surprising to me, and not how I would want it to be. One obvious backside is that I have been unable to see what path I used for the port of my controller. Am I missing something? Where is this configuration stored instead?
I came across the same problem: ZWave stick USB port now configurable via GUI?
In short, it’s now stored in config/.storage/core.config_entries in HASS.IO
dumb question: does the answer only apply to HASS.IO and not Hassbian? Because I don’t see the config directory in my environment:
Not sure if it also applies to Hassbian, but it’s a hidden folder, so you need to ls with whatever parameter Linux needs to also show hidden folders.
You may need to be root or “sudo ls”.
Try again, but not ‘ls’ but ‘ls -a’ in the same location.
The folder is called ‘.storage’ and the leading dot has the convention in linux systems that it is hidden by default. The -a parameter to ls tells it to also show hidden items.
