Tried upgrading from 0.1.7 to 0.1.10 and climate now shows unavailable? Still showing the battery level. Went back to 0.1.7 and the problem was solved.
For thermostats and some RGB devices, the 0.1.10 add-on isn’t compatible with HA 2021.2.X. You’ll need to wait for 2012.3 or use the current HA beta.
Thank you for the update. Is there a place that shows that info.
I have thermostats from Heatit and Mulitreg and they didn’t work with the latest version of z-wave js either.
Restored from snapshot and it’s ok.
Something I will have to fix manually with this version of z-wave js or is there a fix coming? Also using climate. for my entites/thermostats.
