After migration Z-Wave, followed instruction Z-Wave legacy (1.4) -> Z-Wave JS Official add-on. Most of the devices are able to detect normally but Aeotec WallMote Quad(ZW130). Digging some posts, here is what I did.
Press and hold the action button in the back of the ZW130 for 2 secs until the orange led flash. Get into wake up mode. You could check the log under Z-Wave JS add-on to see it completes the interview process… Picture
(option) In Developer Tools, you could check the events and listen to "zwave_js_event ". Press any button on the ZW130 and the event should pop out.
I used automation to manage the buttons.
Example: touch Button 1
platform: event
event_type: zwave_js_event
event_data:
node_id: 17
label: Scene 001
After upgraded the OS to 2021.3.0 and Z-Wave JS to 0.1.10, it seems the zwave_js_event has changed. The message is now property_key: "001" instead of label: Scene 001
I just moved to the zwave js add-on and the WallMote is one of the few items that is stuck in “Node Awake: No.” status. When I put mine into wake up mode, by holding the button until it flashes orange, I get :
11:51:48.653 CNTRLR « [Node 014] received wakeup notification
I’ve left it flashing orange for 10 minutes, but nothing else is showing in the logs. How long did it take for yours to wake up and join?
UPDATE: I ended up just doing a reset on the WallMote and then rejoining the network and that worked just fine.
Updated the OS to 2021.4.1 and JS to 0.1.17. The Wallmote isn’t working anymore. After change the event value from zwave_js_event to zwave_js_value_notification everything goes fine now.
Would also like to know if the long-press still works as I currently use that.
Also is this actually compatible, as the device isnt listed on the ZWave JS device list
I can’t get this working at all… i have tried re-connecting it 20 times but i just get the battery status, and nothing from the bottons. When i try to listen to “zwave_js_event” there is nothing displayed.
How did you guys solve it? Using Zwave JS.
WallMote Quad: Battery level
100,0 %
WallMote Quad: Low battery level
Normal
WallMote Quad: Power Management - Battery is charging
WallMote Quad: Power Management - Battery is fully charged
WallMote Quad: Power Management - Charge battery now
WallMote Quad: Power Management - Charge battery soon
sensor.node_16_node_status
sensor.wallmote_quad_power_management_battery_level_status
Thanks!
Edit, nevermind! I tried one more time and then i wen’t to the logs, and i saw it there! Works awesome
I’ve not been able to get this to work and it seems to post no notifications when listening on ‘zwave_js_value_notification’ but if anyone has been able to get this to work would love to hear
I’d also like to see slide functionality working in home assistant. It works well using Hubitat (using a script) but since I’ve migrated over to HA I can’t see how I can get this to function.
Please elaborate. What do you see in the logs? I too have only the 5 or 6 entities connected to battery status. Where do I find my node Id and buttons?
Hmm well, i can’t really remember now how i did it or what logs i checked, since it was some problems away… but i use this blueprint to controll the WallMote, and it works perfect. Try if it solves you’r problem.
Slide does not work because no event is fired. The device when interviewed never shows it supports MultilevelSwitchCC. When you start the swipe up on the remote it sends a MultilevelSwitchCC::StartLevelChange with direction “up” and when stop swiping it sends a MultilevelSwitchCC StopLevelChange. When you start swiping down it sends a MultilevelSwitchCC::StartLevelChange with direction “down” and when you stop it sends a MultilevelSwitchCC StopLevelChange.
How do we force a device to have a given command class? I can’t pick MultilevelSwitch even after re-interview.
Here’s a snippet from the logs.
–Start Swipe Up
2022-12-16T08:37:43.912Z DRIVER « [Node 079] [REQ] [ApplicationCommand]
└─[MultilevelSwitchCCStartLevelChange]
startLevel: 0 (ignored)
direction: up
duration: 2s
2022-12-16T08:37:43.915Z CNTRLR [Node 079] treating MultilevelSwitchCC::StartLevelChange as a notification
2022-12-16T08:37:43.917Z CNTRLR [Node 079] [Notification] Multilevel Switch
event type: Start level change
direction: up
The log snippet shows the device is sending the documented Multilevel Switch commands, the controller receives it, and sends its own Start level change, and Stop level change Notification events. Did you try listening for zwave_js_notification events in HA?
Is there a way to configure the association groups using the Zwave JS control panel?
I’d like to have the button press and long press call directly to some lights rather than go via home assistant.
I was using the Vera edge controller, but they stopped this from working by disabling the admin login via their cloud service. So I’ve got a Zooz 800 usb stick and am using the Zwave integration. During the migration, all my devices have got new IDs and the Wallmote has been reset and no longer has its associations.
