I have no suggestions regarding device_id and defer to your decision. I was in the process of streamlining the template and wondered why device_id wasn’t used.
I don’t have the appropriate gadgetry to test this but I believe it should work as well as the original version.
- variables:
scene_id: '{{ trigger.event.data.scene_id }}'
- condition: template
value_template: >
{{ trigger.event.data.node_id == (ozw_node_id | int) and
trigger.event.data.scene_value_id == 1 }}
- choose:
- conditions: '{{ scene_id == 1 }}'
sequence: !input 'button_1'
- conditions: '{{ scene_id == 2 }}'
sequence: !input 'button_2'
- conditions: '{{ scene_id == 3 }}'
sequence: !input 'button_3'
- conditions: '{{ scene_id == 4 }}'
sequence: !input 'button_4'
All four choices in choose had two common conditions so I moved them out of choose and to a separate condition. If it evaluates to false then there’s no reason for the action to execute choose. The template also employs the new shorthand notation for Template Conditions.
EDIT
Corrected improperly defined Template Condition.
