Based on existing inovelli blueprints by @vbflo and @kylerw, this is a basic blueprint for the Inovelli Red Series LZW31-SN Dimmer, specifically for use with OZW.
Use this blueprint to configure actions when a scene is activated.
- updated 2020-12-21 based on these suggestions by @123
This blueprint could use improvement!
At this time, it is not possible to obtain the node's id when using the device selector.
- The list of available dimmers is for reference only.
- The node id must be entered manually.
blueprint:
name: Inovelli Red Series LZW31-SN Dimmer
description: Create automations for the Inovelli Red Series LZW31-SN Dimmer using the OZW integration.
domain: automation
input:
inovelli_switch:
description: "List of available inovelli LZW31-SN dimmers.
This list is only a reference. At this time, it is not possible
to obtain the node's id using the device selector."
selector:
device:
integration: ozw
manufacturer: Inovelli
model: LZW31-SN Dimmer Red Series
ozw_node_id:
description: "Enter the node id for an available LZW31-SN dimmer you wish
to configure. For now, this field is required. At this time, it is not
possible to obtain the node's id when using the device selector."
## Config Press 1 time
config_button:
name: Button C - Config press 1x
description: "Action to run, when the config button is pressed one time."
default: []
selector:
action: {}
## Paddle Press 1 time
button_a:
name: Button A - Up/On press 1x
description: "Action to run, when the button is pressed one time.
Typically, you will only set this if you have disabled the relay."
default: []
selector:
action: {}
button_b:
name: Button B - Down/Off press 1x
default: []
selector:
action: {}
## Paddle Held Down
button_a_held:
name: Button A - Up/On held down
description: "Action to run, when the button is held down.
default: []
selector:
action: {}
button_b_held:
name: Button B - Down/Off held down
default: []
selector:
action: {}
## Paddle Press 2 times
button_a2:
name: Button A - Up/On press 2x
description: "Action to run, when the button is pressed two times."
default: []
selector:
action: {}
button_b2:
name: Button B - Down/Off press 2x
default: []
selector:
action: {}
## Paddle Press 3 times
button_a3:
name: Button A - Up/On press 3x
description: "Action to run, when the button is pressed three times."
default: []
selector:
action: {}
button_b3:
name: Button B - Down/Off press 3x
default: []
selector:
action: {}
## Paddle Press 4 times
button_a4:
name: Button A - Up/On press 4x
description: "Action to run, when the button is pressed four times."
default: []
selector:
action: {}
button_b4:
name: Button B - Down/Off press 4x
default: []
selector:
action: {}
## Paddle Press 5 times
button_a5:
name: Button A - Up/On press 5x
description: "Action to run, when the button is pressed five times."
default: []
selector:
action: {}
button_b5:
name: Button B - Down/Off press 5x
default: []
selector:
action: {}
mode: single
max_exceeded: silent
variables:
device_id: !input inovelli_switch
ozw_node_id: !input ozw_node_id
- platform: event
event_type: ozw.scene_activated
condition: "{{ trigger.event.data.node_id == (ozw_node_id | int) }}"
- variables:
scene_id: "{{ trigger.event.data.scene_id }}"
scene_value_id: "{{ trigger.event.data.scene_value_id }}"
- choose:
- conditions: '{{ scene_id == 3 and scene_value_id == 1 }}'
sequence: !input config_button
- conditions: '{{ scene_id == 2 and scene_value_id == 1 }}'
sequence: !input button_a
- conditions: '{{ scene_id == 1 and scene_value_id == 1 }}'
sequence: !input button_b
- conditions: '{{ scene_id == 2 and scene_value_id == 3 }}'
sequence: !input button_a_held
- conditions: '{{ scene_id == 1 and scene_value_id == 3 }}'
sequence: !input button_b_held
- conditions: '{{ scene_id == 2 and scene_value_id == 4 }}'
sequence: !input button_a2
- conditions: '{{ scene_id == 1 and scene_value_id == 4 }}'
sequence: !input button_b2
- conditions: '{{ scene_id == 2 and scene_value_id == 5 }}'
sequence: !input button_a3
- conditions: '{{ scene_id == 1 and scene_value_id == 5 }}'
sequence: !input button_b3
- conditions: '{{ scene_id == 2 and scene_value_id == 6 }}'
sequence: !input button_a4
- conditions: '{{ scene_id == 1 and scene_value_id == 6 }}'
sequence: !input button_b4
- conditions: '{{ scene_id == 2 and scene_value_id == 7 }}'
sequence: !input button_a5
- conditions: '{{ scene_id == 1 and scene_value_id == 7 }}'
sequence: !input button_b5
Blueprint Preview
You do not have to configure every action when using this blueprint.
