Previous to the new Z-Wave JS integration, I was using the legacy Z-wave system. Through this system, home assistant was able to gather some hardware info from each node, particularly one of the attributes was the battery level of the node. I used this attribute of the node for automations, specifically to let me know when one node had a low battery level. This new Z-wave JS server system though doesn’t seem to poll for hardware info, and I’m currently unable to tell the battery level of my nodes. Does anyone have any suggestions? This might be a better question for the guy who made the Z-WaveJSMQTT system, but I thought I’d start here.
Battery levels have been their own sensors in zwave for a long time now, as well as in ozw and now zwave-js. There shouldn’t be any need to use the zwave battery attribute even now.
For all integrations you should see some sensor (percentage) and for zwave-js there may be an additional binary_sensor (battery low).
Well for some reason, the new Z-WaveJS system isn’t receiving any data on battery levels or PIR status. These are the only sensors I receive from my Aeon Labs ZW100 multisensor.
You need to wake up the battery devices so they are discovered. I can barely read your zwavejs2mqtt screenshot, but the device is in ProtocolInfo state, it needs to be Complete. (See docs).
I’m seeing the same thing with my Kwikset 916 locks. Without the zwave domain, I no longer have things like alarm_level and alarm_type. Did see sensors for battery level etc - but nothing for the alarm types and level.
My nodes have been in ProtocolInfo for several days. I ended up performing “Re-Interview Node” on one of them (node 6) and it finished the interview process (Complete) and now I see all my values. I just have to figure out which ones to send to HASS now. Still can’t get node 10 to complete, same thing it’s been in ProtocolInfo for days, even though the wake interval is 1800 secs.
I have a Schlage Connect door lock and the battery sensors are now showing as unavailable. The other sensors are working. Before the switch to JS the battery sensors were all functioning properly.
I switched from zwave2mqtt to zwavejs2mqtt. I use the websocket now to integrate.
I updated the zwavejs docker to version 1.1.1 and l lost all the battery connected devices. I have to re-interview them again. I never had this problem with zwave2mqtt. IS anyone else having the same issues ?
I am having a similar issue, except that my multisensor 6 is showing no entities whatsoever. I’ve woken the multsensor, but that hasn’t changed anything. Is there anything I need to do on the home assistant side to get it to re-interview the node?
I have factory reset my aeotec Zstick Gen5+, removed the z-wave integration and all z-wave devices in home assistant, etc to try to solve the issue that I didn’t get all sensors of the aeotec multisensor 6:
how do i wake up the device’s battery?
using the Zooz 4in1 sensor and the battery level is incorrect at 0%. it is the 3v battery and volt meter shows 3.4v so i know the battery is still good.
check the manual on the device, waking up hardware is hardware dependent. Also, I’ve noticed that most devices don’t report battery levels properly when dealing with normal disposable batteries like AA or AAA.
