I want implement in my HA instance (Core 2024.03; Supervisor 2024.02.1, OS 12.0) Z-Wave coordinator, so I bought Zooz ZST39. I connected it to my RPi 5 USB, added Z-Wave JS (0.4.5 version), configured proper USB port and generated unique keys for S0 and S2 (however S0 legacy is the same as in network field.
Configuration is saved, run addon and have following error.
[17:42:21] INFO: Service restart after closing
[18:42:23] INFO: Successfully send discovery information to Home Assistant.
Error: failed loading config file /etc/zwave_config.json
Error: Invalid key format for securityKeys.S2_AccessControl option
at normalizeKey (/usr/src/node_modules/@zwave-js/server/dist/bin/server.js:18:11)
at /usr/src/node_modules/@zwave-js/server/dist/bin/server.js:67:53
at Object.<anonymous> (/usr/src/node_modules/@zwave-js/server/dist/bin/server.js:155:3)
at Module._compile (node:internal/modules/cjs/loader:1356:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
at Module.load (node:internal/modules/cjs/loader:1197:32)
at Function.Module._load (node:internal/modules/cjs/loader:1013:12)
at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
at node:internal/main/run_main_module:28:49
I don’t catch what is wrong, why there is error and service is restaring all the time and I can’t add Z-wave integration (another error saying it cannot connect).
