I have three locks in my house - A Yale Pro SL and two Schlage Connects. The Yale Pro SL and one of the Schlage Connects work perfectly. But I recently added a second Schlage Connect to my house and I’ve been having difficulty getting it work fully with my set up. Locking and unlocking through Home Assistant works fine, but if I try to set user codes either by using Keymaster or by directly calling the Z-Wave: Set a usercode on a lock
service through developer tools, I get the following error in the logs:
[281472885487360] Error handling message: Unknown error (unknown_error)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 648, in handle_execute_script
await script_obj.async_run(msg.get("variables"), context=context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1524, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 409, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 453, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 476, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 451, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 684, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1738, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1775, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 769, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 931, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 715, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/zwave_js/lock.py", line 132, in async_set_lock_usercode
await set_usercode(self.info.node, code_slot, usercode)
File "/usr/local/lib/python3.10/site-packages/zwave_js_server/util/lock.py", line 112, in set_usercode
value = get_code_slot_value(node, code_slot, LOCK_USERCODE_PROPERTY)
File "/usr/local/lib/python3.10/site-packages/zwave_js_server/util/lock.py", line 32, in get_code_slot_value
raise NotFoundError(f"{property_name} for code slot {code_slot} not found")
zwave_js_server.exceptions.NotFoundError: userCode for code slot 2 not found
My system info:
HA 2022.10.1 running on Odroid N2
Silicon Labs ZST10-700 Z-Wave controller
Z-Wave JS driver version 10.3.0 / server version 1.24.0
Any ideas?
Thanks!
- Jeff
