Z-Wave JS Config DB matching
I have a GE Toggle Switch that is matching to a “GE Enbrighten Z-Wave Plus Smart Switch” which is the wrong device. Basically it matched this:
https://devices.zwave-js.io/?jumpTo=0x0063:0x4952:0x3137:0.0
And it should have matched this:
https://devices.zwave-js.io/?jumpTo=0x0063:0x4952:0x3032:0.0
The second one matches on product id and product type. The first one only matches on product type: 0x4952 or 18770.
My device json looks like this:
	"nodeId": 5,
	"index": 0,
	"status": 4,
	"ready": true,
	"isListening": true,
	"isRouting": true,
	"isSecure": false,
	"manufacturerId": 99,
	"productId": 12338,
	"productType": 18770,
	"firmwareVersion": "3.29",
	"name": "",
	"location": "",
	"deviceConfig": {
		"filename": "/usr/src/node_modules/@zwave-js/config/config/devices/0x0063/12722_zw4005.json",
		"manufacturer": "GE/Jasco",
		"label": "12722 / ZW4005",
		"description": "On/Off Relay Switch",
		"devices": [{
			"productId": 12338
		"firmwareVersion": {
			"min": "0.0",
			"max": "255.255"
My questions are:
  1. How does Z-Wave JS do the lookup and matching to the device id?
  2. Is there a way to override or force this?
The reason this is inconvenient is that I can’t change the LED states specified here:
                "endpoint": 0,
                "commandClass": 112,
                "commandClassName": "Configuration",
                "property": 3,
                "propertyName": "Night Light",
                "ccVersion": 1,
                "metadata": {
                  "type": "number",
                  "readable": true,
                  "writeable": true,
                  "label": "Night Light",
                  "default": 0,
                  "min": 0,
                  "max": 2,
                  "states": {
                    "0": "LED on when switch is OFF",
                    "1": "LED on when switch is ON",
                    "2": "LED always off"
                  "valueSize": 1,
                  "format": 1,
                  "allowManualEntry": false,
                  "isFromConfig": true
                "value": 0
