Working Z-Wave 1.4 converted to Z-Wave-JS (v0.1.51) . Seems to have mostly worked except the Z-Wave add-on log says the node is dead. I don’t understand much of the log information. Does anyone know what the last part is about and if it indicates a condition I need to fix? Would you recommend moving on to zwavejs2jqtt?
2022-01-06T20:15:26.362Z CNTRLR Performing soft reset...
2022-01-06T20:15:26.382Z CNTRLR Waiting for the controller to reconnect...
2022-01-06T20:15:27.886Z CNTRLR Waiting for the Serial API to start...
2022-01-06T20:15:32.889Z CNTRLR Did not receive notification that Serial API has started, checking if it respo
nds...
2022-01-06T20:15:32.918Z CNTRLR Serial API responded
2022-01-06T20:15:32.944Z CNTRLR querying version info...
2022-01-06T20:15:32.975Z CNTRLR received version info:
controller type: Static Controller
library version: Z-Wave 4.05
2022-01-06T20:15:32.977Z CNTRLR supported Z-Wave features:
2022-01-06T20:15:32.978Z CNTRLR querying controller capabilities...
2022-01-06T20:15:33.000Z CNTRLR received controller capabilities:
controller role: primary
is in other network: false
is SIS present: true
was real primary: true
is a SUC: true
2022-01-06T20:15:33.001Z CNTRLR finding SUC...
2022-01-06T20:15:33.034Z CNTRLR This is the SUC
2022-01-06T20:15:33.034Z CNTRLR querying node information...
2022-01-06T20:15:33.109Z CNTRLR received node information:
controller is a SUC: true
controller is a slave: false
controller supports timers: false
nodes in the network: 1, 2
2022-01-06T20:15:33.136Z CNTRLR [Node 001] Embedded device config loaded
2022-01-06T20:15:33.149Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms
2022-01-06T20:15:33.168Z CNTRLR serial API timeouts overwritten. The old values were: ack = 1500 ms, byte = 15
0 ms
2022-01-06T20:15:33.169Z CNTRLR Interview completed
Starting server on 0.0.0.0:3000
2022-01-06T20:15:33.191Z CNTRLR [Node 001] The node is alive.
2022-01-06T20:15:33.192Z CNTRLR [Node 001] The node is ready to be used
2022-01-06T20:15:33.196Z CNTRLR [Node 002] Beginning interview - last completed stage: ProtocolInfo
2022-01-06T20:15:33.198Z CNTRLR » [Node 002] pinging the node...
ZwaveJS server listening on 0.0.0.0:3000
New client
New client
2022-01-06T20:15:37.552Z CNTRLR [Node 002] The node did not respond after 1 attempts, it is presumed dead
2022-01-06T20:15:37.553Z CNTRLR [Node 002] The node is dead.
2022-01-06T20:15:37.554Z CNTRLR All nodes are ready to be used
2022-01-06T20:15:37.573Z CNTRLR [Node 002] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2022-01-06T20:15:37.575Z CNTRLR » [Node 002] querying node info...
2022-01-06T20:15:37.576Z CNTRLR » [Node 002] pinging the node...
Client disconnected
Code 1000:
2022-01-06T20:15:41.784Z CNTRLR [Node 002] The node did not respond after 1 attempts, it is presumed dead
2022-01-06T20:15:41.790Z CNTRLR [Node 002] ping failed: Failed to send the command after 1 attempts (Status No
Ack) (ZW0204)
2022-01-06T20:15:41.791Z CNTRLR [Node 002] Interview attempt (1/5) failed, node is dead.
